Steering wheel
Revision as of 10:41, 16 February 2019; view current revision
Categories: Body | Steering System
Datsun 1200 and Truck variants were fitted with a variety of steering wheels. They are 15 inch diameter wheels (overall diameter 15.75"/40cm). They have a 5/8" (16mm) thick rim section.
Variations
DX, GL, and GX comparo
8880.jpgAlbum 8880
STD/DX (1-spoke)
3700.jpgAlbum 3700
GL (3-spoke)
6467.jpgAlbum 6467
GX (3-spoke metal)
3158.jpgAlbum 3158
Sunny Truck
21325.jpgAlbum click to view 21323.jpgAlbum click to view 21324.jpgAlbum click to view
SSS
6595.jpgAlbum 6595 6787.jpgAlbum 6787
PB110 used the same steering wheels as B110 -- at least with early PB110
460.jpgAlbum 460
1989-1994 1200
B10
The Datsun 1000 (B10) wheels were different from B110 items.
STD | GL | SPORTS
14227.jpgAlbum 14227 3626.jpgAlbum 3626 20578.jpgAlbum 20578
B210 handles bolt to the 1200 steering column.
DX
GL
10874.jpgAlbum 10874
GX
3656.jpgAlbum 3656
GX custom painted spokes | 160Z
21038.jpgAlbum 21038 11371.jpgAlbum 11371
B310
B310 steering wheels supposedly do not fit B110 or B210 steering column. But you can modify the steering column.
JDM B310
DX  single spoke
GL  tri-spoke
GX  leather-like & stainless
OPT black wood & stainless
    brown wood & stainless
B310 GX leather-like vinyl with stainless spokes
B310 GX in B110
25884.jpgAlbum 25884
B310 GX in B210
1965.jpgAlbum 1965
B310 DX/STD
front1.jpgPost click for topic
B310 GL
ssw1.jpg ssw2.jpg IMG_20150604_203131_zpsyqeuchdr.jpgPost click for topic IMG_20150604_203313_zps9fstteqy.jpg
48498 EMBLEM
48423-H8560 GL steering wheel (small type button)
* K,W -7909
* S
* V STD
Nismo 10th Anniversary
20652.jpgAlbum 20652
240Z OPTION looks similar - and does not fit 1200
12579.jpgAlbum 12579
Removal and Installation
First, remove the horn pad. To remove the horn button, remove the two screws from behind the wheel (B110 normal) or push in and twist for GX type.
STD/DX: screws on back side
GX type - push in and twist anti-clockwise to remove
26420.jpgAlbum click to view 26421.jpgAlbum click to view
Next, unbolt the steering shaft large nut. Do not remove it all the way, keep it on so the wheel won't fly off while popping the wheel from the shaft.
Be sure to use a wheel puller:
5106.jpgAlbum 5106
Occasionally you can remove the nut and "pop" it off by hitting it from behind with your fists, but you risk the chance of having it hit you in the face when it pops loose. Discussion
Be safe, don't worry. Only about $15 new for a simple type.
24703.jpgAlbum 24703
Ute wheel in Coupe
2689.jpgAlbum 2689
B210 GX in B110
9848.jpgAlbum 9848
B210 GL in Datsun 1200
13914_4df4b7a34787b.jpgPost 371646 25886.jpgAlbum 25886
Other wheels fit the hub but may not match the trim. The B110 steering wheel hub uses the same bolt pattern as:
45mm between bolts (1-15/16 inch)
* 1970-1976 B110 (Sunny/1200)
* 1974-1978 B210 (Sunny/120Y)
* 1977-1979 S10 (Silvia/SX200)
* 1976-1977 F10 (Cherry)
* 1979-1982 N10 (Pulsar/210)
Only three Datsun models used the small diameter steering column shaft, those models being the B10, B110 & B210. The B10 used blinker canceling pins that were reasonanly close together & this made it unique, The B110 & B210 share the same specs so the hub/boss is interchangeable between these two models.
B310 GX in B110 (with B110 GX horn button)
2129.jpgAlbum 2129
26308.jpgAlbum 26308
All other Datsun models [at least those from the mid 60's], including the B310, used a larger diameter shaft & the boss for any of these will be too big in the hole.
