Flywheel
(Redirected from Flywheel Bolts)
Categories: Clutch | Engine Mechanical
Datsun 1200 uses a traditional type of flywheel at the back of the engine. The face matches the Clutch while a ring gear is attached to the perimeter to let the Starting Motor turn the engine. It uses a 271mm (10.7 inch) flywheel with a 105-tooth ring gear.
Also See:
* Clutch
* Crankshaft
* Automatic transmission flex plate
All flywheels for A-series engines interchange — for rear-wheel drive vehicles.
  • In 1974 flywheel bolts changed from British Threads to Metric threads. So the bolts are not interchangeable from early to late. See Crankshaft#Flywheel_Bolts for details.
  • The A12 flywheel weighs 2.2 lbs (1 kg) less than the A14/15 flywheels
  • A12 flywheel is thinner than A14/A15 and thicker than A10 — this affects the clutch functionality. See #Thickness
17232.jpgAlbum 17232
A10 12310-18001: 8.0 kg (17.6 pounds)
A12 12310-H1000: 9.5 kg (20.8 pounds)
A12 12310-H2310: 6.4 kg (14.1 pounds) GX, also sold as 'Race Option'
A14 12310-H7200: 10.7 kg (22.3 lbs)
15048.jpgAlbum 15048 3152.jpgAlbum 3152
A12 FLYWHEEL MEASUREMENTS
#Thickness: 28mm
ring gear + backing: 20mm
back rim to flywheel face depth: 5mm
clutch face to inner face depth: 17mm
starter ring gear
20430.jpgAlbum 20430
Thickness
A14/A15 flywheel is thicker than the A10/A12 flywheel. When fitting the thinner flywheel to A14, remove the Engine Plate to compensate.
Mixing/matching flywheels can affect clutch functionality. You may need to use a different size clutch release bearing sleeve, or change the engine plate.
A10: 25 mm thick?
* does not fit A12 due to different starter gear angle
A12: 28 mm thick (fits A10)
???: 30 mm thick (early A14? machined A14?)
A14: 35.6 mm thick (H89 flywheel)
A15: 35.6 mm thick (H89 flywheel)
A15/A14 flywheel
174_618a109adaffc.jpgPost 496146
30mm flywheel thickness
23641.jpgAlbum 23641
Inspection
If the starter occasionally makes grinding sounds, chances are the flywheel ring gear needs replacing (or just replace the whole flywheel, which is often less expensive).
Yes, you should resurface the flywheel if it is not in good shape!!! Better to not re-grind the flywheel if it doesn't need it.
It is not indicated to turn the flywheel UNLESS cracks appear, or it is not flat (worn unevenly), or the surface is burnt (heavy glazing). Guys will tell you "it is cheap insurance" to machine the flywheel clutch surface regardless, but that's not what the Datsun factory service manual says.
Wash ... in suitable cleaning solution to remove dirt and grease ... Check friction surface of flywheel and pressure plate for scoring or roughness. Slight roughness may be smoothed by using fine emery cloth. If surface is deeply scored or grooved, the part should be replaced.
- 1980 B310 service manual
If it is warped, have it resurfaced. It is it burnt, chattered, or is grooved, resurfacing is called for. But it if still worked great, is flat, and not burnt, don't bother. The Nissan factory service manual does not recommend a resurface unless needed. Every time my Datsun flywheel did not look great, I should have resurfaced it. And everytime it looked great and I didn't resurface it, all was fine.
If the teeth are worn, replace ring gear
23497.jpgAlbum 23497
Flange damage
24122.jpgAlbum 24122 24124.jpgAlbum 24124
Removal and Reinstallation
The crankshaft needs to be locked from turning when removing or tightening the flywheel bolts.
Flywheel Stop:
23604.jpgAlbum 23604
A less effective type of stop can be used in a pinch using a scrap of metal. The bolt will bend while bolting or unbolting the flywheel but no worries, just toss out the bolt when finished
23490.jpgAlbum 23490
Clean the #Bolt threads -- do not oil the threads -- and use a torque wrench to install.
TORQUE SPECS
Flywheel bolts 88 Nm (58-65 ft. lb.)
