Wide gearbox crossmember
From Datsun 1200 Club
Category: Transmission Modifications
A wide crossmember can be bolted to the floor pan using large washers for reinforcement. Then the original 1200 gearbox body brackets can be removed, providing enough space for large gearbox fitment.
18458.jpgAlbum 18458
Note
A generic wide crossemember is not needed for A-series gearboxes. For more specific crossmember mods, see:
In general, a generic "wide" crossmember makes for easy swaps.
Unlike the stock in-the-tunnel crossmember, a wide unit stretches across the floor pan
30355.jpgAlbum 30355
For manual 1200 car, remove the factory mounting bosses from the tunnel (if the room is needed), and bolt a flat or box section plate to the bottom of the car.
7604.jpgAlbum 7604 19252.jpgAlbum 19252
Note that the factory crossmember mounting brackets have been removed from inside the tunnel. The new custom crossmember bolts to the floor.
universal gearbox crossmember designs
A piece of 40mm box steel will do the job. Bolt it to the rubber mount of the gearbox and then bolt it to the floor - add some spacers as required.
PIGDOG welded late model Nissan floor boss
9568.jpgAlbum 9568 9569.jpgAlbum 9569
IMG_20130115_192832.jpgPost click for topic
Channel section
18827.jpgAlbum 18827
mattdatca18
017.jpgPost click for topic
sandwich
12692.jpgAlbum 12692 12693.jpgAlbum 12693
Silvia mount insulator
nismogearboxmount.jpg 9618.jpgAlbum 9618
9619.jpgAlbum 9619 9598.jpgAlbum 9598
Rear crossmember (Transmission Mount)
11170.jpgAlbum 11170
mildman
All gearbox options for the 71-Series Transmission will need you to fabricate (or get someone to fabricate) a new gearbox crossmember to attach the gearbox to the floor of your car. In the case of a stumpy 5 speed just a piece of 40mm box steel will do the job. Bolt it to the rubber mount of the stumpy and then bolt it to the floor - add some spacers as required. Here a pic of a crossmember I made. (It only gets wider at the edges as I had some existing holes in the floor of the Datto I wanted to use.)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Wide_gearbox_crossmember"
This page has been accessed 6,179 times. This page was last modified 21:53, 25 April 2025. Content is available under Datsun 1200 Club.
