Colors
Revision as of 10:33, 28 October 2021; view current revision
Categories: Body | Paint
The Datsun 1200 was offered in a limited number of colors. Available colors varied by market. The same color number may have different names in different markets. The color number is printed on a small plate in the engine compartment on top of the radiator core support.
Color Number Tag
Color No. 006
16409.jpgAlbum 16409
Please look at your 1200's Colour ID tag, and if you are sure yours is an original car, add it here.
Over the years these numbers tend to get worn off, so don't be surprised if you cannot read yours.
Australian-assembled
Australian-assembled 1200 sedans have locally fitted ID & color plates.
For specific codes, see the #Australia_Market section below
23992.jpgAlbum 23992 19476.jpgAlbum 19476
Paint Types
The orginal 1200 paint was "amino alkyd enamel" (a type of synthetic enamel), which is tough, durable and sprays on shiny. It's a good choice. Enamel won't dull if waxed. All new cars have used enamel since the 1960s. The older type is acrylic lacquer and requires intial buffing and is not as durable as enamel, but can be layered and buffed for a superior shine.
Alkyd Enamel dries shiny, needs no buffing, but takes a little longer to dry than 2-pak Enamel. And is inexpensive. A lot of old guys recommend acrylic laquer for its superior deep shine, but that needs buffing and rubbing.
  • Single package coatings (1-pak) are less expensive and provide good results, but take longer to dry.
  • Two package coatings (2-pak) seal/harden/gloss the paint and dry quickly. Classic two package epoxies or polyurethanes fall into this category.
Newer cars use a base coat and clear-coat. The results can be better (or worse) than single-coat Acrylic Enamel.
1K: (single-pack) a coating that does not require a hardener, catalyst or activator. A "single-component" paints. Not the same as a "single stage" paint.
2K: (two-pack) an epoxy type coating that needs to be mixed with a hardener, catalyst or activator. A "two-component" paint, include Two Pack Acrylic Enamel, and urethane paints. 2K paint requires a full respirator to shoot, althought a mask is always recommended.
CLEAR COAT
  • Single-Stage: a coating that does not require a clear top coat. A single-stage coating may or may not require a catalyst, hardener or activator.
  • Two-Stage: a coating system that requires both base and clear coats. This is more commonly referred to as "basecoat/clearcoat" or "BC/CC". The coats of base and clear may or may not require a catalyst, hardener or activator.
  • A clear top coat even when not required may be added for enhanced durability or depth.
  • Easy to paint: Regular is easier than Metallic
  • Easy to maintain: Do not use lacquer paint. Use either Acrylic Enamel (as per original Datsun paint) -- or -- the newer 2-part expoxy paints with a clearcoat finish.
  • Safer to paint: Acrylic Enamel won't kill you, as can spraying epoxy paint without a full-mask.
Prices
A standard acrylic enamel non-metallic paint job (door closed) starts at $450 in USA to paint the entire car.
A typical budget paint job is more like $1500 USD which includes small amounts of minor bodywork.
A 'show car' metallic paint job starts at $5000 USD. But if you want to win the car show, $15,000 is not out of line.
Double these prices for Australia.
Engine Color
1971-1973 Datsun 1200 engines were painted "Datsun Turquois", a medium blue-green. The block and Rocker cover are painted the same color.
Earlier and later engines may be painted a different shade of blue such as "Nissan Blue", "Datsun Red" (e.g. Datsun 1000) or Black (late model A12s).
The 1200 air cleaner was painted a light blue.
6547.jpgAlbum click to view factory brochure
The air cleaner and its brackets is a light blue, about the same color as a new Kangaroo Bag.
Stock engine colors
6602.jpgAlbum click to view 606.jpgAlbum click to view 1492.jpgAlbum click to view
Nissan Blue (not an original 1200 color)
8115.jpgAlbum click to view 230.jpgAlbum click to view
One Datsun fan reported this for engine turquois:
Dupont mix guide          mix size
806J   HS BLACK            177.2
801J   HS WHITE            290.0
828J   HS FAST BLUE        373.8
830J   HS FAST GREEN       444.4
702OG  BINDER              844.0
7030G  BALANCER            960.4
Door Paint
Coupes came with black door window frames, while all other 1200s had color-matched frames.
