Seats
Revision as of 04:19, 26 August 2016; view current revision
Category: Interior
Datsun 1200s came with different types of seats, depending on the market. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Operation
Template:OwnersManual2
Sedan vs Coupe seats
sedan - fixed, with recliner OPTION
sedan GL, GX - x-pattern cloth
coupe - recliner, x-pattern cloth
truck - fixed, no recliner
Coupe Seats - sporty trim, but light with very little padding
Sedan Seats - flatter, with a bit more padding
5083.jpg 11972.jpg 19004.jpg Danish two-tone seat option
Late Sunny Truck
STD, Deluxe - vinyl, black or yellow
GL - fabric insert
GX - plaid fabric insert
B110 GX-5 - hi-back seat, black
KPB110 GX - hi-back seat OPTION with ovoid recliner control
* laterally-padded seats
KPB110 GL - laterally-padded seats
B210 - low-back seats with small headrest
KB210/KPB210 - hi-back seats with round recliner control
KPB210 GLL/GXL - low-back seats with small headrest
B120 1978-1989 hiback seats, BROWN
B120 1989-1994 hiback seats, Black with GREY inserts
Hiback seats - factory fitted to GX-5
full
Unknown High-back seats
GL seat
th_st1.jpg th_st2.jpg th_st3.jpg Headrests
Location
Front seat risers
A seat cross member
B inside seat bracket
C outside seat bracket
Also see: Coin Tray
Sunny Truck
Many B120 have a fixed (non-sliding) passengers side seat rail, but all 1200 rails interchange so you can replaced with an adjustable seat rail.
1971-1978 Black low-back seats
1978-1989 Brown hi-back seats
1989-1994 Gray hi-back seats
-7803 Early Datsun 1200 utes
* sedan seat bottom
* Truck unfinished back
* fixed (non-reclining)
* thin headrest
** 87700-G1001 Head Restaint Assy OPTION ALL(assist)
7803-8910 - Brown
* High-back seat (no external headrest)
8910- Gray
Coupe, Sedan seats fit in ute, no problem, even though they are a little thicker than truck seats
Catalytic Converter Seats
later seats have passenger side lower mount -- to clear the catalyst bulge in the floor.
1976-1978 B-210 pictured here (1989-up Sunny Truck is similar)
Stock Seats
13933.jpg Japan 11913.jpg USA Coupe 5083.jpg Stock Seats
USA models:
  • 1973 models had blue or beige seats. Black was available (again) on from 0173
  • 1971-1972 models:
    • Coupe: Black, Beige or (optional) Yellow
    • Sedan: Black, Yellow, Gray
  • Reclining seats standard on coupe
  • Sedan had folding non-reclining seats with (optional) reclining seats
  • Sedan had some sort of optional front seats
1555.jpg Standard, Deluxe and Reclining Seats
456.jpg GX Seats
620.jpg DX Seats
765.JPG Recovered Seats
Aussie-Market
STD
3537.jpg 1200 Coupe seats (custom fabric) in Datsun 1000
Ute
Australia-market B120 seats are not suitable for sedans as the back is not finished, but are extra thin compared to sedan seats with a slim-profile headrest.
th_IMG_0341.jpg th_IMG_0346.jpg th_IMG_0343.jpg th_IMG_0344.jpg th_tomita_akira_s15-img600x450-1352004442aujxg068643.jpg
Split-bench seat idea
th_ud_4771-img600x450-13084554571odvv046865.jpg th_ud_4771-img600x450-1308455540lyfjld47224.jpg th_ud_4771-img600x450-13084554565vjtmb46865.jpg
Bench Seat
120Y bakkie and 1400 bakkie (B140) came with a 3-passenger bench seat
16135.jpgAlbum 16135
7-passenger bench seating
19822.jpgAlbum 19822
Retrofit
ud_4771-img600x450-13084554571odvv046865.jpgPost click for topic ud_4771-img600x450-13084554565vjtmb46865.jpgPost click for topic ud_4771-img600x450-1308455540lyfjld47224.jpgPost click for topic
Mazda 1000 Bench seat which has been retrimmed
IMG_3211.jpgPost click for topic
Parts
  • 86982-A0600 Eyelet 'A' Seat Back $1.12
  • 86983-A0600 Eyelet 'B' Seat Back $0.85
  • 87550-H1603 Slide-seat LH $44.33
  • 87500-H1603 Slide-seat RH
  • 87400-M3000 Hinge-recline RH $179.58
  • 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
  • 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors sometimes called coin trays. These fit above the floor just to the outside of each seat.
