CA engine fitting
From Datsun 1200 Club
Categories: Engine Modifications | Engine Swaps | Nissan Engines
1046.jpgAlbum 1046
<- Back to CA-Series Engine Swaps
Choose a Transmission
Silvia 5-speed is type FS571C
1484.jpgAlbum 1484
  • CA16 uses a smaller clutch & gearbox. E16 & GA16 use a different bell, but same transmission series
  • CA18 & CA20 use a factory adapter plate & larger transmission
CA18DE
NOTE: RWD & FWD engine blocks are the same for the CA engine family.
You can use the typical CA18 gearbox, but it is longer than a Datsun 1200 gearbox, so the shifter comes up about 4 inches aft of normal.
See Stumpy for a 71-series gearbox that fits in Datsun 1200
See 71#Swap Notes for more details and options
POST feral: The CA18DE and DET's use 71B boxes. Very late DET's in S12's use the 71C box same as SR20's. Box type is easily identifiable from the number cast into the casing.
The main difference between 71B and 71C that has implications for front casing swaps is the bearing diameters and shift rail diameters.
In the 71C boxes the front bearings are bigger and the rails are larger as well.
910 5-Speed
Series 3 Bluebird (910) CA20E/CA20 5 Speed - This is a straight fit for a CA18DE, and for stock power applications is a cheap alternative. Especially if you can find a low milage example.
Gearbox crossmembers
See main article: 71-series Transmission#Crossmember
Speedometer
1163.jpgAlbum 1163
The 71-series gearbox speedometer drive works with the 1200 speedometer cable. If you need a longer cable, the Datsun 810 (200B) cable fits.
If the gearbox has an electronic sender for electronic speedometer, you can unbolt it and bolt in cable drive:
Cable drive (obtain from any 71C gearbox)
Silvia engines do not need the electronic speedometer signal. If it is installed, it can be used for overrun fuel-cut (increased fuel economy) plus the Silvia gauge cluster can be fitted to the 1200 dash.
See Main Article: Electronic Speedometer
Engine Fitting
Any motor mount that is made for the KA24DE motor can be used on the CA18DET. If using the Nismo mounts your motor may sit slightly higher than stock but it will fit.
20mm back of the head to the firewall
9571.jpgAlbum 9571 9570.jpgAlbum 9570
The radiator support does not need to be cut but is sometimes done to make engine hoisting easier
18394.jpgAlbum 18394 18392.jpgAlbum 18392
Flywheel
CA18/CA18DET uses a 6-bolt crankshaft. CA20 uses an 8-bolt crankshaft
See #Clutch & Flywheel
Engine Plate
rear engine plate or adapter plate
11251 PLATE-ENGINE,REAR
30411-W4401 MT <> 30411-W4403
* 910 8210-8310
* C31 8210-8412
* C32 8410-8412
* R30 8210-8412
* S12 8308-8412
30411-V5500 MT
* S13/RS13
* C22 8509-9106
* GC22 8605-
* C32 8412-
* C33
* R30 8412-
* R31
* R32
* S12 8412-
Sump
Front-sump oil pans from the Nissan S13 Silvia fit the stock 1200 engine bay crossmember location.
Possibly the Nissan factory winged sump may also fit.
21807.jpgAlbum 21807
Crossmember
Will 1200 crossmember modified for L-series work with CA18?
See Main Article: L/Z/KA/SR Crossmember
1200 crossmember modified for CA:
8710_4de740fe16338.jpgPost 370363 10107.jpgAlbum 10107 9572.jpgAlbum 9572 11869.jpgAlbum 11869 4695.jpgAlbum 4695 6861.jpgAlbum 6861 6862.jpgAlbum 6862 7749.jpgAlbum 7749 15429.jpgAlbum 15429
Insulator
9620.jpgAlbum 9620 4377.jpgAlbum click to view 4697.jpgAlbum 4697 13102.jpgAlbum 13102 13104.jpgAlbum 13104
Mad Dat Kit
Maddat CA crossmember for 1200 - Product No - FKCA1200 CA18/1200 Fitting Kit
441.jpgAlbum 441 174_5afcbfc398238.jpgPost 488322
Engine xmember has new platforms fitted & engine rubber mounts supplied. Gearbox xmember is a universal design that can be used with CA, R30 stumpy or Gazelle gearbox. For utes use the Stumpy R30 box with CA bellhousing fitted. For all fitments the standard gearbox mounts in the trans tunnel need to be removed and minor clearancing around the bellhousing is required. We recommend the fitment of our custom trans tunnel when doing this conversion, it allows much easier removal of the gearbox from under the car.
