Instruments and Controls
From Datsun 1200 Club
Category: Owner's Manual
<-- back to Owners manual
Instruments and Controls is a section in the Datsun 1200 owners manual.
1972 USA Owners manual
29372.jpg12   29378.jpg13
1974 B120 Owner's Manual (Page 06 ... 08)
* Seat Belt Warning System (North America models)
* Speedometer
* Tachometer (OPTIONAL sedan/coupe)
1972 USA Owners manual (Page 09 ... ):
Seat Belt Lamp, Tachometer and Speedometer
Water Temperature Gauge
1972 USA Owners manual (Page 10 ... ):
If the pointer stays on the "H" side for more than two minutes, stop the vehicle and let the engine cool down, keeping it at 1,000 to 1,500 rpm.
"H" is past the large middle range (way over to right-side — the H area).
Also see:
* Thermostat
* Temperature Gauge
WATER TEMPERATURE GAUGE
When the ignition switch is on, this gauge operates and the pointer indicates the coolant's temperature, For most types of driving, the pointer will hover about halfway. However, the engine will run satisfactorily when the pointer is at any position in the middle range. Continual stop-and-go driving or high-speed driving in warm weather, hill climbing, or towing another car may cause the gauge pointer to swing to the "H" side. If the pointer should remain on the "H" side for more than two minutes, stop the vehicle and let the engine cool down, keeping it at 1,000 to 1,500 rpm.
29370.jpgPage 10
Round-gauge dash
21620.jpgAlbum 21620 21619.jpgEarly style
Standard dash
1974 B120 Owner's Manual (Page 08 ... 08)
the pointer will hover about halfway...
08.jpgPage 8
Fuel Gauge
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
29370.jpgPage 10
FUEL GAUGE
When the ignition switch is "ON," the fuel gauge pointer indicates an approximate amount of fuel in the tank.
See also: Fuel Sender
Round-gauge dash
The fuel gauge is part of the Cluster Gauge
26218.jpgAlbum 26218
Standard dash
26046.jpgAlbum 26046
approximate amount of fuel...
FUEL GAUGE
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill. So check the fuel supply when the vehicles is reasonably level, either standing still or moving steadily.
08.jpgPage 8
Indicator/Warning Lights
See also: Wiring
Ignition Warning Light
CHG lamp
Glows red whenever the alternator is not supplying current
IGNITION WARNING LIGHT
With the ignition switch on, the ignition warning [CHG] light glows red whenever the alternator is not supplying current to the electrical system. After the engine starts, the light should go out, indicating that the alternator is operating properly.
The light may glow or flicker occasionally when the engine is idling, However, if the light remains on at normal driving speeds, the alternator and electrical system should be checked.
29370.jpgPage 10
Round-gauge dash
Standard dash: CHG ignition lamp is on far left
26046.jpgSTD Dash
After the engine starts, the light should go out...
08.jpgPage 8
06.jpgPage 6
Oil Pressure Warning Light
OIL lamp
Stop the engine immediately
OIL PRESSURE WARNING LIGHT
The oil pressure warning light will glow red, when ignition switch is on; if the light does not glow, the bulb or wiring is causing the trouble. The light will go out as soon as engine starts and the oil pressure reaches normal condition. If the engine oil pressure should below a safe operating limit, the light will glow. The light may flicker for a few seconds after a sudden stop, but this condition is not necessarily harmful to the engine.
However, if the light glows steadily at normal driving speeds, stop the engine immediately and have its lubrication system checked.
29370.jpgPage 10
Round-gauge lights
Standard dash lights: Oil is on far right
1974 B120 Owner's Manual (Page 09 ... 09)
warning light will glow red...
09.jpgPage 9
Headlight Beam Indicator Light
Blue BEAM lamp
The beam indicator glows whenever the high beams are being used
HEADLIGHT BEAM INDICATOR LIGHT
The headlights have two beams to meet varying night driving conditions.
The high beams give you better long-range visibility on dark roads in the suburbs.
With the headlights on, the beam indicator glows whenever the high beams are being used, and goes off when the low beams are selected.
29370.jpgPage 10
Round-gauge dash
Standard dash lights: BEAM is the blue light
1974 B120 Owner's Manual (Page 09 ... 098)
The high beams give you better long-range visibility on dark roads...
