Australia-assembled Stanza (1978-1981 A10) is a version of the B110/B210/B310 suspension ... so the parts fit with only small modifications. This is a popular swap in Australia, due to the beefy Girlock calipers fitted for the local market.
Japan-built A10 (510/Stanza/Violet) has the same rotor size as large B310, but with smaller calipers. See B310 swap (B310 and A10 use the same parts).
* No brake booster is needed
For more information on struts swaps, including other choices, see main article: Strut swaps.
A10 Strut Swap is very similar to the B310 Strut Swap, main differences:
- No machining needed for B310 strut with 245 mm brakes. With A10, you reportedly need to cut the strut shorter. Otherwise there will only be 2" of suspension travel
- A10 has same 245mm (9.6") rotors but with (Aussie versions of A10, at least) Girlock calipers which use much bigger pads than the B310.
- Any of the calipers will bolt to the A10 or B310 struts
B310: 1979-1982 Sunny, 210, 140Y/150Y * NOT A12-power B310 Sunny
1200rallycar has this to say about the Stanza strut swap:
I installed stanza struts to give me 9.5" discs with huge pad area (single piston though) and also to permit putting wider wheels (14*5.5" maybe 6" can fit not sure) the struts are a straight swap if you use the following componentsuse the stanza struts and stub axle, 1200 springs and top-plate things, stanza lower control arms, 120y castor rods and 1200 tie rods. all ya gotta do is swap everything over and i think when you put the stanza struts in you reverse the sides they came from but its pretty obvious which one goes on which side when you go to put em on anyway. If you want a stiff front end too change over the oil in the stanza shockers to 20W-50 motor oil (ive done and it works a treat, no body roll) There is 250ml oil in these struts. I am quite happy with the brakes as theyll pull me up instantly without change to master and no booster used. As added bonus stanza struts installed like this give about 1 degree negative camber.
The stanza springs can be used in this install but would need to be cut down (legalities involved) and the holes where the strut mounts to the tower need to be bored and elongated out so you can use the stanza top plate, though these springs will be stiffer and its possible to lift the front of you car a little for more squat on launch.
There is two stanza struts one has a three bolt ball joint the other has a four bolt, you need the one with the four bolt, also there is notable diffrence between calipers, the four bolt has big girlocks, the three has small calipers similar to the 1200. (i think the change between struts occurs in 1980)
TIP: If you want a stiff front end, change over the oil in the Stanza shocks to 20W-50 motor oil (1200rallycar has done and it works a treat, no body roll) There is 250ml oil in these struts. I am quite happy with the brakes as theyll pull me up instantly without change to master and no booster used. As added bonus Stanza struts installed with the wider Stanza ball joints give about 1 degree negative camber.
You can also upgrade the brakes fitted to Stanza/B310 struts:
Stanza struts and 275mm rotor Commodore VL Turbo caliper
Rotor Sizes
Rotor Sizes (JDM Parts Catalog)Dia. (mm) | Part Number | Source |
212.5 | 40206-H1006 | B110, B210 with A12 1974, 1975 |
245 (SC20) | 40206-U5100 | A10 |
245 (SC20) | 40206-U6700 | B210 A14, B310 A14/A15, PB210 late |
Rotors: Rockauto lists same PNs for B310 and A10 $9.52 each Another source lists these: * Datsun 1600, 180B, 610 Sedan, SSS (9/1974 - 8/1978) * Stanza A10 (5/1978 - 6/1979) * Sunny A14, A15 (1979 - 1981) * Vanette C20 (10/1980 - 5/1981)
IMPORTANT
In Japan and USA, there is only a single A10 strut -- with four-bolt ball joint.
In Australia, there are two A10 strut/brake combos:
- one has a three-bolt ball-joint (pre-1980?)
- other has a four-bolt ball-joint (post-1980?)
You need the one with the four-bolt, also there is notable difference between calipers, the four-bolt has big Girlock calipers, the three has small calipers similar to the 1200. You want the one with the Girlocks.
Coil Springs & Strut Top
The strut tops are different, so use the B110 tops with the A10 struts.
Now the spring of the A10 strut is too long for the B110.
- Use the B110 coil spring (110 mm diameter), spring cup and strut top hat, and fit it to the A10 strut. If you lower the car more than an inch or two you will need to flare the fenders.
