Trim
Revision as of 03:45, 28 December 2017; view current revision
Category: Body
Datsun 1200 came in several trim levels from basic to sporty and on to luxury. Trim packages names vary by country, but include basic Standard (STD), better Semi-Deluxe (Semi-DX), Deluxe (DX) luxury GL (Grand Luxury) and sporty GX (Grand Luxury Twin-Carb).
Also see Interior
Japan-market trim levels for B110 (1200) and PB110 (1400)
743.jpgAlbum 743
In order of prestige:
basic     STD (Standard)
better    Semi-DX
normal    DX (Deluxe)
best van  Super-DX
luxurious GL (Grand Luxury)
sporty    GX (GL Twin Carb)
Model Availability
Coupe
* DX
* GL
* GX
4-door Sedan
* STD
* DX
* GL
* GX
Van Trim
* STD
* Semi-DX
* Deluxe
* Super-DX
Truck Trim
* STD (early models)
* Deluxe (option early models, plus all late models)
Standard
STD models were your poverty pack model. Like other stripper models it was the lowest cost.
* Dog dish Hubcaps instead of full wheel covers
* No heater
* Cigarette Lighter delete (plug for dash, no lighter)
* Radio delete (Blank Plate)
* Antenna delete (a-pillar plugs)
* Heater delete (Firewall and cylinder head plugs, different lower radiator hose)
* Air intake plate under dash (non-heater models)
* Package Tray cap (OPTION)
Standard trim was not available for Coupe.
Deluxe
DX trim is your basic model. Deluxe in the car industry usually means a basic model, not a luxury model, and the 1200 is no exception. DX (Deluxe / デラックス) was available on all Japan Market 1200 models including pickup. It was also the only available Trim level in USA.
DX models could be fitted with Options equipment.
Deluxe standard fitment included all features of STD, plus:
* DX Coupe is the lowest level Coupe trim, so it has no special badges
* DX Grille Badges -- none on Grille, just like STD
* DX Sedan boot lid
  22513.jpgAlbum click to view
* DX Sedan C-Pillar
  13484.jpgAlbum click to view
* Roof drip moulding rails (stainless)
* Body side moulding (stainless)
* Rear window chrome moulding
* Rear fender badge 'Sunny' (Sedan DX/GL)
* Gauges: Round in DX Coupe, Rectangular for DX Sedan
  * Rectangular cluster lids & cases differ STD vs DX
* Brakes: Disc for DX Coupe, Drum for DX Sedan
* Seats: Reclining on 2-dr & 4-dr Sedan (2-dr STD is only folding)
* Seat colors: Black STD, other colors DX
* Colors: Exterior color choices
* Colors: Interior color choices in addition to black
* Interior: Rear ashtray
* Hubcaps: Full covers
  6217.jpgAlbum click to view
* Hubcaps: Van DX (VP): dog dish (same as 4S STD, differs from 2S STD)
* Mirrors: Trapezoidal (same as GL)
  19958.jpgAlbum click to view
* Transmission: Optional automatic with sedan (not offered on STD sedan)
  3-speed or 4-speed available on DX Sedan.
* Engine: A12 (not A12GX)
* Heater: DX (optional on STD)
* Room Lamp
* Sun Visor assistant side DX/GL
* Package Tray
* Rear Tunnel Floor insulator
* Rear Floor insulator
* Rear Seat under floor insulator
* Carpet
* Rear wheel house cover (except 4D STD)
* Rear wheel house pad
* Seat riser trim (plastic cover between seat and door jamb)
* Side cover: front, rear and lower rear seat
* Finisher: A-pillar CLOTH & PAD
* Finisher: B-pillar CLOTH & PAD
* Finisher: C-pillar CLOTH & PAD
* Door Lamp Switch (for room lamp)
* Roof insulator
* Glass front windscreen/windshield chrome trim
* Horn, Low - DX Sedan. Coupe has GX-type Low Sports Horn
* Radio, speaker and antenna
* Speedometer with tripmeter from Jan 1971 (STD is w/o tripmeter)
  USA DX is without tripmeter. Glass differs.
