With an Hitachi Twin Carb (GX-style) engine a RHD car there is clearance aplenty to fit air cleaners. But on a LHD car fitting an air cleaner it a bit tricky because the brake and clutch cylinders are on the left side. But the Twin Hitachis are easily fitted to LHD than a twin-Weber setup.
GX air cleaners are different from 510 SSS Twin Carb, and take a different filter element.
The GX cleaner has a long snout. A12T cleaner has a mid-length snout, and A14T has a short snout.
Filter
All A-series twin-carb (GX, A12T, A14T) used the same filter element:
16546-H2300
Overall size 30cm x 15cm x 5.4cm center hole 24cm x 9.3cm
The L-series engines (PB110,PB210) used same as 510 (from 1969) and 610/710 and Europe 910K SSS
Nissan 16546-22000 Element
Subaru 16546-22000 Element
Overall size 323mm x 151mm x 60mm Center hole 264mm x92mm
K&N33-2010 Quinton Hazel QAF68 Unifilter UL324-60ST Fram CA2710 Ryco A257
GX
GX cleaner was red, and had a single small hose connection -- for the crankcase breather.
See main article: GX Air Cleaner
Also see GX Air Cleaner Part Numbers
A12T
B210 A12T cleaner was blue, and had several small hose connections.
* inner EVAP lines * Idle Compensator * Larger IMS hose
A14T
The A14T air cleaner has triangular bolt-pattern on the carburetor side.
PB110
B110 L14 engine Sunny Excellent 1400 had a single-hose air cleaner. It also uses an [[Idle Compensator].
Early style:
* 16500-H2700 up to '71-9
16500-H2710 from '71-10
* kidney-bean shape
PB210
Sunny Excellent 1400 B210 used the kidney-bean shaped air cleaner with no hot air option.
16500-H6003 Cleaner 16500-H6004 from '73-9 16500-H6005 from '74-12 16500-H6006 from '75-8
Air Horns
Stock utilizes air horns built into the air cleaner.
Air Horns, taken from air cleaner
Custom Air Cleaner
Datsfullysik created this nice air cleaner from modern parts.
- Valvoline VA61 air filter
- TFI air filter adapter
- bracket (could use plumbers strapping)
- hose and clampes
Cherry
Twin round air cleaners come from the Nissan Cherry A12T engine.
E10 Cherry X-1 models carried the A12T Hitachi Twin Carb engine (2-dr, 4-dr, and coupe).
Nissan Cherry as also fitted with twin-carb optional single air cleaner. Inside the housing fit two round filter elements. You can see two round sections on top and a slanted section giving it a kidney-bean shape.
16500-M0303 Cleaner-front 16500-M0804 from '73-9 16500-M0808 Cleaner-rear
Hot Air OPTION from 1973 - single housing 16500-M0810 Cleaner (op.) 16500-M0830 from '73-3 * Has twin round sections
16546-M0800 Element [round] 16546-M0810 Element [round, for single cleaner]
