Hitachi Twin Carb Air Cleaners
(Redirected from GX Air Cleaner)
Category: Hitachi Twin Carb
With an Hitachi Twin Carb (GX-style) engine a RHD car there is clearance aplenty to fit air cleaners. But on a LHD car fitting an air cleaner it a bit tricky because the brake and clutch cylinders are on the left side. But the Twin Hitachis are more easily fitted to LHD 1200 than a twin-Weber setup.
GX air cleaner service both of the twin carburetors
18250.jpgAlbum 18250
GX air cleaners are different from 510 SSS Twin Carb, and take a thinner filter element.
The GX cleaner has a long snout and was red. A12T cleaner was blue, and A14T has a six-sided oval shape.
#GX A12 - red
#Cherry A12T - round or oval with round inside
#PB110 L14T blue or red, single-hose air cleaner with Idle Compensator
#A12T B210 - blue
#A14T - 6-sided oval
Filter
Filter for the A12GX is shorter than the one for the PB110 GX
A-series 54mm tall 300mm long
L-series 60mm tall 323mm long
A-Series
All A-series twin-carb (GX, A12T, A14T) used the same filter element:
16546-H2300
Overall size 30cm x 15cm x 5.4cm
center hole 24cm x 9.3cm
29935.jpgAlbum 29935
L-Series
Datsun Sunny Excellent PB110 GX was fitted with a twin-carb L14 engine. The L-series engines (PB110,PB210) used same filter as 510 (from 1969) and 610/710 and Europe 910K SSS
Nissan 16546-22000 Element
Subaru 16546-22000 Element
Overall size 323mm x 151mm x 60mm
Center hole 264mm x92mm
29936.jpgAlbum 29936
Quinton Hazell QAF68
Unifilter UL324-60ST
Fram CA2710
Ryco A257
82145-4800
Fram LA-269V / CA-2710
* Bluebird SSS P510/K610 '70~
* Sunny Excellent GX PB110 '71~
* Violet 1600 SSS P710 '73~
29937.jpgAlbum 29937 29938.jpgAlbum 29938 29939.jpgAlbum 29939
GX
GX cleaner was red, and had a single small hose connection -- for the crankcase breather.
normal
1972 option ducted
13428.jpgAlbum 13428 29940.jpgparts
29942.jpgAlbum 29942 29943.jpgAlbum 29943 29944.jpgAlbum 29944
29948.jpgAlbum 29948 29950.jpgAlbum 29950 29951.jpgAlbum 29951 29949.jpgAlbum 29949
Red - A12GX
29946.jpgAlbum 29946 29947.jpgAlbum 29947
With bottom vent hole (custom?)
29945.jpgAlbum 29945
custom-painted black air cleaner
26744.jpgAlbum 26744
29941.jpgAlbum 29941 18247.jpgAlbum 18247
A12T
B210 A12T cleaner was blue (early ones may have been red). It differs from the GX cleaner by having several small hose connections.
* inner EVAP lines
* Idle Compensator
* Larger IMS hose
Blue - A12T
A12T_air_cleaner_stack.jpg A12T_air_cleaner_fitting.jpg A12T_air_cleaner.jpg
Hot air OPTION
A14T
The A14T air cleaner has triangular bolt-pattern on the carburetor side.
A14T parts
15675.jpgAlbum 15675
Tell-tale six-sided shape
13673.jpgAlbum 13673 13674.jpgAlbum 13674 13675.jpgAlbum 13675
This one is custom-painted red, and with a custom dual-solex bottom
PB110
B110 L14 engine Sunny Excellent 1400 had a single-hose air cleaner. It also uses an Idle Compensator.
Early style: 16500-H2700 up to '71-9
7714.jpgAlbum 7714
Early? Painted red.
Late Style 16500-H2710 from '71-10 (kidney-bean shape) see blog
3375.jpgAlbum 3375 174_65af59a396c41.jpgPost 498207 174_65af5988a0a40.jpgPost 498207 30945.jpgAlbum 30945
30947.jpgAlbum 30947 30946.jpgAlbum 30946
PB210
Sunny Excellent 1400 B210 used the kidney-bean shaped air cleaner with no hot air option.