738.jpgAlbum 738 737.jpgAlbum 737
Non-stock Coupe color-matched door window frame
26357.jpgAlbum 26357
Japan Market Colors
1970 Colors
B110 Colors at Introduction (JDM)
Source: Datsun Sunny 1200 Salesman Business Instructions, Page 23, Nissan 1970
1970 color sheet
26951.jpgAlbum 26951 1076.jpgAlbum 1076
#645 Sun-light Blue サンライト ブルー (coupe)
#924 Sun-ray White サンレイ ホワイト (sedan, coupe)
#926 Sun-color Yellow サンカラー イエロー (sedan, coupe)
#928 Sun-lit Gray (metallic) サンリット グレー(メタリック) (sedan, coupe)
#929 Sun-power Blue (metallic) サンパワー ブルー(メタリック) (sedan)
#930 Sundew Green サンヂュー グリーン (sedan, coupe)
#931 Sunflower Gold サンフラワー ゴールド (sedan, coupe)
#932 Sun-bright Red サンブライト レッド(sedan, coupe)
1970/1971 DX/GL color sheet
1077.jpgAlbum 1077
821 White
665 Sunkist Yellow
004? Sungrow Green?
931? Sunflower Gold?
005 Sunfast Blue
006 Orange
Seat material
G cloth (GL models)
D Black Vinyl (DX models)
K Yellow Vinyl (DX with green exterior)
1972 Colors
1972 JDM catalog lists the following color Cowl Top Grille vents.
Coupe:
930 Green 931 Gold 932 Red 821 White
665 Yellow 004 Metalic Green005 Turkois 117 Gray
Sedan GX:
665 Yellow 004 Metalic Green 005 Turkois 117 Gray
929 Blue 554 Light Green
B310 Colors
Source: Parts Catalog C-403
7910-8010
603 ワイン レッド wine red metallic
630 ページュ beige
663 シルベー silver metallic
715 ブルー blue metallic
804 イエロー yellow
805 ホワイト white
807 レッド red
810 ブラワン brown metallic
811 ゴールド gold metallic
815 ライト ブルー light blue metallic
816 グリーン green metallic
818 ライト グリーン light green metallic
8011-
663 same as above
804 same as above
805 same as above
807 same as above
817 ダーク ブラウン dark brown metallic
842 ブラウン brown metallic
924 ブルー blue metallic
926 ワイト レッド light red metallic
928 ページュ beige
Interior Trim Code
G 黒 Black
P 茶 light brown; tawny
Sunny Truck
1971 - 1978
Interior: D black
white or blue
1979 - 1989
Interior: C brown
B121 colors from Dec 1979 Catalog:
20841.jpgAlbum click to view
216 white ホウイト
18738.jpgAlbum click to view
688 blue (medium robin's egg) ブレー
18735.jpgAlbum click to view 10998.jpgAlbum click to view 2015.jpgAlbum click to view
617 beige ベージュ
All with brown interior, as all 1978-1988 pickups.
1989-
Source: Parts Catalog C415
Interior: K グレー gray
Body Color
#002 ホワイト White
1846.jpgAlbum click to view
#EH3 ダーク イエロー Dark Yellow
27046.jpgAlbum click to view
#544 ブルー Blue
#BG9 グレイニッシュ ブルー Greyish Blue metallic
July 1992 Brochure
Sunny Excellent 1400
These colors were offered for Excellent 1400 PB110 (model year unknown):
009 サンスポットオレンジ(メタリック) Sunspot Orange (metallic)
005 サンファーストブルー (メタリック) Sunfast Blue (metallic)
008 サンダウンパープル (メタリック) Sundown Purple (metallic)
004 サングロウグリーン (メタリック) Sunglow Green (metallic)
931 サンフラワーゴールド Sunflower Gold
821 サンシャインホワイト Sunshine White
930 サンデュグリーン Sundew Green
665 サンキストイエロー Sunkist Yellow
7723.jpgAlbum 7723
NOTE: color sheet appears to have faded somewhat. Source: composite of graphics from original Nissan brochure (year unknown).
