Hitachi Twin Carb Air Cleaners
Revision as of 07:32, 13 January 2013; view current revision
Category: Hitachi Twin Carb
With an Hitachi Twin Carb (GX-style) engine a RHD car there is clearance aplenty to fit air cleaners. But on a LHD car fitting an air cleaner it a bit tricky because the brake and clutch cylinders are on the left side. But the Twin Hitachis are easily fitted to LHD than a twin-Weber setup.
GX air cleaners are different from 510 SSS Twin Carb, and take a different filter element.
The GX cleaner has a long snout. A12T cleaner has a mid-length snout, and A14T has a short snout.
Filter
All A-series twin-carb (GX, A12T, A14T) used the same filter element:
16546-H2300
Overall size 30cm x 15cm x 5.4cm
center hole 24cm x 9.3cm
The L-series engines (PB110,PB210) used same as 510 (from 1969) and 610/710 and Europe 910K SSS
Nissan 16546-22000 Element
Subaru 16546-22000 Element
Overall size 323mm x 151mm x 60mm
Center hole 264mm x92mm
K&N33-2010
Quinton Hazel QAF68
Unifilter UL324-60ST
Fram CA2710
Ryco A257
GX
GX cleaner was red, and had a single small hose connection -- for the crankcase breather.
See main article: GX Air Cleaner
Red - A12GX
Also see GX Air Cleaner Part Numbers
A12T
B210 A12T cleaner was blue (early ones may have been red). It differs from the GX cleaner by having several small hose connections.
* inner EVAP lines
* Idle Compensator
* Larger IMS hose
Blue - A12T
th_A12T_air_cleaner_stack.jpg th_A12T_air_cleaner_fitting.jpg th_A12T_air_cleaner.jpg
Hot air OPTION
A14T
The A14T air cleaner has triangular bolt-pattern on the carburetor side.
PB110
B110 L14 engine Sunny Excellent 1400 had a single-hose air cleaner. It also uses an [[Idle Compensator].
Early style:
* 16500-H2700 up to '71-9
16500-H2710 from '71-10
* kidney-bean shape
th_img_958563_14330428_2.jpg th_img_958563_14330428_0.jpg th_img_958563_14330428_1.jpg th_img_958563_13504444_2.jpg th_img_958563_13504444_1.jpg
PB210
Sunny Excellent 1400 B210 used the kidney-bean shaped air cleaner with no hot air option.
16500-H6003 Cleaner
16500-H6004 from '73-9
16500-H6005 from '74-12
16500-H6006 from '75-8
Air Horns
Stock utilizes air horns built into the air cleaner.
Air Horns, taken from air cleaner
Long horns
Custom Air Cleaner
Datsfullysik created this nice air cleaner from modern parts.
  • Valvoline VA61 air filter
  • TFI air filter adapter
  • bracket (could use plumbers strapping)
  • hose and clampes
12635.jpg 12636.jpg 12637.jpg 12682.jpg 12683.jpg 12684.jpg 12694.jpg 12695.jpg 12696.jpg
Cherry
Twin round air cleaners come from the Nissan Cherry A12T engine.
E10 Cherry X-1 models carried the A12T Hitachi Twin Carb engine (2-dr, 4-dr, and coupe).
Nissan Cherry as also fitted with twin-carb optional single air cleaner. Inside the housing fit two round filter elements. You can see two round sections on top and a slanted section giving it a kidney-bean shape.
16500-M0303 Cleaner-front
16500-M0804 from '73-9
16500-M0808 Cleaner-rear
Hot Air OPTION from 1973 - single housing
16500-M0810 Cleaner (op.)
16500-M0830 from '73-3
* Has twin round sections
16546-M0800 Element [round]
16546-M0810 Element [round, for single cleaner]
Cherry air cleaners can be used in the B110
619.jpg 776.jpg 954.jpg 955.jpg 960.jpg 1002.jpg 1003.jpg 1488.jpg 1503.jpg 1504.jpg 1509.jpg 1510.jpg 1512.jpg 1517.jpg 1519.jpg 1973.jpg 2804.jpg 2805.jpg 2806.jpg 2845.jpg 2846.jpg 2892.jpg 3168.jpg 3171.jpg 3384.jpg 3360.jpg 3375.jpg 3682.jpg 5007.jpg 6297.jpg 6442.jpg 6489.jpg 6493.jpg 6727.jpg 7000.jpg 8091.jpg 8125.jpg 8126.jpg 8355.jpg 8362.jpg 9257.jpg 9258.jpg 9589.jpg 9725.jpg 9858.jpg 11789.jpg 13044.jpg 13363.jpg 13428.jpg 13673.jpg 13674.jpg 13675.jpg 13882.jpg 13957.jpg 14757.jpg 14758.jpg 14760.jpg 14856.jpg 14956.jpg 14957.jpg 16059.jpg 15118.jpg 15236.jpg 15425.jpg 15729.jpg 15777.jpg 15778.jpg 15864.jpg 16060.jpg 16571.jpg 17046.jpg 17253.jpg 18076.jpg 18060.jpg 18250.jpg 18755.jpg 18756.jpg 18757.jpg 18759.jpg 18936.jpg 19100.jpg 21289.jpg 21290.jpg 21291.jpg 21533.jpg 21534.jpg