* Cigarette Lighter
* Brake-hand control
* Brake master cylinder twin-cylinder type (drum brake Sedan DX)
* Brake master cylinder single-cylinder type Van DX
* Wheel is different somehow (perhaps missing the tabs for dog dish covers)
* Steering Column collapsible saftety type: USA DX (same as GL/GX, except LHD)
* Cowl Top Grille Sedan DX/GL
  2183.jpgAlbum click to view
* Parcel Shelf on 4DX
* 2nd rear ash tray
* Glass differs from STD somehow
* 2S DX rear side window hinge cover
* Trunk Lid Spacer
* Trunk Room Mat
* Special Door panels (Door Finisher) with enclosed pattern
  DX: 3836.jpgAlbum click to view
  STD: 11179.jpgAlbum click to view
* Arm Rest instead of door pull
Sedan DX
* B110 (4D) Sedan 4-dr DX
* B110T (4DT) Sedan 4-dr DX with 4-speed
* B110A (4DA) Sedan 4-dr DX with Automatic
* B110R (2D) Sedan 2-dr DX
* B110TR (2DT) Sedan 2-dr DX with 4-speed
* B110AR (2DA) Sedan 2-dr DX with Automatic
Coupe
Coupe base trim was DX, so it carried no special badging
* KB110 (CD)  2-dr Coupe
* KB110A (CDA) 2-dr Coupe Automatic
Coupe DX was similar to Sedan DX, except:
* Coupe DX had disc brakes
* Coupe DX had round-gauge instrument panel
* Coupe DX had no side vents (except for 1972)
This brochure shows that Coupes only came in the higher trim levels, that is to say, there was no STD coupe.
22517.jpgAlbum 22517 461.jpgAlbum 461
USA Deluxe
For USA, all 1200s are Deluxe.
* Coupes have no badges as usual with the base trim
* Sedans are Deluxe level, with higher specification than Japan-market Deluxe
  * fitted with the GL-spec disc brakes
  * fitted with the GL-spec round gauges
2682.jpgAlbum 2682
USA standard equipment (Deluxe)
* 4 CYL, OHV, 5 MAIN BEARING ENGINE
* SEAT BELT BUZZER [ALL] & LIGHT [1972-1973]
* PARKING LIGHTS
* 5 MPH FRONT END PROTECTION [1973]
* FOLD-DOWN REAR SEAT ON 1200 COUPE
* RECLINING FRONT SEATS
* WHITE SIDE WALL TIRES
* AUTOMATIC CHOKE [1972-1973]
STANDARD EQUIPMENT
* Fresh Air Heating & Defrosting System
* 2-Speed Electric Wipers
* Two Padded Sun Visors
* Safety Padded Dash
* Ignition Key Buzzer
* Steering Wheel Lock
* Impact Absorbing Steering Column
* Head Rests
* Seat & Shoulder Belts, Front
* Seat Belts, Rear
* Hand Brake Warning Light
* Engine Emission Control
* Safety Glass
* Safety Door Latches
* Side Marker Lights
* 4-Way Flash Lights
* Backup Lights
* Outside Rear View Mirror
ADDED FEATURES - NO COST
* Electric Windshield Washers
* Dual Horns
* Ash Tray(s)
* Cigarette Lighter
* Glove Box With Door
* Courtesy Lights
* Flow Through Fresh Air
* Fold Down Rear Seat on 1200 Coupe
* Full Flow Oil Filter
* Front Disc Brakes & Dual Master Cylinder
* Nissan Unibody All Steel Construction
* Tinted Glass (Not Available on 1200 Sedan)
* Full Wheel Covers
* Rubber Faced Bumper Guards
Options
* Radio
* Carpet
Van DX
The van (wagon) was offered in Semi-DX, Deluxe, and Super-DX.