#005 Sunfast Blue
26405.jpgAlbum click to view 26406.jpgAlbum click to view
?#008 Sundown Purple?
1716.jpgAlbum click to view
?#009 Sunspot Orange metallic?
11439.jpgAlbum 11439 sany-hanyu-101.jpg 458.jpgAlbum click to view
?#931 Sunflower Gold?
#821 Sunshine White
?#665 Sunkist Yellow?
#004 Sunglow Green
#930 Sundew Green
10316.jpgAlbum click to view 459.jpgAlbum 459
North American Market
Parts Catalog
In the United States and Canada, these are some of the colors offered (please add to the list if your car has a different number):
(source: List in catalog for touch-up paint)
#003 Dark Green
#006 Sunbird Orange
16409.jpgAlbum 16409 4003.jpgAlbum 4003
#554 Light Green
#567 Blue
#645 Blue
#665 Yellow [pale yellow, also used by Datsun Roadster]
22251.jpgAlbum 22251 7073.jpgAlbum 7073
#703 Green
#820 Red
#821 White
8462.jpgAlbum 8462 12222.jpgAlbum 12222 6553.jpgAlbum 6553
#931 Gold
#932 Red
20397.jpgAlbum 20397
(source: List in catalog for coupe cowl vent colors)
#924 White
#926 Yellow
#928 Gray (Gray rather than Grey is the spelling in the factory parts manual)
#930 Green
#940 Green
1971 Colors
Source: "Introduction of Datsun 1200 2-door Sedan Model LB110TRU"
Black interior except where noted
703 Green
820 Red (interior: Gray)
821 White
665 Yellow
567 Blue
645 Blue (interior: Gray)
554 Light Green
932 Red
1973 Colors
1973 USA colors at introduction
821 White, blue interior
665 Yellow, blue interior
567 Blue, blue interior (Sedan only)
645 Blue, blue interior
554 Light Green, blue interior (Sedan only)
932 Red, blue interior
931 Gold, blue interior
006 Orange, blue interior, optional yellow interior
003 Green, blue interior
940 Yellow Green, blue interior, optional yellow interior
Source: Service Bulletin No. 169 Introduction of Datsun 1200 1973 Model Year Nissan, 1972
B310
source: parts catalog
208 yellow -1279
216 white -1179
305 light blue metallic -1279
601 lime green metallic
603 red metallic
609 dark brown metallic -1279
630 beige
663 silver metallic
647 brown -1279
677 olive green metallic -1279
678 dark blue
804 yellow 1279-
805 white 1279-
807 red 1279-
809 sky blue 1279-
810 brown metallic 1279-
815 blue metallic 1279-
816 green metallic 1279-
824 brown 0879-
824 brown 1279-
905 red -1279
B110: See Paint Part Numbers touch-up paint
The USA B210 Parts Catalog lists these colors of touch-up paint
216 White
932 Red
905 Red
224 Yellow Green
931 Gold
940 Green
225 Blue
226 Dark Blue
352 Dark Blue
227 Orange
217 Yellow
109 Yellow
211 Dark Green metallic
212 Blue metallic
214 Brown metallic
1977 Colors (B210)
At introduction. Interior colors listed as Seat/door Headliner Carpet
019 Yellow (USA Honey Bee only), black beige black
211 Dark Green metallic, beige beige brown
212 Blue metallic, blue beige brown
214 Brown metallic, beige beige brown
216 White
224 Yellow Green
225 Blue
227 Orange
352 Dark Blue
905 Red
931 Gold
940 Green (USA only)
Source: Service Bulletin Vol. 258
Australia Market
Aussie-built 1200s have an Australia ID plate affixed in the usual spot:
P/Colour: 15465 [light green]
P/Colour: S-4253 [orange]
12330 Antarctia White 911
th_043-1.jpg MR 12QQ
13980 Kalahari Tan CLR312 CLR 312
12239.jpgAlbum click to view
Soramame Green 566-13176
8710_55245fbd5f717.jpgPost click for topic
Regatta Blue 10089
13643.jpgAlbum click to view
Mustard 13974
4099.jpgAlbum click to view
Australian-assembled 1200 were assembled in the Clayton factory (by Motor Producers Ltd.) and used Dulux acrylic lacquer paint. The same colors were used by Clayton-assembled VW and Volvo cars.
