EFI Manifold
Revision as of 06:29, 9 December 2021; view current revision
Categories: Manifold | Fuel System | Fuel Injection
To convert your engine to EFI can obtain a factory EFI manifold or use the stock downdraft manifold with an EFI throttle body, buy a port-injection manifold, or make your own.
 Also see: Turbo Inlet Manifolds
Most EFI inlet manifolds are of the 'log' type - with (for an inline four motor for example) 4 downward runners that curve inward to the ports in the head, and a 'log' across the top connecting them. As agricultural as that sounds, it creates a necessary/desirable amount of turbulence and helps keep fuel suspended and satisfactorily distributed and mixed to produce good power -- and without danger of leaning out. This is use with a single throttle body at the entrance to the log. Using a large TB mean it can flow as much HP as the engine needs -- log manifold are not limited in power. The log acts as the plenum (air chamber) feeding the cylinders.
Log manifold with tuned-length runners (short for maximum HP at high RPM)
26377.jpgAlbum 26377
Log manifold with long runners (for maximum HP at medium RPMs)
661.jpgAlbum 661
The alternative is the Individual Throttle Body (ITB) which uses four throttle bodies, and a single runner for each cylinder. It can be with a plenum, or without. Without plenum means it is highly susceptible to RPM, and with a plenum means the torque curve is fatter. ITB w/o plenum does not make more HP than without, though it does look cool.
ITB
7303.jpgAlbum 7303
Factory EFI
Datsun made a factory EFI manifold for the A-series engine.
21849.jpgAlbum 21849 2758.jpgAlbum 2758
Buffalo
Buffalo1200 made an aftermarket manifold for their South African-made ATV project, now since discontinued.
28350.jpgAlbum 28350
Danie van Vuuren supplied all the fuel injection components for the Buffalo ATV project. The intake manifold is custom made & high quality. As of September 2011, Danie could supply you a complete setup or just the bare manifold for about R1800.00 for the bare intake manifold.
POST WTB 'Buffalo' fuel inj manifold
16236_5763562044de2.jpgPost 479298
26377.jpgAlbum 26377 28352.jpgAlbum 28352 28353.jpgAlbum 28353 28354.jpgAlbum 28354
28351.jpgAlbum 28351
DCOE Conversion
Many EFI kits are available for a Weber DCOE carburetor manifold.
See main artice: EFI
EFI on A14
Delorto
13322.jpgAlbum 13322 13321.jpgAlbum 13321 13320.jpgAlbum 13320
Bike Manifold
Instead of Bike Carbs, how about Bike EFI? Motorcycle throttle bodies are a cost-effective way to go.
gx1200
9441.gifAlbum 9441
* Kawasaki 1100 Throttle bodies
* Nissan RB30 injectors
* Microtech MT4 ECU
* Bosch pre pump and main pump
* Custom intake runners on standard intake flanges
* A15 Has had rings and bearings and a mild cam.
  Other than that its standard
* 57KW atw (43 rwhp, or about 54 engine HP)
His A15 probably had the low-RPM camshaft and round-port cylinder head from a Vanette, rather than the 80HP A15 from a B310.
rally1200 bike
35mm motor bike throttle bodies with injectors inbuilt
15077.jpgAlbum 15077
19835.jpgAlbum 19835
24290.jpgAlbum 24290
20918.jpgAlbum 20918
20917.jpgAlbum 20917
7303.jpgAlbum click to view 7020.jpgAlbum click to view 7016.jpgAlbum click to view 7015.jpgAlbum click to view 5747.jpgAlbum click to view
Custom
A tuned-runner manifold would not be hard to make one out of some steel tubing and a bit of 10mm plate for the flange, just need a throttle body around 50mm.
661.jpgAlbum 661
quote: Figure out exactly what you want, take some dimentions and a spare cyl head (if you have one) to an aluminum or stainless steel fabrication place eg, aluminium boat builder, have it fabricated ,then machined and bob's your uncle, you have an injection manifold. I'm an aluminium boat builder by trade, so I couldnt see it costing anymore than $250 - $350 max
2365.jpgAlbum 2365
9275.jpgAlbum 9275
1477.jpgAlbum click to view 1727.jpgAlbum click to view 1815.jpgAlbum click to view 2057.jpgAlbum click to view 2058.jpgAlbum click to view 3268.jpgAlbum click to view 3884.jpgAlbum click to view
Dimlights's UM-1
301.JPGAlbum click to view 300.JPGAlbum click to view 302.JPGAlbum click to view
Empson's innovative intake manifold allows use of stock exhaust manifold
You could also use a modified Hilborn injection manifold (A15 manifold with injector bosses welded on)
4069.jpgAlbum click to view
zigmondo
16236_5b4c4a8486819.jpgPost 488941
3rotor
post
Runner lengths are 225mm and can be adjusted by altering the silicone connectors.
3372384028_5ff7f7b9fa.jpg 3372382526_666c4e7cfb.jpg 3372382642_65d60d6462.jpg 3371562025_ffcfb480a4.jpg 3371562159_e43ef6ca8c.jpg 3372383074_8ce6225564.jpg 3372383306_6a2d8c8c52.jpg 3371562737_a930e0f019.jpg
bigv
7430.jpgAlbum 7430
22" runners, length tuned for torqe. For maximum high-RPM power, the diameter should be increased 7407.jpgAlbum 7407
Two-piece runners
7408.jpgAlbum 7408
rally1200 DCOE
rally1200 EFI on aftermarket DCOE manifold
23200.jpgAlbum 23200
23199.jpgAlbum 23199
Air horns
23198.jpgAlbum 23198
Extensive heat shield
23197.jpgAlbum 23197
rally1200 log
5631.jpgAlbum 5631
5747.jpgAlbum 5747
The_Engine_Room
18181_5728b8ed6c09b.jpgPost 478584
Lamb_Daiquiri
11744_57288bb983dcf.pngPost 478581
Whitley
705_5d17f711e6bcb.jpgPost 491820
s
