1984 Nissan Competition Catalog
(Redirected from 1984)
Category: Nismo
ALL 1200-related pages from 1984 Nissan Competition Catalog (part number 99996-CAT84).
NISSAN COMPETITION PARTS
Proven names like Electromotive, Bob Sharp Racing, Tilton, Koni, Venolia and Iskenderian, backed by a complete line of non-USA [JDM] and competition parts from the factory make this the most comprehensive competition catalog ever.
Table of contents:
  • page  2     240Z, 260Z, 280Z, 280ZX
  • page 16     510, 610, 710, 200SX, Stanza
  • page 34     1200, B210, 210, 310/N10
                [sic, page 36]
  • page 48     620, 720 Truck
  • page 54     1600, 2000 Roadster
  • page 60     #Miscellaneous
1200 Parts
Block, Crank, Rod, Bearings, Piston & Camshaft
Cylinder Head, Valves and Lubrication
Cooling
Hitachi Twin Carb
The GX/SU induction system was a production line option on non-USA versions of the 1200 and B210. Requires use of GX cylinder head. The GX system can be adapted to virtually any A-series engine.
Mikuni/Solex Carburetors
This induction system requires the use of the GX or competition cylinder head. With appropriate jetting and venturi sizing this system can be applied to any modified A-series engine.
Fuel Pump & Components
  • Electric fuel pump
  • replacement filter
  • blanking plate
Pulleys and Electrical
Tachometer, Speedometer and Exhaust
29796.jpgAlbum 29796 29795.jpgAlbum 29795
Flywheel, Clutch and Transmission
16819.jpgAlbum 16819
Differential
Stabilizer and Shocks
  • F10 & N10/310 Final Drive Gears (To 7/81)
  • Wheel Studs & Nuts
  • Brakes
    • 99996-H7010 1200, F10 & 310/N10 DP11 BRAKE PAD SET
    • 99996-K7000 B210 & 210 DP11 BRAKE PAD SET
    • 44060-27720 BRAKE SHOE/FORE for 1200 and early B210
    • 44070-27720 BRAKE SHOE AFT for 1200 and early B210
    • 44060-A1270 BRAKE SHOE/FORE for late B210, 210, F10 & 310/N10
    • 44070-A1270 BRAKE SHOE/AFT for late B210, 210, F10 & 310/N10
    • 44100-H3320 5/8" WHEEL CYLINDER for 1200 and early B210
    • 44100-H3300 11/16" WHEEL CYLINDER for 1200 and early B210
    • 44100-H3100 13/16" WHEEL CYLINDER for 1200 and early B210
    • 44100-M7000 5/8" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-M4901 11/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-G2800 3/4" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-U9200 13/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-N4601 7/8" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-Q1100 15/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-A7610 1" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-A7611 1-1/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
  • 1200 Stabilizer Bars
    • 54611-H2300 20MM FRONT BAR
    • 54617-H2300 BUSHING FOR 54611-H2300 2 REQ.
    • 99996-H4301 QUICKOR 25MM FRONT BAR KIT
    • 99996-H4351 QUICKOR 19MM REAR BAR KIT
  • B210 Stabilizer Bars
    • 54611-22301 19MM FRONT BAR
    • 54617-22020 BUSHING FOR 54611-22301 2 REQ.
    • 99996-H4060 INSTALLATION KIT FOR 54611-22031
    • 54611-22030 23MM FRONT BAR
    • 54617-22030 BUSHING FOR 54611-22030 2 REQ.
    • 99996-H4060 INSTALLATION KIT FOR 54611-22030
  • 210 [Datsun B310] Stabilizer Bars
  • 310/N10 Stabilizer Bars
  • Koni Shock Absorbers
    • Front
    • Rear
    • 99996-1714N 1200/FRONT 2 REQ.
    • 99996-2359A 1200/REAR (COUPE ONLY) 2 REQ.