Installation - torque the bolts in a star pattern (tighten opposite bolts)
23498.jpgAlbum 23498
When installing the Clutch, use a spline-aligner so the transmission will be able to slide on
23560.jpgAlbum 23560
Lightening
For race cars, a light flywheel allows the engine to rev faster according to this principle:
The more weight, the more time it takes to accelerate
23496.jpgAlbum 23496 16998.jpgAlbum 16998
Now a street car wants a heavier flywheel, so that it will:
  • smooth out the combustion pulses
  • smooth out the drivetrain
19041.jpgAlbum 19041
These are the factory specs for flywheel weight reduction:
1014.jpgAlbum 1014 3913.jpgAlbum 3913
Finished wheight is about 6.5 kgs --a total of 2 kgs removal
Reference: Datsun B110 Competition Tune-Up Manual, Nissan Motor Co. Ltd., Tokyo Japan 1974
6209.jpgAlbum 6209
1280.jpgAlbum 1280 13202.jpgAlbum 13202 13203.jpgAlbum 13203 13308.jpgAlbum 13308 11151.jpgAlbum 11151 11152.jpgAlbum 11152 10428.jpgAlbum 10428 11108.jpgAlbum 11108 5509.jpgAlbum 5509 5510.jpgAlbum 5510 5511.jpgAlbum 5511 5512.jpgAlbum 5512 6208.jpgAlbum 6208 6209.jpgAlbum 6209 7979.jpgAlbum 7979 8003.jpgAlbum 8003 3507.jpgAlbum 3507 3923.jpgAlbum 3923 5428.jpgAlbum 5428 5429.jpgAlbum 5429 5430.jpgAlbum 5430 2513.jpgAlbum 2513 1268.jpgAlbum 1268 1481.jpgAlbum 1481 1487.jpgAlbum 1487
Bolts
Nissan flywheel bolts are very strong. Just clean the threads and use a torque wrench to install.
THREAD TYPE
1966-1973 3/8" x 24 UNF
1973-2002 M10 x 1.25 (from 1973 July)
TORQUE SPECIFICATION 1973
6.5 to 7.5 kg-m (47 to 64 ft-lb)
Best practices:
  • Reusing the flywheel bolts is acceptable. Even new bolts will come loose due to shaking. Even #ARP bolts will snap!
  • Do not oil the bolts. Just clean them
  • Overtightening weakens them. Always use a torque wrench
  • Use stock Datsun flywheel bolts. If using aftermarket bolt, ensure they are 1) not too long and bottoming out 2) ensure the head face shoulder design is compatible 3) Use high strength steel like the factory bolts 4) Ensure head size does not interfere with the clutch plate
  • Loctite is not needed, even for high RPM use. Per Pitroad: "Pitroad tightens ... without applying screw locking agent."
  • Make sure the flywheel-to-flange surfaces are clean
    • Do not let oil or Loctite get between the two, or the bolts may loosen over time
    • Run your finger over the flange. Any burring or uneveness can cause the flywheel to vibrate and come loose over time
  • For 7000+ rpm use have the flywheel #doweled
  • To reduce vibrations, always re-balance the engine after changing rods or pistons or crank
High Strength Bolts
ARP does not make A-series flywheel bolts, though some use non-A-series ARP bolts. In any case the stock bolts are plenty strong.
That being said, Kameari has selected ARP bolts and packaged them for the A-series engine flywheel. Pitroad has verified these bolts and also sells them.
Pitroad Kameari-ARP flywheel bolts
28556.jpgAlbum 28556
TORQUE for extra-strength bolts
10.0kg-m
Pitroad: "Tightening torque 13.5kg-m Apply screw locking agent without applying oil to the screw part. However, Pitroad tightens with a tightening torque of 10.0 kg-m without applying screw locking agent."
亀有エンジンワークス
Kameari Engine Works 203-2802-6S
* Chrome molybdenum steel, 200,000 psi
* M10 x P1.25 x 23.4 six bolts
* Exterior Finish: Black Oxide
31111.jpgAlbum 31111
ARP 203-2802 Flywheel Bolts for Toyota 4AG ($44 2025)
* Socket Size: 1/2" 12pt
* UHL: 1.050"
* Thread Size: M10 x 1.25
* Eight bolts
31110.jpgAlbum 31110 31112.jpgAlbum 31112
Dowels for High RPM
For 7000+ rpm use, have the flywheel doweled and consider replacing the stock crankshaft pulley with a Harmonic Balancer
7372.jpgAlbum 7372
Some recommend Using Loctite threadlocker (red) on the bolts, though other racing shops say it is not necessary. If use, apply to the crank threads using a cotton swab instead of putting it on the bolts.
