Aftermarket wheels to suit Datsun 1200 come in a never-ending variety of sizes and shapes.
* Rims A-M * Rims N-Z
Ox
Ox Wheels 651 17x7 +40 (use with large spacer)
Peformance
* Challenger * Lotus * Spitfire * Spyker * Superlite
Racing Forg
Ray's
Also see: #Volk Racing
57V gram lights
57V compare to Williams F1 (upper right)
Rebel
Riken
River Side
Japan's River Side wheel aka Riverside
R101 4-point single star; double 4-point is R109 (or Colin Star Shark)
Revolution
Revolution wheel since 1967. http://www.revolutionwheels.com
ROH
Astron, Contessa, Reflex, Wildfire, and more classics.
Rota
Phillipine Aluminum Wheels Inc.
Rota RB - See Minilite#Rota
Rota Aleica
Rota Grid Concave
Rota Shakotan (similar to Hayashi #Street)
Shakotan 15x8+0: article
Zero Plus (similar to WORK#Equip 01
Simmons
See main article: Simmons
Southern Ways
Cross, Glids waffle-style, Glids II mesh-style, Wars, Strobo
1979 advert "True 3-piece wheel"
Glids II
Glids II mesh-type wheels are best identified by a cast S W on the back of the wheel. It can also be identified by the three "digits" in between the four lug holes. By contrast, Speed Star Mesh has a diamond between each lug hole.
- Fingers between the lug holes (not diamonds)
- The rim bolts are between the spokes (not at the spoke tips)
Glids II were made in Japan by Southern Ways. In the USA, Epsilon Wheel Corporation of Los Angeles (Mori Corporation) marketed the wheels.
Spalding
1981-1984 Message-II -- 1981 Wheel Of The Year
Speed Star
See main article: Speed Star Wheel
Speedline
Speedy
Starcorp
Superlite
Made in Britain http://www.superlite-wheels.com
Topy
Topy Jovite - see Speed_Star_Wheel#Mark_III
Topy JMW Crosspider RC-101 - see WORK#Equip_01_clones
Topy JMW Crossline AD-SCX (1979)
TSW
TSW 15" with Yokohama 195-45-15
Ultra
Volk Racing
Volk Racing Wheel by Rays Engineering
racing Mesh with octagonal center
VTO
VTO is a retro-wheel manufacturer out of USA. They export their classic-design wheels all over the world.
VTO BRE Libre-style
VTO Classic 8
Watanabe
RS Watanabe
Weld
The ultimate American drag racing wheel
Greg Weld "Prolite" (now Race Star Industries http://www.racestarindustries.com)
Western
Superlite - see Minilite#Western
Work
Equip 01, Equip 03, Ewing
XXR
521
Unknown
similar to GE Sigma SE but with vented center Datsun 1200 uses a common wheel bolt-pattern: 4 bolt holes on 4-1/2 inch circle (aka 4-on-4.5). Nissan engineers specified this in inches. In metric this is equivalent to a 4 x 114.3 PCD (Pitch Circle Diameter). Stock Datsun 1200 wheels are 12 inch diameter, 4J (4 inches wide). All models, even GX models and 1994 Sunny Truck models, used 12" wheels. Only the Datsun 1200 SSS used a special wheel, though still 12" diameter. Wheels up to 18x7 will fit under the stock bodywork.
Stock Wheels
- 12" diameter
- 4-inch wide
wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Datsun Option Wheels
Also see: B310_Options#Wheels
{{Album|23907}
40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13) 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
Also used on 200SX (S10 silvia) 1977-1979
Option B Wheel
Option C Wheel
B310 Wheels
ホイール
Sunny 1200 Race Wheels
Sports Options Catalog | Sports Options Parts
Race Road Wheel Parts 1 40300-H5021 ROAD WHEEL FR 8Kx14 inch 40300-H5020 ROAD WHEEL FR 9Kx14 inch 40397-N3120 SPACER-Safety Bolt (16) 40398-N3120 SEAL-Rubber (16) 2 40399-H50?? BOLT-Safety (16) 3 40209-A0220 SPACER-Road Wheel (4) for aluminum, t=5 4 40222-A0220 BOLT-Wheel FR (8) M12 x 1.25 x 50 5 40223-A0220 BOLT-Wheel RR (8) M12 x 1.25 x 50 6 40224-H5020 NUT-Wheel (16) (Taper) 7 40224-E7210 NUT-Wheel (16) (Taper) Chrome-plated cap nut
This is 4-spoke 14-inch. Aluminum alloy instead of the magnesium, size 8J and 9J.
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Also See: Vibration
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
- Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the Offset must be reduced from +30.
- Rear: +30 Offset works best with Datsun 1200, allowing the largest width tyres (205-width tyres).
Rear
Ute Rear
Weights
Stock Datsun 1200 Wheels (12 x 4) weigh 11 pounds each. Virtually all aftermarket alloy wheels are heavier, except for very expensive magnesium wheels.
See main article: Wheel Weights
Wheel Adapters
Wheel Spacers
See main article: Wheel Spacers
If the wheel offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
FWD Rims
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- 1979-1983 SAAB 900
Sigma Rims
Australia * Chrysler Sigma 1978-1980 * Mitsubishi Sigma from 1981
1977-1980 #GE Sigma SE 14x5.5 with 195/65R14
1982 GH #Sigma Turbo rims 15 x 6 inch
GE Sigma SE
- 1977-1980 Australia GE Sigma SE
- 1976-1979 Japan Galant Lamba
- 1978-1983 USA Plymouth Sapporo
Sigma Turbo
1982 GH Sigma Turbo rims 15 x 6 inch 4x114.3 (Sigma Turbo was a limited run on 500 cars)
Toyota
Celica
4-spoke Styled Steel Wheel * 1973-1983 Corolla [1] * 1974-1975A20 Celica![]()
A40 Celica 1978-1981
Corolla RWD
E30 1974-1979 E70 1979-1983
TE71 Levin pointie with slots
Supra
A60 Celica XX 1981-1986/Z10 Soarer
Nissan-Datsun Wheels
Bakkie Deluxe Wheels
B140 Champ with deluxe option wheels
Bakkie White-spoke Wheels
B140 Champ wheels (trail duster style aka white-spoke steels)
A-LINE "Spoke White" of the Steel Outback Range (8-spoke)
