Seats
Revision as of 01:20, 20 December 2014; view current revision
Category: Interior
Datsun 1200s came with different types of seats, depending on the market. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Sedan vs Coupe seats
sedan - fixed, with recliner OPTION
sedan GL, GX - x-pattern cloth
coupe - recliner, x-pattern cloth
truck - fixed, no recliner
Coupe Seats - sporty trim, but light with very little padding
Sedan Seats - flatter, with a bit more padding
Danish two-tone seat option (sedan)
STD, Deluxe - vinyl, black or yellow
GL - fabric insert
GX - plaid fabric insert
B110 GX-5 - hi-back seat, black
KPB110 GX - hi-back seat OPTION with ovoid recliner control
* laterally-padded seats
KPB110 GL - laterally-padded seats
B210 - low-back seats with small headrest
KB210/KPB210 - hi-back seats with round recliner control
KPB210 GLL/GXL - low-back seats with small headrest
B120 1978-1989 hiback seats, BROWN
B120 1989-1994 hiback seats, Black with GREY inserts
Late Sunny Truck
Unknown High-back seats
Sunny Truck
Many B120 have a fixed (non-sliding) passengers side seat rail, but all 1200 rails interchange so you can replaced with an adjustable seat rail.
1971-1978 Black low-back seats
1978-1989 Brown hi-back seats
1989-1994 Gray hi-back seats
-7803 Early Datsun 1200 utes
* sedan seat bottom
* Truck unfinished back
* fixed (non-reclining)
* thin headrest
** 87700-G1001 Head Restaint Assy OPTION ALL(assist)
7803-8910 - Brown
* High-back seat (no external headrest)
8910- Gray
Coupe, Sedan seats fit in ute, no problem, even though they are a little thicker than truck seats
Catalytic Converter Seats
later seats have passenger side lower mount -- to clear the catalyst bulge in the floor.
1976-1978 B-210 pictured here (1989-up Sunny Truck is similar)
Stock Seats
1972 USA Owners manual (see pages 4-5 for Seat information):
The rear [Coupe] seat area may be quickly and easily converted into baggage space when needed.
13933.jpg Japan 11913.jpg USA Coupe 5083.jpg Stock Seats
USA models:
  • 1973 models had blue or beige seats. Black was available (again) on from 0173
  • 1971-1972 models:
    • Coupe: Black, Beige or (optional) Yellow
    • Sedan: Black, Yellow, Gray
  • Reclining seats standard on coupe
  • Sedan had folding non-reclining seats with (optional) reclining seats
  • Sedan had some sort of optional front seats
1555.jpg Standard, Deluxe and Reclining Seats
456.jpg GX Seats
620.jpg DX Seats
765.JPG Recovered Seats
Aussie-Market
3537.jpg 1200 Coupe seats (custom fabric) in Datsun 1000
Ute
Australia-market B120 seats are not suitable for sedans as the back is not finished, but are extra thin compared to sedan seats with a slim-profile headrest.
th_IMG_0341.jpg th_IMG_0346.jpg th_IMG_0343.jpg th_IMG_0344.jpg th_tomita_akira_s15-img600x450-1352004442aujxg068643.jpg
Split-bench seat idea
th_ud_4771-img600x450-13084554571odvv046865.jpg th_ud_4771-img600x450-1308455540lyfjld47224.jpg th_ud_4771-img600x450-13084554565vjtmb46865.jpg
Bench Seat
120Y bakkie and 140Y bakkie (B140) came with a 3-passenger bench seat
Also see: B140_Model_Changes#Bench_Seat
120Y bakkie
th_480695915_7.jpg th_069c_20.jpg th_0596n3g_20.jpg th_7423chd_20.jpg th_470325156_4.jpg th_477434621_3.jpg
Parts
  • 86982-A0600 Eyelet 'A' Seat Back $1.12
  • 86983-A0600 Eyelet 'B' Seat Back $0.85
  • 87550-H1603 Slide-seat LH $44.33
  • 87500-H1603 Slide-seat RH
  • 87400-M3000 Hinge-recline RH $179.58
  • 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
  • 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors sometimes called coin trays. These fit above the floor just to the outside of each seat.
Seat Riser Trim
  • 74961-H1100 TRIM-seat riser (R.H.) DX, GL
  • 74962-H1100 TRIM-seat riser (L.H.) DX, GL
TRIM-SEAT RISER, RH
  • 74961-H1100 7510-7803 BLACK
  • 74961-G1060 7804-8910 DARK BROWN
  • 74967-95W00 8910- GRAY
th_willieoec-img600x450-13273001390hi3qt29706.jpg th_willieoec-img600x450-1327300140dg42d729706.jpg th_willieoec-img600x450-1327300140wpvelu29706.jpg
TRIM-SEAT RISER, LH
  • 74962-G1000 -7803 BLACK
  • 74962-G1060 7804-8910 DARK BROWN
  • 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
  • 66919-H1001 -7803 BLACK
    • 66919-H1001 is superseded by 01553-00291 $0.80 USD
  • 66919-G1060 7804-8910 DARK BROWN
  • 96815-B0700 8910-
TRIM CLIP is also used by the Kick Panel and coupe rear interior panels
Headrests
See main article: Headrests
Alternative Seats
Corolla 1326.jpg Laser 1731.jpg Prelude 1993.jpg Covers 2386.jpg Daihatsu 2017.jpg Buff's 2974.jpg EFI 4212.jpg Honda? 1785.jpg MOMO 236.jpg 262.jpg
Recaro Seats
Recaro is the premium automobile seat company.
1075.jpg 1203.jpg 9205.jpg 9623.jpg 13135.jpg 13952.jpg 13953.jpg 14206.jpg 14207.jpg 17242.jpg 17327.jpg 17774.jpg
Upholstery
See main article : Upholstery
Custom Upholstery
Racing Seats
1467.jpg Yokohama Seats
2617.jpg Revolution Racegear Seats
1897.jpg Baby Seat
2984.jpg SAAS Buckets
3481.jpg Sparco Buckets
4727.jpg OBX Daytona Buckets
3862.jpg Velo Seats
Seat Rails
See main article: Seat Rails
Adapting Seats
B210* seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat:
5185.jpg Seat Slide (aka Seat Rail)
* early B210 seats fit B110 directly
* late B210 seats have a non-flat bottom
If you don't have the B110 rails, you can adapt B210 or B310 slides:
5086.jpg Modifying B310 brackets to fit B110 chassis
Many, many other seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
5186.jpg Seat Adapting
554.gif Seat Slide
573.gif Seat Rails
574.gif Seat Rails
5085.jpg Chassis Brackets - for flat seat runners
9731.jpg 323 seats in 1200 coupe
Account and pictures of how to adapta Civic seats: http://forum.ratsun.net/showthread.php?t=776
Rear Seats
See Rear Seat
Australia Legalities
See Also
Seat Photo Index