If using high RPM, look at getting the crank flange dowelled. The flywheel is actually clamped on the head of the bolt not on the shank of the bolt (there is side-to-side play), so three dowels 120° apart should do the job. The end of the crank is soft (unlike the crank journals) and easy to drill.
A10 Flywheel
A10 engine flywheel is lighter than A12 flywheel, so will not smooth out the power pulses as well.
On the other hand it has less mass, so aids acceleration. You can lighten the A12 flywheel (by machining) or use the already light A10 flywheel. Unfortunately the A10 flywheel requires machining to use with an A12 (details for machining below)
160 mm clutch area (vs 180mm for all other A-engines)
26653.jpgAlbum 26653 27233.jpgAlbum 27233
* Machine step out of the A10 surface
* Drill new holes for the larger clutch
* Use a longer Release Bearing Sleeve
  Some say you can shim it
See main forum discussion
If using the standard A10 clutch, the smaller clutch pressure plate is held on using M6x1.0 bolts which are prone to snapping. May be worth drilling and retapping to suit the M8x1.25 bolts like the rest of the A-series use, but the pressure plate may not have enough clearance around the head/seat area to fit regular M8x1.25, though socket head cap screws may be used as they have small heads. Using M6x1.0 socket head cap screws in the standard holes may be another alternative as they are a stronger material (grade 12.1, vs 8.8 or less for regular bolts)
Datsun B10 fixing clutch cover
08120-62010 BOLT M6 x 20 medium carbon steel
08913-23610 WASHER-lock
27234.jpgAlbum 27234
FWD
Front-wheel-drive flywheel from E10 Cherry/120A, F10 Cherry/F-II or N10 (310/Pulsar) is smaller diameter and the clutch fits down inside the FWD flywheel.
13801.jpgAlbum 13801 13802.jpgAlbum 13802 13803.jpgAlbum 13803
Interchangeability with Datsun 1200: none
26242.jpgAlbum 26242
20
* 12310-18001 ASS'Y-FLYWHEEL B10
* 12310-18002 ASS'Y-FLYWHEEL B10 (from E/# A10-87871)
* 12310-H1000 FLYWHEEL ASS'Y A12, A12S, A12A, A13S
* 12310-H6200 ASSY-FLYWHEEL A13
* 12310-H7200 FLYWHEEL ASS'Y A14 -7909
* 12310-H7201 FLYWHEEL ASS'Y A14 7910-8010
* 12310-H8900 FLYWHEEL ASS'Y V A14S, A15 8011-
* 12310-H8910 FLYWHEEL ASS'Y A14S, A15 8011-
26 & 27
BOLTS - See Flywheel Bolts
21
* 12312-18000 GEAR-ring, flywheel A10/A12/A14
* 12312-18010 GEAR-ring, flywheel A14S 8110-
22
* 12313-10600 DOWEL (3) all A-series A10-A15
9
BUSHING-pilot: see Pilot Bushing
The flywheel "Assembly" includes these parts:
* 12312 GEAR-ring, flywheel
* 12313 DOWEL-flywheel
RockAuto.com
ATP ZA543 Flywheel Ring Gear $22.79
* Outer Diameter=10.655"
* Inner Diameter 9.451"
* Pitch=10/12 Width=.400"
* Teeth=105
* Chamfer=FRONT #1231218000
VW Conversion
Fitting an A-series engine to a VW gearbox (dune buggy)
9259.jpgAlbum 9259 9260.jpgAlbum 9260
MT conversion
When adding a flywheel to an engine that was originally fitted to an automatic transmission:
  • Make sure that the thin spacer for the flex plate is off the crank
  • make sure that there is a Pilot Bushing in the crank
  • rotate flywheel until all 6 holes line up
9372.jpgAlbum 9372 11166.jpgAlbum 11166
Aluminum Flywheel
16767.jpgAlbum 16767 16768.jpgAlbum 16768 14582.jpgAlbum 14582
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Flywheel"
This page has been accessed 81,139 times. This page was last modified 17:35, 31 October 2025. Content is available under Datsun 1200 Club.