* VB110 (VD) Super Deluxe
* VB110 (VDT) Super Deluxe with 4-speed
* VB110P (VP) Deluxe
* VB110PT (VPT) Deluxe with 4-speed
Truck DX
B120 (Deluxe) and B120T (Deluxe 4-speed)
Early deluxe features include:
* Whitewall tires
* Trapezoidal mirrors
* Radio & Antenna
* Chrome window moulding
* Chrome bumpers
* Chrome hubcaps
* Sunny side badges
All those features are missing from the B120S (Standard) model:
GL
GL グランド・ラクジアリ
GL Grand Luxury was offered on:
* Coupe
* 4-door Sedan
* 2-door Sedan GTR (1972 only)
Grand Luxury has all the features of DX, plus:
* Disc brakes
* Round gauages
* 3-spoke steering wheel
* Better seats (cloth and reclining/folding)
* Better interior with unique colors & fabrics
* Exhaust finisher (chrome tailpipe extension)
GX
16329.jpgAlbum 16329 17302.jpgAlbum 17302
GX グランド・ラクジアリー・シイン・キャブ
GX Grand Luxury Twin Carb
* 4-door Sedan
* Coupe
See: GX Brochures
Grand Luxury twin carb (GX) was the top of the line for Datsun 1200. All the options for GL trim were standard fitment on the GX. Both 4-door sedan and Coupe were offered in GX Trim. Automatic or 4-speed was offered. 5-speed was the GX5 (see separate section below). GX trim was offered only in Japan and in South Africa.
* Max Speed: 95 mph instead of 90 mph
* 0-400m: 16.7 sec
* GX Side Stripes
* Carpet and interior materials and color combinations
* Brown Dash
  5227.jpgAlbum click to view
* Bullet Mirrors
  10309.jpgAlbum click to view
* Unique Hubcaps
  DX-style but with dark gray centers instead of light gray
  8580.jpgAlbum click to view
* Steering wheel
  3158.jpgAlbum click to view
* A12 GX Engine 83PS with Twin Hitachi sidedrafts
  18247.jpgAlbum click to view
* Unique Badges
  5204.jpgAlbum click to view 964.jpgAlbum click to view 9930.jpgAlbum click to view
* Seats
  1972.jpgAlbum click to view 20665.jpgAlbum click to view
* Black-out Tail Panel
  coupe - center finisher
  21081.jpgAlbum 21081 174_4dcc8ff61d576.jpgPost 367825
  sedan (right and left "finisher" pieces -- not paint)
  750.jpgAlbum click to view 10097.jpgAlbum click to view 10097.jpgAlbum click to view
* 180 kp/h Speedometer
Colors
See Main Article: Japan Market Colors
Early GX
22557.jpgAlbum 22557
932 Sun-bright Red
    22557.jpgAlbum click to view
931 Sunflower Gold
    7480.jpgAlbum click to view
926 Sun-color Yellow
    26436.jpgAlbum click to view
924 Sun-ray White
    25661.jpgAlbum click to view
930 Sundew Green
    19277.jpgAlbum click to view
928 Sun-lit Gray (metallic)
    16329.jpgAlbum click to view
929 Sun-power Blue (metallic)
645 Sun-light Blue
GX Coupe
* GX Coupe has black-out Grille center rib
* GX Coupe has black-out rear panels
  21081.jpgAlbum 21081 174_4dcc8ff61d576.jpgUpload click to view
  79801-H2400 FINISHER-rear panel, center
  79802-H2400 FINISHER-rear panel side, upper RH
  79803-H2400 FINISHER-rear panel side, upper LH
  79804-H2400 FINISHER-rear panel side, lower RH
  79805-H2400 FINISHER-rear panel side, lower LH
  79202-H1826 1970 SET-ORNAMENT, REAR PANEL COUPE
  79202-H4025 1972 ORNAMENT SET-rear panel
GX Sedan
GX 4-dr was offered.
GX South Africa
South Africa GX used the 1972 Facelift parts, but with many several differences including hubcaps and interiors. Apparently this was the only country outside Japan that sold B110 GX cars. The GX5 was not sold in South Africa.
See Main Article: South Africa GX
GX Identification
The vast majority of "GX" 1200s for sale in the 21st century have been replicas/clones -- also known as fakes.
Look for:
  • build plate in Japanese script or Afrikaans
  • Build plate showing 83 PS
    19810.jpgAlbum 19810
  • Engine with twin-inlet Suction Pipe (small inlet is non-curved)
  • Chassis number which matches the build plate
GX-5
The GX-5 was a new model for 1972. It was a GX model fitted with a direct-fifth 5-speed Transmission, high-back seats and special GX-5 badges.
See Main Article: GX-5
1972
In Japan, a minor facelift was applied to all 1972 B110s, including a "power bulge" hood on Standard and Deluxe trims.
See Main Article: Facelift