09.jpgPage 9
Brake System Warning Light
BRAKE lamp
1972 USA Owners manual (Page 11 ... ):
BRAKE SYSTEM WARNING LIGHT
If either half of the dual brake system fails, the brake warning light (BRAKE) glows when brakes are applied, You must stop the car immediately and if you can safely operate with two-wheel brakes, move your car at reduced speed to the nearest service station.
This warning light is also used as the parking brake warning light.
Before starting, if the warning light does not glow when the parking brake and ignition switch are on, have the electrical system checked.
29371.jpgPage 11
Round-gauge dash
Standard dash lights: On Deluxe models only. BRAKE is second from left
Turn Signal Indicator Lights
Flashing type indicators wink...
TURN SIGNAL INDICATOR LIGHT
Flashing type indicators wink simultaneously with the traffic indicators in the front both sides, and rear of the vehicle, with the ignition switch turned on.
29371.jpgPage 11
Round-gauge dash: to right and left of speedometer
174_67e7685d5a557.jpgSpeedometer
Standard dash lights: Winkers are to left and right of the speedometer dial
26046.jpgSTD Dash
wink simultaneously with the traffic indicators...
09.jpgPage 9
06.jpgPage 6
Switches
Also see: Wiring
Ignition Switch
Also see:
* Keys
* Locks
* Ignition Switch
ignition switch ... is integrated with the steering lock device
1974 Export B120 Owners manual
Page 09   Page 10
(Optional)
The key can be inserted or withdrawn only when the switch is in the "GARAGE" or "LOCK" position. In the "GARAGE" position, however, the steering is not locked.
(3-position)
The "ON" position allows you to turn on the ignition system as well as all the other electrical circuits.
No mention is made of what the OFF position is for. Presumably its use is the same as the "GARAGE" position.
Notice that the standard 3-position type does not have an "ACC" position.
22007.jpgAlbum 22007
5-position switch vs 4-position switch:
22011.jpgAlbum 22011
Note addition of ACC position, which power Radio & Rear Defroster
Portugal market:
22008.jpgAlbum 22008
Interruptor de ignićāo [Ignition switch]
Desligado [OFF]
Ligado    [ON]
Arranque  [START]
Light Switches
Also see: Lighting Switch
Light Switch
1972 USA Owners manual (Page 12 ... ):
When you pull the switch knob to the first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
At the second position, the parking lights are still on and the headlight beams are lit, then if you push the turn signal lever switch forward, the headlight high beams will be turned on ... Pull the lever toward you, and it will be changed over to low beam.
The key takeaway here is that:
  • Knob in the 1st Position, NO HEADLIGHTS for US models
  • Knob in the 1st Position, LOW BEAMS work for other countries, including Japan-market
1974 B120 Owner's Manual (Page 10 ... 11)
LIGHT SWITCH
The light switch clearance lights, parking lights, headlights, taillights, license plate light and instrument panel lights.
With the light switch knob pulled on, the following lights will be on.
1st position:
Clearance, parking, tail, license, instrument panel lights and then headlight low beams.
With the turn signal switch lever pulled up, the headlight low beams can be turned on.
2nd position:
Headlights and other lights
If you push the turn signal switch lever forward, the headlight high beams will be turned on.
(Australia only)
1974 B120 Owner's Manual (Page 11 ... )
INSTRUMENT PANEL LIGHT CONTROL (For Australia only)
The instrument panel light control is integral with light switch. The brightness of instrument panel lights can be adjusted by turn the light switch knob.
Turning the knob clockwise will darken the instrument panel lights.
Turn Signal Switch and High Beam Switch Lever
Hazard Warning Switch
Main: Hazards
1972 USA Owners manual (Page 13 ... ):
By pushing the tumbler switch, all the directional lights flash at the same time to warn other cars that some trouble happened in your car.
Wiper and Washer Switch
Main: Wipers
To operate the washer, turn clockwise and hold the knob for a moment, or until there is enough fluid on the glass to wash off the dirt. Do not operate the washer for more than thirty seconds continuously.
Horn
Main: Horn
Sound the horn by depressing a horn button on either side of the steering wheel
Parking Brake Lever
Main: Hand Brake
If the ignition switch is on when the parking brake lever is applied, the brake warning light will glow.
Heat Glass Switch
Heated rear (defrostable) window was Optional equipment.
The rear heat glass incorporates a printed heating element to prevent frosting or icing
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Instruments_and_Controls"
This page has been accessed 58,275 times. This page was last modified 04:40, 24 July 2025. Content is available under Datsun 1200 Club.