18304.jpgAlbum 18304 IMG00136.jpgPost click for topic
13637_4d3909ae1d440.jpgPost 354099 10290_4d8336d28d5fb.jpgPost 360401
Turbo
Also See: Turbo#Intercooler
913.JPGAlbum 913 2228.jpgAlbum 2228 7461.jpgAlbum 7461 7465.jpgAlbum 7465 7466.jpgAlbum 7466 7467.jpgAlbum 7467 9106.jpgAlbum 9106 9127.jpgAlbum 9127 9128.jpgAlbum 9128 9129.jpgAlbum 9129 10440.jpgAlbum 10440 17944.jpgAlbum 17944
Fuel Line, Pumps and Tank
745.jpgAlbum 745
Use high flow rated Bosch EFI pumps, Walbro pumps (watch out for the Ebay fakes).
10243_4a90b8273bcf9.jpgPost 272495 10243_4a90d00982f80.jpgPost 272506 10243_4a90d040aaf18.jpgPost 272506 10243_4a90d23845bb7.jpgPost 272508
Vacuum Diagram
10243_4a90d06900202.jpgPost 272506
See main article: EFI Wiring
Also see: POST ca18de/det wiring info & discussion
There's only a half dozen wires out of the S13 harness that need to be connected to the 1200 harness.
quote: The ignition wires are pulled out of the 1200 loom. The alternator loom is modified to suit the CA18's alternator. The CA18DE/T looms require start signal, ignition, 12V constant. That's it...
I like to wire up CA18's by starting with connectors and sensors that you are going to use. Don't wire what you aren't going to use!! eg. Aircon, Test Connectors, Wires going to the Dash, Automatic Transmission Computer, Climate Control etc. It's all hundreds of meters of useless wire. Label all of the things below with masking tape, and then pull all of the wrapping tape off the loom.
  • Crank Angle Sensor
  • Oxygen (02) Sensor
  • AFM [MAF]
  • Injectors
  • Coil Packs
  • Temperature
  • FICD
  • AAC
  • Knock Sensor
  • Boost Control
  • Power Valve
  • Alternator
  • Throttle Position Sensor
Rip out all of the connectors that are either taped up or go nowhere. For installation in a 1200. You'll need to cut about a metre out of engine bay to computer wires, measure twice and cut once.
I like to use all of the 1200 loom to supply the power to the CA loom. The CA Loom sorts itself out.
Alternator
See Main Article: EFI Wiring#Alternator
Ignitor
See main article: COP#Ignitor Module
MAF Sensor
Mass Air Flow (MAF) sensor on an S13 connects to the air cleaner.
Swap into 1200
MAF sensor
22680-58A10 JP.S13.CA18DET 4-pin
22680-61A01 ZA.CA18DET 200SX
22680-D6000 UK.CA18DET 200SX 3-pin
22680-58A10 S13
No MAF is needed if using an ECU that is capable of speed-density calculations (e.g. MegaSquirt). It can use either the MAF sensor, or it can do calculations based on MAP and TPS inputs and correct for temperature to calculate the air mass.
Preparing the Engine before Installation
For a second hand CA18det, these are some pre-install activities:
  • Get engine block water/oil galleries cleaned out professionally.
  • Get radiator professionally cleaned and pressure tested.
  • Remove MAFM and clean the hotwire on the Mass Air Flow Meter. Use carby cleaner and cotton bud.
  • Make sure MAFM is not clogged with oil from sitting upside down in a container.
  • Remove and clean out the idle control unit on side of plenum. Use Carby Cleaner.
  • Remove and clean the cold idle valve underneath throttlebody. Use Carby Cleaner
  • Remove and clean the CAM covers, soak them in Kero for 30-60mins to clean out the oil strainers.
  • Remove/Clean and reseal the cam cover rubber seals.
  • Check head bolt torque settings.
  • Remove and clean the Throttle body. Use Carby cleaner. Make sure that the shaft bearings aren't worn.
  • Clean out intake side crank breathers. They can be full of crystalline carbon crap, causing high rev oil retention in head.
  • Timing belt tensioner bearings. Can be ordered from Nissan (expensive) or can press the bearings out of holders and order bearings from Bearing supplier using the numbers on bearing oil seal. Then repress the bearings into the Nissan holders.
  • Front Camshaft lip seals ($15 for both), Half moon seals at back of cam covers ($20 for both).
  • Breather hoses on intake side can go hard and split, causing oil leaks. If they are hard, try to replace them with silicon hose, or landcruiser heater hose (but be prepared to replace them every 2 years).
  • Check water hoses used to heat plenum on front and back of plenum. Remove them if in above zero deg C climate.
