With an Hitachi Twin Carb (GX-style) engine a RHD car there is clearance aplenty to fit air cleaners. But on a LHD car fitting an air cleaner it a bit tricky because the brake and clutch cylinders are on the left side. But the Twin Hitachis are easily fitted to LHD than a twin-Weber setup.
GX air cleaners are different from 510 SSS Twin Carb, and take a different filter element.
The GX cleaner has a long snout. A12T cleaner has a mid-length snout, and A14T has a short snout.
Filter
All A-series twin-carb (GX, A12T, A14T) used the same filter element:
16546-H2300
Overall size 30cm x 15cm x 5.4cm center hole 24cm x 9.3cm
The L-series engines (PB110,PB210) used same as 510 (from 1969) and 610/710 and Europe 910K SSS
Nissan 16546-22000 Element
Subaru 16546-22000 Element
Overall size 323mm x 151mm x 60mm Center hole 264mm x92mm
K&N33-2010 Quinton Hazel QAF68 Unifilter UL324-60ST Fram CA2710 Ryco A257
GX
GX cleaner was red, and had a single small hose connection -- for the crankcase breather.
See main article: GX Air Cleaner
Also see GX Air Cleaner Part Numbers
A12T
B210 A12T cleaner was blue (early ones may have been red). It differs from the GX cleaner by having several small hose connections.
* inner EVAP lines * Idle Compensator * Larger IMS hose
A14T
The A14T air cleaner has triangular bolt-pattern on the carburetor side.
See main article: A14T_Part_Numbers#Air_Cleaner
PB110
B110 L14 engine Sunny Excellent 1400 had a single-hose air cleaner. It also uses an [[Idle Compensator].
Early style:
* 16500-H2700 up to '71-9
16500-H2710 from '71-10
* kidney-bean shape
PB210
Sunny Excellent 1400 B210 used the kidney-bean shaped air cleaner with no hot air option.
16500-H6003 Cleaner 16500-H6004 from '73-9 16500-H6005 from '74-12 16500-H6006 from '75-8
Air Horns
Stock utilizes air horns built into the air cleaner.
Air Horns, taken from air cleaner
Custom Air Cleaner
Datsfullysik created this nice air cleaner from modern parts.
- Valvoline VA61 air filter
- TFI air filter adapter
- bracket (could use plumbers strapping)
- hose and clampes
Cherry
Twin round air cleaners come from the Nissan Cherry A12T engine.
E10 Cherry X-1 models carried the A12T Hitachi Twin Carb engine (2-dr, 4-dr, and coupe).
Nissan Cherry as also fitted with twin-carb optional single air cleaner. Inside the housing fit two round filter elements. You can see two round sections on top and a slanted section giving it a kidney-bean shape.
16500-M0303 Cleaner-front 16500-M0804 from '73-9 16500-M0808 Cleaner-rear
Hot Air OPTION from 1973 - single housing 16500-M0810 Cleaner (op.)![]()
16500-M0830 from '73-3 * Has twin round sections
16546-M0800 Element [round] 16546-M0810 Element [round, for single cleaner]
Cherry air cleaners can be used in the B110