    • 99996-1912R B210/FRONT
    • 99996-2359A B210/REAR (COUPE ONLY)
    • 99996-2002P 210/FRONT
    • 99996-2378B 210/REAR (EXCEPT WAGON)
    • 99996-1130B 210/REAR (GAS)(EXCEPT WAGON)
    • 99996-2002T 210/FRONT (SPORT)
    • 99996-2378J 210/REAR (SPORT)(EXCEPT WAGON)
    • 99996-2005P F10 & 310/N10/FRONT
    • 99996-2205B F10 & 310/N10/REAR
Suspension and Fiberglass Parts
  • B210 GT4 Fiberglass Parts
  • 210 Fiberglass Parts
Miscellaneous
Mikuni Accessories
  • Mikuni/Solex Accessories
    • Main Jets
    • Air Jets (Countersunk Type)
    • Pilot Jets
    • Outer Venturi (40PHH)
    • Outer Venturi (44PHH)
    • Needle Valve ASSY
    • Velocity Stack
  • Mikuni/Solex Accessories [continued]
    • Jet Blocks
    • Main Bleed Pipe (Emulsion Tube)
Spark Plugs
  • Champion Spark Plugs
    • [various standard tip, gold tip or projected tip plugs]
  • Spark Plug Spacer
    • 99996-N6732 .096 SPARK PLUG SPACER
    • 99996-0N677 .135 SPARK PLUG SPACER
Special Tools
  • Special Tools
    • EG167-00000 UNI-SYN CARB ADJUSTMENT GAUGE
    • ST358-50000 BRAKE ADJUSTMENT TOOL
Literature
Competition198463.jpgLiterature
Labels
  • Nissan/Datsun Die-cuts & Labels
    • 99996-X1001 'DATSUN' BLACK (1.5" x 12")
    • 99996-X1002 'DATSUN' WHITE (1.5" x 12")
    • 99996-X1003 'NISSAN' BLACK (1.5" x 12")
    • 99996-X1004 'NISSAN' WHITE (1.5" x 12")
    • 99996-X1010 'DATSUN' BLACK (3.5" x 34")
    • 99996-X1011 'DATSUN' WHITE (3.5" x 34")
    • 99996-X1013 'NISSAN' BLACK (3.5" x 34")
    • 99996-X1014 'NISSAN' WHITE (3.5" x 34")
    • 99996-X2001 'DATSUN...WE ARE DRIVEN' BLACK
    • 99996-X2002 'DATSUN...WE ARE DRIVEN' WHITE
    • 25371-N3121 IGNITION CUT-OFF SWITCH LABEL (CIRCLE)
    • 25371-A7600 IGNITION CUT-OFF SWITCH LABEL (TRIANGLE)
25371-A7600, 25371-N3121
20963.jpgAlbum 20963
Wearing Apparel
  • Wearing Apparel
    • T-shirts
    • Tank Tops
    • Halter Top
    • Patches
Race Posters
Plus:
The catalog has posters for all kinds of Datsun-Nissan models. Here are the Sunny posters:
"Road Atlanta Datsun B 210 — C Sedan National Champion"
Don Devendorf's B210, 1974/75 C Sedan Champion
28292.jpgAlbum 28292 65f99996-P0010.jpg 65h99996-P0012.jpg 65i99996-P0013.jpg 65j99996-P0014.jpg 65l99996-P0017.jpg 65n99996-P0020.jpg 65p99996-P0024.jpg
Here are the non-Sunny posters
#99996-P0001 Datsun S30 Z-Power
#99996-P0002 Datsun 710
#99996-P0004 Datsun 620
#99996-P0009 Datsun 610
#99996-P0011 Datsun 280Z
#99996-P0016 Datsun A10 (new 510)
#99996-P0019 Datsun S10 (new Silvia)
#99996-P0023 Datsun 280-ZX Turbo
#99996-P0025 Datsun 720
#99996-P0026 Datsun 620 Off-road Performance
#99996-P0022 Datsun S130 race car cutaway
65a99996-P0001.jpg 65b99996-P0002.jpg 65d99996-P0004.jpg 28329.jpgAlbum 28329 65g99996-P0011.jpg 65k99996-P0016.jpg 65m99996-P0019.jpg 65o99996-P0023.jpg 65q99996-P0025.jpg 65r99996-P0026.jpg 65s99996-P0022.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=1984_Nissan_Competition_Catalog"
This page has been accessed 68,216 times. This page was last modified 06:35, 11 January 2025. Content is available under Datsun 1200 Club.