16500-H6003 Cleaner
16500-H6004 from '73-9
16500-H6005 from '74-12
16500-H6006 from '75-8
Air Horns
Stock GX air cleaner utilizes air horns built into the air cleaner.
Air Horns, taken from air cleaner, can be used on their own
13044.jpgAlbum 13044 14078.jpgAlbum 14078
Long horns
8102.jpgAlbum 8102 18076.jpgAlbum 18076
Custom Air Cleaner
229.jpgAlbum 229
1565.jpgAlbum 1565 1567.jpgAlbum 1567 1568.jpgAlbum 1568
Datsfullysik
Datsfullysik created this nice air cleaner from modern parts.
* Valvoline VA61 air filter
* TFI air filter adapter
* bracket (could use plumbers strapping)
* hose and clampes
12635.jpgAlbum click to view 12636.jpgAlbum click to view 12637.jpgAlbum click to view 12682.jpgAlbum click to view 12683.jpgAlbum click to view 12684.jpgAlbum click to view 12694.jpgAlbum click to view 12695.jpgAlbum click to view 12696.jpgAlbum click to view
Cherry
E10 Cherry X-1 models carried the A12T Hitachi Twin Carb engine (2-dr, 4-dr, and coupe).
Twin round air cleaners come from the Nissan Cherry A12T engine.
18253.jpgAlbum 18253 18929.jpgAlbum 18929 18930.jpgAlbum 18930 18931.jpgAlbum 18931
Nissan Cherry as also fitted with twin-carb optional single air cleaner. Inside the housing fit two round filter elements. You can see two round sections on top and a slanted section giving it a kidney-bean shape.
16500-M0810
20805.jpgAlbum 20805 20806.jpgAlbum 20806
4522.jpgAlbum 4522
16500-M0303 Cleaner-front
16500-M0804 from '73-9
16500-M0808 Cleaner-rear
Hot Air OPTION from 1973 - single housing
16500-M0810 Cleaner (op.)
16500-M0830 from '73-3
* Has twin round sections
16546-M0800 Element [round]
16546-M0810 Element [round, for single cleaner]
Cherry air cleaners can be used in the B110 (see blog)
619.jpg 776.jpg 954.jpg 955.jpg 960.jpg 1002.jpg 1003.jpg 1488.jpg 1503.jpg 1504.jpg 1509.jpg 1510.jpg 1512.jpg 1517.jpg 1519.jpg 1973.jpg 2804.jpg 2805.jpg 2806.jpg 2845.jpg 2846.jpg 2892.jpg 3168.jpg 3171.jpg 3384.jpg 3360.jpg 3375.jpg 3682.jpg 5007.jpg 6297.jpg 6442.jpg 6489.jpg 6493.jpg 6727.jpg 7000.jpg 8091.jpg 8125.jpg 8126.jpg 8355.jpg 8362.jpg 9257.jpg 9258.jpg 9589.jpg 9725.jpg 9858.jpg 11789.jpg 13044.jpg 13363.jpg 13428.jpg 13673.jpg 13674.jpg 13675.jpg 13882.jpg 13957.jpg 14757.jpg 14758.jpg 14760.jpg 14856.jpg 14956.jpg 14957.jpg 16059.jpg 15118.jpg 15236.jpg 15425.jpg 15729.jpg 15777.jpg 15778.jpg 15864.jpg 16060.jpg 16571.jpg 17046.jpg 17253.jpg 18076.jpg 18060.jpg 18250.jpg 18755.jpg 18756.jpg 18757.jpg 18759.jpg 18936.jpg 19100.jpg 19233.jpg 21289.jpg 21290.jpg 21291.jpg 21533.jpg 21534.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Hitachi_Twin_Carb_Air_Cleaners"
This page has been accessed 47,874 times. This page was last modified 00:30, 14 October 2025. Content is available under Datsun 1200 Club.