Dulon E-Type acrylic lacquer
Dulux Australia Limited
 [formerly: A BALM PAINTS PRODUCT]
Soromame Green 566-13176 (Avocado Green)
8710_54f8f2ea292b7.jpgPost 462968
Colour Code: CLR 722 [Riverina Orange, 1974]
DULON Acrylic Enamel
A product of Dupont Australia Limited
REFINISH WITH
SHANTUNG 566-13174 (beige or light reddish-brown)
8710_5cc5646560ce9.jpgPost 491271
local codes
02-U
Japan-built 1200s sold in Australia use the typical Japan paint codes, but have a localized name. For example:
821 Pale Grey
In Japan, color 821 is called "Sunshine White", while in USA color 821 is simply listed as "White"
Portugal
See main article: Datsun 1200 S1
black
New Zealand Market
Late Ute Colors:
Cream
White
Yellow
Red
Blue
385.jpgAlbum 385
Paint Chips
http://chipex.com - touch up paint kits
1200 pickup
660 Blue -74
003 Dark Green -73
EH3 Dark Yellow 93-96
940 Green -74
820 Red -74
006 Sunbird Orange -75
821 White -75
210/510
928 Cameo Beige 1981-1982
PPG paint chips, all Datsun colors for the specific year including 1200
Datsun 1971
502 Ivory
904 B879 White
903 14239 Blue Poly
920 23576 Gold Poly
931 23577 Mustard
901 32910 Light Gray Poly
907 44403 Green
240 44432 Green
918 60636 Orange
905 71899 Red
932 71917 Red
919 81908 Yellow
Datsun 1972
821 8889 White
018 8895 White
012 8935 Silver Poly
568 14274 Blue
072 14466 Blue Poly
115 14467 Blue Poly
103 14514 Bright Blue
170/562 19924 Turquoise (Asian Blue)
938 23615 Sahari Gold Poly
074 23749 Bronze Poly
114 23750 Bronze Poly
536 23756 Brown
125 23817 Beige
641 32941 Dark Gray
930 4483 Green
003 44485 Green
021 44679 Green
006 60647 Orange
Datsun 1973
Color Documentation
Also see:
* Category:Paint
* Black
* Blue
* Green
* Grey and Silver
* Pink and Red
* Yellow
004 Green
930 Green
554 Green
034 Green?
703 Green?
940 Green?
924 White
821 White
820 Red
932 Red
006 Orange
931 Gold
665 Yellow
925 Yellow
926 Yellow?
929 Blue
645 Blue
005 Turkois
567 blue?
blue
008 Purple?
928 Gray?
Black
Poo Brown
Poo Brown
Interior Color
Also see: Interior
Standard and Deluxe Vinyl
B - Black
USA Blue
K - Yellow/Beige
Australian-assembled Sedan
White
White
Blue
Red
Sunny Truck
1971-1978 black
1978-1989 brown
1989-2004 grey
PB110 Cloth
GX brown cloth
GL black stripe
GL black tricot
GL blue tricot
Color Codes
Where listed the paint formulas are for single-coat paints (not 2-pack or base/clearcoat).