B110
Including PB110
48498-H1000 EMBLEM 'S' MARK DX
48498-H1100 EMBLEM 'D' MARK DX
#DX Two-spoke 48400-H1000,48400-H1001 ASS'Y-WHEEL-steering Std, Dx
#GL Three-spoke 48400-H2000,48400-H2001 ASS'Y-WHEEL-steering GL
#GX metal three-spoke 48400-H2300,48400-H2301 ASS'Y-WHEEL-steering GX
OPTIONAL - There were two Optional Steering Wheels
  • 48400-H1200 ASS'Y-WHEEL-steering (wood) OPTION ALL (per JDM catalog)
    metal three-spoke, one-slot spokes covered with plastic trim
  • 48400-H2310 ASS'Y-WHEEL-steering (foam skin) OPTION ALL (per JDM catalog)
    metal three-spoke (at 2, 10, and 6 o'clock), one-slot spokes uncovered
    14654.jpgAlbum click to view
5298.jpgAlbum click to view
These wheels were derived directly from the B10 option wheel. They made a new hub (boss) to suit the 1200 column & a new horn button to 'update' them but are otherwise the same.
The optional wheels are different from the B10 mainly in the horn button and the hub part (the wheels themselves appear to be the same, but were only sold as an assembly).
  • The 1200 horn button is wider at the top, and narrower where it bolts to the wheel
  • The 1000 horn button is the opposite (narrower at the top)
Also, the 1200 hub part where it meet the steering column is bigger diameter. So the 1200 hub flares out slightly to this larger diameter. The 1000 hub is completely cylindrical.
Note that the 1000 hub on the right is cylindrical & has closely spaced blinker pins, while the 1200 hub on the left is conical, or bell shaped & has pins more widely spaced.
The wheel & the complete horn switch assembly are identical between the B10 OPTION wheel and the B110 OPTION wheel.
DX
3700.jpgAlbum 3700
GL
457.jpgAlbum 457 GL_handle-1.jpg GL_handle-2.jpg 48400-H20_a.jpg 48400-H20_b.jpg
GX
48420-H2325 ASS'Y-PAD, horn GX
48498-H2300 EMBLEM-'GX'
metal three-spoke, each spoke has a divided slot
21781.jpgAlbum 21781 460.jpgAlbum 460 21782.jpgAlbum 21782
20500.jpgAlbum 20500
B120 Sunny Truck
#Early Black | #Mid Brown | #Late Gray
Center Emblem
* 48498-H1000 -7803 NLA
* 48409-H5002 7804-7907
* 48409-G1660 'S' 7908-
  27043.jpgAlbum 27043
Early Black
Early 1971-1978, 1200 STD/DLX wheel, same as coupe, sedan and wagon
21325.jpgAlbum 21325
48400-G1000 -7803
18259.jpgAlbum 18259 11149.jpgAlbum 11149
Mid Brown
1978-1989, same as #B210 (brown only)
48400-G1060 7804-7907 Dark Brown
48400-G1660 7908-8910 Brown
21323.jpgAlbum 21323
Late Gray
1989-1994, same as before except Gray
48400-95W00 8910- [Gray]
2689.jpgAlbum 2689 17269.jpgAlbum 17269
Bakkie
South Africa 1200 & B140 bakkie
1979-1989 brown
1990-2008 brown or gray
handle.jpg 8985.jpgAlbum 8985
13025.jpgAlbum 13025 19330.jpgAlbum 19330
48400-H5000, 48400-H5001 STD, DX, PB210 DX
* two-spoke
3127.jpgAlbum click to view  full
48400-H5100, 48400-H5103 black (wood-like) GL
* three-spoke
10874.jpgAlbum click to view 6731.jpgAlbum click to view
48400-H5102,H5105 black (wood-like) PB210 GL, op. PB210 DX
48400-H5101,H5104 brown (wood-like) PB210 GL, op. PB210 DX
* three-spoke
* 48400-H5104 brown (wood-like) L16 GL
* 48400-H5105 black (wood-like) L16 GL
48400-H5200 (leather-like) GX, op. ALL
48400-H5202 < 48400-H5203 (leather-like) GX, op. ALL
* three-spoke, five rectangular holes in each spoke
48400-H7210 ASSY-STEERING WHEEL 3 SPOPK LEATHERETTE OP.COUPE FROM 0875 USA
6623.jpgAlbum click to view
48400-H5600, 48400-H5800, 48400-H5802 (wood) OPTION ALL, PB210 OPTION ALL
19641.jpgAlbum click to view
48400-H6000, 48400-H6001, 48400-H6002 (leather-like) PB210 GX, L16 GX, L16 GL
48400-H7509 A14T
20453.jpgAlbum click to view:GX-T
48400-H7800 Van Super Deluxe (black wood-like)
GX center pad removal: Push in hard and and slowly gently twist it counterclockwise and it should just turn and plop off.