- Or, cut the A10 springs by 2'
Optional, for racing or lowering
- Remove the spring perch and use a weld-on Coilover Springs kit. You can lower the car more by getting the tires in closer to these small-diameter coils (using different offset wheels)
Coilovers also give you more room for wider tires, as well as more room to move the strut with adjustable camber/caster strut tops.
Remember that that the stock B110/B210/B310 spring rate is:
- 90 lb/in
- For road/race compromise, use 200 lb/in springs
- For road racing, using 250 lb/in springs
Shortening the Strut
If you wish to lower your 1200 more than 2" lower than stock, the Stanza strut tubes must be shortened.
See main article: Shortening struts
Strut Inserts
Use 240K gas inserts or other 2-inch Strut Inserts. Don’t forget you may need a spacer at the bottom of the strut tube to make it all line up, nice and tight. You can use a stack of large-diameter washers.
Balljoints and Lower Suspension
The spacing where the strut bolts to the steering arm is different from B110 spacing. So, use the A10 or B310 lower parts:
- steering arm (knuckle)
- LCA (same length as B110) for A10 is identical to 1976- 1200 ute
B310: 1979-1982 Sunny aka 'Datsun 210', 140Y or 150Y * not A12-power B310
Now the A10 uses the same strut-to-knuckle spacing, so you can use these parts:
- A10/B310 W50 steering arm (knuckle)
A10/B310 Ball-joint Offset
About 15-18mm difference.
The Ball-joint bolts on top of the Lower Control Arm. The steering arm (steering knuckle) fits on top of the ball joint via the taper post.
- Use the longer B310 ball-joint to gain negative camber. The downside is it pushes the tire to the outside, and wider tires will foul on the outer fenders.
The 310 ball joint uses a larger diameter taper. It wouldn't fit into the 110/210 steering arm. 310 steering arms, (As you know) have a greater bolt spacing than the B110/B210s do. So you couldn't use them without swapping the whole strut.
All Datsun/Nissan struts -- except B110 and B210 -- up to and including R31 Skyline and 280ZX struts will bolt to an A10/B310 steering arm. The A10/B310 lower control arm is same length as a 1200. So you can use the A10/B310 control arm with other. The A10/B310 ball joint is needed to fit the steering arm, and this will make wider track (resulting in about 1 degree negative camber).
Tension Rods
Use A10/B310/B120 lower control arm, and the B120 late caster rod
For more details, see Caster Rods.
Instructions
Parts Needed
Grab the whole front strut/brake assembly as well as the brake hoses and the brake bias controller unless you plan on using an adjustable unit. Also grab the brake master cylinder if it is a similar type to the B110.
Details
Use at your own risk. There is no guarantee these steps are complete.
- Remove strut
- Disassemble the coil and remove strut insert
- Cut the A10 spring cup from the strut tube
- Cut the tube to length
- Weld the B110 cup onto the A10 strut
- swap the springs and strut top from the B110 onto the A10 strut
- Put A10 strut on car. Put the A10 struts reverse of the sides they came from but its pretty obvious which one goes on which side when you go to put them on
- Check wheel alignment. Especially set the toe-in, it will have changed.
NOTE: This is from the JDM parts catalogs. It doesn't list the good Aussie Girlock 4-pot calipers and pads. Nor the USA B310 AN20 (twin-piston calipers) brakes
Model | A10 | B310 A14/A15 |
Rotor | 40206-U5100 | 40206-U6700 |
Hub | 40202-W5050 | 40202-W5050 |
Baffle Plate | 41151-22000 | 41151-22000 |
Caliper Assy | 41000-W5001 | 41000-W5001 |
Brake Pad (JDM) | 41060-U4026 Akebono S21B | 41060-A1126 Akebono S17A (S21B pads on some) |
Caliper Plate | 41025-22000 | 41025-22000 |
Knuckle Arm | 40052-W5000, 40052-W5060 | 40052-W5000, 40052-W5060 |
Ball Joint | 40160-W5000 | 40160-W5000 |
Rod Assy LH (RHD) | 48630-W5025 | 48630-W5025 |
Lower Arm (RH) | 54100-H8500, 54100-W5000 | 54100-H8500 |
Tension Rod RH | 54470-W5000 | 54470-W5000 |
Strut Assy | 54302-W7625 | 54302-H8527,54302-H8529 54302-H9025 54302-H9225 |
Ball joints: * H74 type recommended * W50 type A10 wide type
Click each photo for larger pic, details and maybe more information on A10 struts.