  • 74961-H1100 TRIM-seat riser (R.H.) DX, GL
  • 74962-H1100 TRIM-seat riser (L.H.) DX, GL
TRIM-SEAT RISER, RH
  • 74961-H1100 7510-7803 BLACK
  • 74961-G1060 7804-8910 DARK BROWN
  • 74967-95W00 8910- GRAY
th_willieoec-img600x450-13273001390hi3qt29706.jpg th_willieoec-img600x450-1327300140dg42d729706.jpg th_willieoec-img600x450-1327300140wpvelu29706.jpg th_coina.jpg th_coinb.jpg th_coinc.jpg
TRIM-SEAT RISER, LH
  • 74962-G1000 -7803 BLACK
  • 74962-G1060 7804-8910 DARK BROWN
  • 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
  • 66919-H1001 -7803 BLACK
    • 66919-H1001 is superseded by 01553-00291 $0.80 USD
  • 66919-G1060 7804-8910 DARK BROWN
  • 96815-B0700 8910-
TRIM CLIP is also used by the Kick Panel and coupe rear interior panels
Datsun 1000 Seats
Headrests
See main article: Headrests
Upholstery
See Main Article : Upholstery
Custom Upholstery
18176.jpgAlbum 18176
stock seats with cloth inserts
7857.jpgAlbum 7857
Alternative Seats
Factory Bucket Seats
Subaru fits ute nicely
11773.jpgAlbum 11773
Mitsubishi FTO in ute
7814.jpgAlbum 7814
Mitsubishi Cordia
6860.jpgAlbum 6860
CRX
10480_4e916595ab8e4.jpgPost 384992
S14 seats
100_2644.jpgPost click for topic 100_2645.jpgPost click for topic
Speaker Seats
Mazda 121 Seats
4161.jpgAlbum 4161 3931.jpg 4047.jpg 4160.jpg 2885.jpgAlbum click to view
Corolla
1326.jpgAlbum 1326
Ford Laser
1731.jpgAlbum 1731
Prelude
1993.jpgAlbum 1993
Seat Covers
2386.jpgAlbum 2386
Daihatsu
2017.jpgAlbum 2017
EFI
4212.jpgAlbum 4212
Honda?
1785.jpgAlbum click to view
Baby Seat
1897.jpgAlbum 1897
Sport Seats
In-between cushy factory seats and full-racing seats are sport seats with supportive side-bolster. Easier to enter and exit, they also allow more motion than deep-buck racing seats.
Monza Seats
3820.jpgAlbum 3820 3577.jpgAlbum 3577
Buff's
2974.jpgAlbum 2974
Takami
3010.jpgAlbum 3010 3122.jpgAlbum 3122
Forza seats - The 1200 rails line up perfectly, although need to drill new holes for the rear bolts and fit a couple of spacers.
FDD62D5B-5A5B-48CF-8D00-54D78F2BB8DF-1144-0000019317004B0A_zps238027bd.jpg th_B1326A5E-25EF-4481-889E-82B32FB60C4F-4101-000004F4F190C7C6_zpsa0721fc8.jpg th_5DF9BC4F-29F9-4CFC-B91A-B873CE8BF042-4101-000004F504D4C2D0_zps5b6fc1b4.jpg
Recaro Seats
Recaro is the premium automobile seat company.
Recaro sport buckets
17774.jpgAlbum 17774 17327.jpgAlbum click to view 1203.jpgAlbum click to view 9623.jpg 13135.jpg 13952.jpg 13953.jpgAlbum click to view
Recaro racing shells
14206.jpgAlbum 14206 14207.jpgAlbum 14207 9205.jpgAlbum 9205 17242.jpgAlbum 17242
Vintage
South Yokohama - Cobra low-back classic
Revolution Racegear classic look (though not good for racing)
2630.jpgAlbum 2630 2617.jpgAlbum 2617
Racing Seats
Racing seats - shells - are thin and light. Support typically comes from a deep bucket design, which makes them more difficult to enter and exit.
Cobra
3792.jpgAlbum 3792 4067.jpgAlbum 4067
MOMO
236.jpgAlbum 236
Rally
553.gifAlbum 553 554.gifAlbum 554
SAAS deep bucket
2984.jpgAlbum 2984
Sparco deep buckets
3481.jpgAlbum 34818207.jpgAlbum 8207
OBX Daytona Buckets
4727.jpgAlbum 4727
Velo Seats
3862.jpgAlbum 3862
Seat Rails
See Main Article: Seat_Rails
Adapting Seats
NOTE: When bolting in seats, use high-strength bolts (10.8 spec), so that in a minor accident the bolts do not break.
Many, many seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Seat Adapting
5186.jpgAlbum 5186
Seat Slide
554.gifAlbum 554 573.gifAlbum 573 574.gifAlbum 574
Chassis Brackets - for flat seat runners
5085.jpgAlbum 5085
323 seats in 1200 coupe
9731.jpgAlbum 9731
17934.jpgAlbum 17934 17935.jpgAlbum 17935
22679.jpgAlbum 22679
Australia Legalities
Rear Seats
See Main Article: Rear Seat
See Also
* Seat Photo Index