B210 GX
B210 GX handle, OPTION for non-GX
* Black Spokes, spiral-pattern emblem
* Chrome Spokes, wood-pattern emblem (from 1973 October)
This variation has chrome spokes and an unusual wood-grain center emblem without a horn mark
Spiral-pattern center with horn logo
48400_B210-GX_a.jpg 48400_B210-GX_b.jpg 48400_B210-GX_c.jpg th_10994_512c6a6db276f.jpgUpload
USDM GX
13518.jpgAlbum 13518
S10
1977-1979 Datsun 200SX (Silvia) used a steering wheel that looks like the B210 GX wheel.
  • Black 48400-N5810/48400-N5815
  • Brown 48400-N5811/48400-N5816
  • Brown, light 48400-N7800 1979
  • Green 48400-N5812/48400-N5817
  • Blue 48400-N7801 1979 only
Does this fit small shaft (B110/B210) or large shaft (B310)?
Aftermarket Wheels & Hubs
Aftermarket steering wheels generally require an adapter hub.
See Main Article: Steering_wheel_boss_kit
Purchase an aftermarket (non-factory) wheel for various reason:
  • Looks. Beautiful natural woods, or hi-tech looking modern designs, or maybe chrome
  • Room. A smaller diameter wheel requires more effort to turn, but provides a bit more leg room
  • Tall drivers. For those who like the seat back, extend the wheel
  • Racing. Smaller wheel turns the car faster for tight road circuits
6279.jpgAlbum 6279
Room
OMP Kubic with flat top crown and bottom crown
15731.jpgAlbum 15731
Sparco 350mm (giving 25mm more legroom, as stock wheel is 400 mm)
174_57940f8ba0e97.jpgPost 480068 4180.jpgAlbum 4180
Extended | Deep Dish
1993.jpgAlbum 1993 4246.jpgAlbum 4246
Woods
669.JPGAlbum click to view 772.jpgAlbum click to view 977.jpgAlbum click to view 978.jpgAlbum click to view 1909.jpgAlbum click to view 2531.jpgAlbum click to view 3843.jpgAlbum click to view 5493.jpgAlbum click to view
Colors
3082.jpgAlbum click to view 4246.jpgAlbum click to view 4298.jpgAlbum click to view
th_4356.jpgAlbum click to view
th_4363.jpgAlbum click to view
50.JPGAlbum click to view 223.jpgAlbum click to view 236.jpgAlbum click to view 532.jpgAlbum click to view 553.gifAlbum click to view 559.gifAlbum click to view 601.jpgAlbum click to view 639.JPGAlbum click to view 784.jpgAlbum click to view 1203.jpgAlbum click to view 1206.jpgAlbum click to view 1327.jpgAlbum click to view 1563.jpgAlbum click to view 1886.jpgAlbum click to view 1898.jpgAlbum click to view 1976.jpgAlbum click to view 2041.jpgAlbum click to view 2075.jpgAlbum click to view 2671.jpgAlbum click to view 2706.jpgAlbum click to view 2881.jpgAlbum click to view 3104.jpgAlbum click to view 3138.jpgAlbum click to view 3189.jpgAlbum click to view 3791.jpgAlbum click to view 3852.jpgAlbum click to view 3864.jpgAlbum click to view 3865.jpgAlbum click to view 4038.jpgAlbum click to view 4154.jpgAlbum click to view 4155.jpgAlbum click to view 4161.jpgAlbum click to view 6703.jpgAlbum click to view 11578.jpgAlbum click to view 15800.jpgAlbum click to view 24579.jpgAlbum click to view
Cherry
E10 Nissan Cherry wheel in B110
13131.jpgAlbum 13131
E10 Cherry - see main article: X-1R
misc
Datsun B10 OPTiON wheel with aftermarket (Nismo?) 'GT' horn button
12703_4b51d0e0898c6.jpgPost 300158
aftermarket horn button (fits GX wheel?)
Left: 240Z wheel modded for 1200 | Right: B10 wheel with Nismo horn button
5372.jpgAlbum 5372
