Bumper
(Redirected from Rear Bumper)
Categories: Body | Fibreglass
Adorning the extreme ends of the Datsun 1200 are chrome bumpers. Although the front bumper is shared by all models, the rear bumper differs between Coupe, Sedan, Van and Sunny Truck. The revised front bumpers have bolt holes for USA and Japan license plates (two sets of holes), while early ones are specific.
FRONT
* sedan, coupe, wagon, truck 1971-1978
* truck 1978-2008
REAR
* Sedan  license number lamp
* Coupe  license number cutout
* Wagon  plain straight bumper
* Ute    bumperettes (rubber pads)
21426.jpgAlbum 21426
rubber #Overriders
21439.jpgAlbum 21439
SEDAN - straight rear bumper with opening for plate light
25125.jpgAlbum 25125 25358.jpgAlbum 25358
Front
The front bumper= of a 1200 is a fairly straight chrome bar and has two small notches on the bottom for the front turn-signal lights:
21425.jpgAlbum 21425
All 1200 models used the same front bumper, including Truck through March 1978
wagon_front.jpg 737.jpgAlbum 737 21426.jpgAlbum 21426 8580.jpgAlbum 8580 3085.jpgAlbum 3085 9917.jpgAlbum 9917 736.jpgAlbum 736
North America 1200 came with rubber #overriders
10129.jpgAlbum 10129
The front bumper is in three pieces, although it is sold factory assembled as one piece.
  • Two long front sections (left and right) that curve and the end to wrap around the side just a little
  • a shallow degree binding piece (the front bumper is a slight V)
21427.jpgAlbum 21427
inside
Measurements
Bumper bar
Stay bolt holes: 710 mm apart
Height: ~90 mm
Depth at Center: ~30 mm
Depth off Center: ~45 mm
Has both plate holes:
* License Plate holes USA: 7" (~178mm)
* Number Plate holes Japan 210 mm (some threaded, some not)
Some have extra cosmetic front bolt holes:
Outer front bolt holes: 300 mm outboard of stay holes
24720.jpgAlbum 24720
Stays
Stays mount the bumper to the body. Early vs late stays have a different bolt angle and spacing (not interchangeable).
Early 1200s use 8mm bolts (fastening Stay to Hood Ledge)
Later 1200s use 12mm bolts (from '72-7)
Main: Stays
Australia
Australian-assembled 1200s used a unique multi-piece bumper
separate-formed ends joined to the main section bar
30353.jpgAlbum 30353
center bar is one-piece, without the seam that Japan-built 1200s have
30354.jpgAlbum 30354
B120
Australia utes used the same #Front bumper as coupe and sedan until the last 1985.
JDM 1971-1978
STD trucks used a flat-silver painted bumper (62651-G1001)
DX trucks used a chrome bumper (#62651-H1001)
From April 1978, Sunny Truck used a rubber-ended bumper
21428.jpgAlbum 21428
April 1978-1989 October, chrome (メッキ) 62651-G1060
20832.jpg 20832.jpgbrochure
October 1989-1994 Sunny Truck black 62010-W9500
31015.jpgbrochure
New Zealand
SportStar B120 utes had black bumpers:
28046.jpgAlbum 28046
B140 Bakkie
174_6927f5c7d7097.jpgPost 499134
The B140 Bakkie has a larger black painted flat bumper, with the front combination lamps in the face.
7403.jpgAlbum 7403
It has rubber ends
174_6927fe4c79b1f.jpgPost 499139 174_6927f76a0b7d8.jpgPost 499135 20114.jpgAlbum 20114
Stays
31362.jpgAlbum 31362
PB110
PB110 Sunny Excellent came with a unique front bumper with a separate bar and S-curved ends. Every piece is different from the 1200 (bar, stays & brackets). The fasteners (bolts, washers and shims) are same as the 1200.
H25 bumper
27646.jpgbrochure 459.jpgBrochure
301-01.jpgPart Numbers
Bumper end: 62653-H2500 BUMPER-front (R.H.)
26757.jpgAlbum 26757 26758.jpgAlbum 26758
Rear
Rear bumpers differ by 1200 model, and are distinguished by the license plate lighting provision. PB110 used the same rear bumpers as regular B110.
  • #Sedan Rear bumper has a small light in the center facing up to illuminate the license plate
  • #Coupe Rear bumper has a notch for the license plate:
    225.jpgAlbum click to view 174_56b925bdbaeb2.jpgUpload click to view
  • Wagon is smooth with no notch and no light:
    753.jpgAlbum click to view 2998.jpgAlbum click to view
  • #Ute Rear has rear bumper, just rubber pads
  • North America 1200 had rubber #overriders
    3250.jpg 21439.jpgAlbum click to view
Sedan Rear
bumper has a small lamp in the center facing up to illuminate the license plate
29755.jpgAlbum 29755 20726.jpgAlbum 20726
2305.jpgAlbum 2305 11174.jpgAlbum 11174
PB110 (1400) and B110 (1200) use same rear bumpers
25663.jpgAlbum 25663 24665.jpgAlbum 24665
Coupe Rear
Coupe bumper has a notch for the number plate, the notch is wide to acommodate Commonwealth plates as well as the narrower Japan or USA plates.