Blue
#005 Turkois
#544 Blue
#567 Blue
#645 Dark Blue
#927 Sunshade blue
#688 Blue (medium robin's egg blue)
#929 Sun-power Blue (baby blue)
#BG9 Greyish Blue metallic
Gray
Green
#004 Sunglow Green metallic
#554 Sunglow Green metallic/Light Green/Kasumi Mint Green
#703 Green (mint green)
#930 Sundew Green (dark green)
#940 Yellow/Green
Red & Orange
#006 Orange
#820 Sunrise Red
#931 Sunflower Gold (mustard/yellow)
#932 Sun-bright Red
White
#002 White 1989
#216 White 1977-1980
#805 Alpine White 1979
#821 Sunshine White 1967-1973
#924 Sun-ray White 1970
Yellow & Beige
#617 Beige
#665 Sunkist Yellow
#926 Sun-color Yellow (light beige)
#EH3 Dark Yellow
002
1981-2002
Nissan 002 White
27045.jpgAlbum 27045 1846.jpgAlbum 1846
004
1971-1973
Nissan 004 Sunglow Green (metallic)
3998.jpgAlbum 3998
005
1971-1973 Sunfast Blue (metallic)
Nissan 005 サンファーストブルー (メタリック)
26405.jpgAlbum 26405 26406.jpgAlbum 26406
006
1971-1973
Nissan 006 Sunbird Orange
216
1973-1979 Polar White
Nissan 216 ホワイト
BASF Glasurit Line 22 formula (grams)
* M0    196.1
* M60   999.5
* A168   38.9
* A126   23.5
* M5     20.1
544
Nissan 544 Blue
1986-2002
BASF Glasurit Line 22 formula (grams) MS7664683
* M0     198.0
* M530   510.0
* M26    144.0
* M60    124.8
* M52     65.4
554
1969-1970 Sunglow Green (metallic)/Light Green/Kasumi Mint Green
Nissan 554 サングロウグリーン (メタリック)
11244.jpgAlbum 11244
617
1978-1979 beige (light shade of yellow/brown)
Nissan 617 ベージュ
* M0   196.9
* M5   451.7
* M60  409.4
* M26   69.8
* M6    34.9
645
1969-1973
Nissan 645 Dark Blue
8580.jpgAlbum 8580
665
Sunkist Yellow light yellow/beige (nearly white)
Nissan 665 サンキスト イエロー
1979-1972
RGB: 191,169,97
BASF Glasurit (grams)
* 352-91 174.6
* M25    892.2
* M105    57.7
* M146    25.4
* A974     7.4
7073.jpgAlbum 7073
364.jpgAlbum 364 363.jpgAlbum 363
688
1979-1992 Blue/Clear Blue/Light Blue
Nissan 688 ブレー
18735.jpgAlbum 18735
* M0    197.1
* M60   583.3
* M63   253.1
* A423   79.1
* M94    27.7
* A126   23.7
703
1968-1971 Green/Sunnyside Green
Nissan 703 Green
820
820 Sunrise Red
Nissan 820 サンライズレッド
27268.jpgbrochure
821
821 Sunshine White
Nissan 821 Sunshine White
#821
* USDM: White
*  JDM: Sunshine White
*  ADM: Pale Grey
1967-1970 Datsun B10
1970-1973 Datsun B110
8889   Ditzler PPG DITZCO DQE
31012L Lucite
31012D Dulux
4326   Sherwin Williams J5
Basics
* 531
* 361
* 582
* 365
2120.jpgAlbum 2120 8462.jpgAlbum 8462 12222.jpgAlbum 12222
925
925 Sunset Gray
Nissan 925 サンセットグレー
926
1970 Sedan, Coupe
Nissan 926 Sun-color Yellow
927
927 Sunshade Blue
927 サンシェイドブルー
21419.jpgbrochure
929
Nissan 929 Sunpower Blue (metallic)
5264.jpgAlbum 5264
930
1970-1973 Sundew Green/Dark Green
Nissan 930 サンデュグリーン
459.jpgAlbum 459 228.jpgAlbum 228 10316.jpgAlbum 10316
931
931 Sunflower Gold
Nissan 931 サンフラワーゴールド
197106-2.jpg 197106-1.jpg 18.jpgAlbum 18 1741.jpgAlbum 1741
932
1970-1973 Red/Bright Red
Nissan 932 Red
20397.jpgAlbum 20397 11310.jpgAlbum 11310
PPG Ditzler 71917
940
1970-1977
Nissan 940 Light Green/Yellow Green
225.jpgAlbum 225
BG9
Nissan BG9 Greyish Blue metallic
EH3
Dark Yellow
Nissan EH3 Dark Yellow
27046.jpgAlbum 27046
JDM B122 1989-1994
RGB: 115,83,33
* M0    197.0
* M5    457.7
* M60   333.8
* A168  102.2
* M974   47.5
How to Paint
See:
* Painting