H18 (coupe) bumper bar
10367.jpgAlbum 10367 225.jpgAlbum 225
174_56b925bdbaeb2.jpgPost 476204 174_56b925ca12873.jpgPost 476204 174_56b925dab4333.jpgPost 476204
H19 North America coupe with #Overriders (same as H18 but with holes drilled for bolting on overriders)
3250.jpgAlbum click to view 174_6186e8f1663de.jpgPost 496134
H18 worldwide (no overrider bolt holes)
452.jpgAlbum click to view 3850.jpgAlbum 3850
Truck Rear
Ute had two small rubber pads (for the tailgate to drop against), and two black corner bumperettes:
2710.jpgAlbum 2710 5650.jpgAlbum 5650 237.jpgAlbum 237 20967.jpgAlbum 20967
21431.jpgAlbum 21431
Custom
Sunny B210 bumper fitted to Sunny Truck
21423.jpgAlbum 21423
B140 Bakkie
Late-model B140 Bakkie rear has the standard two black corner bumperettes but with reflectors in the face.
The latest bakkies had Reflectors in the bumperettes
22424.jpgAlbum 22424
RED starboard
RED port
174_6927fd1cceda8.jpgPost 499138 6427.jpgAlbum 6427
8986.jpgAlbum 8986
Stays
1973 USA Bumpers
For 1973, USA models got redesigned bumper-to-body brackets to meet FMVSS No. 215 (2.5 mph bumpers). They also used larger bumper pads. The chrome parts look similar but are different. These are not safety bumpers but are designed to reduce low-speed car damage (property damage).
174_57c618c25c43a.jpgPost 480921
NOTE: A 1973 front bumper with brackets does not fit a 1971 or 1972 model
15928.jpgAlbum 15928
H70 front bumper
2029.jpgAlbum 2029 10906.jpgAlbum 10906
Front reinforcement
19762.jpgAlbum 19762
H70 rear sedan bumper
21440.jpgAlbum 21440
H71 rear coupe bumper (notched for license plate)
6804.jpgAlbum 6804 21438.jpgAlbum 21438
Implementation Details:
Two-piece construction
Note the double-set of bolt holes for the stays (inboard of the lamp cutouts)
License Plate Lighting
 Also see: Rear License Plate Lamp
For North America in order to meet new FMVSS regulations, 1973 Sedan rear bumper was modified to have a brighter license plate lamp (the coupe with its dual lamps was already bright enough). The lighting moved from the bumper to near the plate.
1973 Sedan - bumper bar with no light (H70)
1427.jpgAlbum 1427
The resulting bumper was similar to a wagon bumper but came with large rubber overriders and extra holes to bolt to the larger 1973 stays.
1973 apron panel is same as earlier
174_57c618dba3523.jpgPost 480921
South Africa
1200s in South Africa, at least from 1973, were factory-fitted with Datsun 510 bumpers. These have a bit longer overbend, but are the same width.
8349.jpgAlbum 8349
2738.jpgAlbum 2738
Bumper Options
Coupe shown with Overriders AND a Bumper Guard
28036.jpgAccessories
Overriders
JDM models came without rubber overriders, but all North American models had rear overriders front and rear.
with overriders
10129.jpgAlbum 10129 21439.jpgAlbum 21439
without overriders
21096.jpgAlbum 21096 20651.jpgAlbum 20651 20802.jpgAlbum 20802
North America bumpers with overriders removed (note holes in bumper)
6599.jpgAlbum 6599 6603.jpgAlbum 6603
Rare Australia overriders
12928.jpgAlbum 12928
the rubber part snaps into the holes in the metal part
21179.jpgAlbum 21179
rubber parts not installed
Bumper Guards
OPTION available from Datsun USA dealers were tubular steel "bumper guards" (a type of overrider) from Amco:
Datsun part number
99990-00025 Guard-bumper front
99990-00026 Guard-bumper rear
Amco 5563 shown on Coupe
20584.jpgamco
From the 1971 Accessories brochure
28036.jpg1971 Accessories 28037.jpgAlbum 28037 28038.jpgAlbum 28038
29150.jpg1972 Accessories
Bull Bar
Bullbar or Roo bar will prevent random large animals from smashing your radiator grille. In some places called a Brush Guard or Nudge Bar.
Factory B140 Bull Bar
Dealer-installed Roadstar Nudge Bars
28049.jpgAlbum 28049 28050.jpgAlbum 28050
Heavy-Duty Bumper with Bilby Guard
14009.jpgAlbum 14009 4290.jpgAlbum 4290
Bull Bar
21424.jpgAlbum 21424
sidedraught's Bull Bar:
12898.jpgAlbum 12898
South African Safari Bar
16171.jpgAlbum 16171
Ecuador Brush Guard on B210 2-dr sedan
17082.jpgAlbum 17082 17078.jpgAlbum 17078
Fibreglas
FRP (fiber reinforced plastic), fiberglass or carbon fibre
From Bprojects mail order: Stock bumper design made in FRP with White Gel Coating
Custom Bumpers
Bumperettes
13782.jpgAlbum 13782 17697.jpgAlbum 17697 DSC05995.jpg 9852.jpgAlbum 9852
Blackout
Black painted
9989.jpgAlbum 9989 20931.jpgAlbum 20931
Bumperless Look
Bumper removed
7926.jpgAlbum 7926 17657.jpgAlbum 17657
2442.jpgAlbum 2442
19563.jpgAlbum 19563 19564.jpgAlbum 19564
Chromeless Coupe
14005.jpgAlbum 14005
Smooth Coupe
17954.jpgAlbum click to view
Bumperless Custom
17862.jpgAlbum click to view
Smooth Utes
Bumpers backside Sunny Trucks (bumperettes removed)
2137.jpgAlbum 2137
バンパー
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Bumper"
This page has been accessed 130,526 times. This page was last modified 03:47, 28 November 2025. Content is available under Datsun 1200 Club.