  • Be sure to install the plenum rear plate gasket with the locating hole oriented to the top of the plenum. It will start leaking within a couple of days if the hole is on the bottom.
  • Check compression on all 4 cylinders (fuel/ignition disabled), should be within 10psi, and all over 170psi.
  • If one cylinder has less compression, remove plug, add a tablespoon of oil, and recheck, if it goes up, it's rings. Otherwise headgasket or scored bore.
  • Try to use factory waterpump, some aftermarket ones aren't real good. Mine had it's pulley/fan holes drilled off centre.
  • Always use Nissan thermostat. Cheap ones (Ryco) from K-mart aren't good enough.
  • Buy NGK platinums from Nissan at $18-20 each. They are fine up to 20 PSI boost, unless you have a bad tune which melts them...
Piping/Hose Connections
CA18/CA18DET
See:
* POST What goes where?
* POST The CA18DE & DET Q&A Thread
Heater Hoses
In the Silvia, the CA18DE hoses across the back of the head are the heater hoses (goes to the firewall and into the heater core). In a 1200 the hoses may be changed from this routing.
6978.jpgAlbum 6978
One heater hose loops back and connect to the rear side of block
The other connects to the heater pipe fastened along the side of the engine
174_5b3dfdd43ae97.jpgPost 488814
Heater outlet at rear of block (#1 in photo). The nipple may be double-outlet or single nipple. If a heater is not desired, cap the nipple (or remove and install a plug).
174_5b3e0173462c9.jpgPost 488814
Crankcase Ventilation
CA18 engines use a PCV system to control engine fumes. This may be replaced by an Oil Catch Can for racing purposes.
PCV Valve (screws into manifold plenum) and top breather hoses
174_5b3c7c1d83c05.jpgPost 488799
CA18DE block breather
174_5b3dedf52b940.jpgPost 488812
The CA18DE block breather nipple is just above the oil filter. The short length of hose to the pipe is missing in the photo
174_5b3df4b8ae06f.jpgPost 488813
The block breather connects to the left side cam cover
174_5b3df58d87875.jpgPost 488813
Upgrading the CA engine
Lighter block girdle
25212.jpgAlbum 25212
Injectors
Injector changes almost certain require a tune change, which needs either an aftermarket ECU, or a chip to be modified/burned and inserted into a modified factory ECU.
General recommendations for high powered CA18s require 440cc to 700c injectors to be used.
Stock injectors are yellow top OR green top (330cc vs 370 cc ???)
See Injectors
Add a second bank of injectors for drag racing
1717.jpgAlbum 1717
Turbo Choice
Sensible Street -> T28G, GT28 (s15 jdm), GT2810 -> GT2835. Drag Racing -> GT2840, Various large T3, HKS, Trust or GReddy offerrings.
Camshafts
Tomei offer: Hydraulic -> 256 deg to 270 deg duration at a nominal lift of 8.8mm Solid -> 264deg to 270 deg duration with 9.25 or 10.25 lift. Requires solid lifters and shims.
HKS: All discontinued, and no longer available new.
CAMSHAFT ASSY, INTAKE 13001/13020
13020-D4202 CA18DET
* U11,U12.(A+SSSAL.MT+K)
* S12
* T12, T12Y.CA18DT
13020-55W00 CA18D, CA18DT
* U12.SSSR
* T12Y.CA18D
13020-35F00 CA18DE, CA18DET
* S13, RS13
13020-1E000 CA18DET
* RS13
* U13
CAMSHAFT ASSY, EXHAUST 13020/13020M
13020-55W11 CAMSHAFT ASSY, EXHAUST CA18DE
* S13
* U12.(CA18D+CA18DET.SSSR)
* T12Y.CA18D
13020-D4211 CAMSHAFT ASSY, EXHAUST CA18DET
* S12, S13, RS13
* U11, U12.CA18DT.(SSSAL.MT+K.MT+AT)
* T12, T12Y.CA18DT
Lifters
CA18DE uses hydraulic bucket lifters
SR20DE uses valve rockers & rocker Pivots with shims over the valve stems
Hydraulic Camshafts use the stock hydraulic lifters.
14333_5378749a30dc5.jpgUpload click to view
13231-79S00 LIFTER-VALVE <> 13231-58S12 <> 13231-59S00
* CA18DE,CA18DET
* Z32.(VG30DE+VG30DETT)
* KN13.(CA16DE+CA18DE)
Solid Lifters are used with Solid Lifter Camshafts, and allow for higher lift cams to be used.
Requires:
* solid profile camshafts
* adjustable pullies
* solid lifters
* heavy duty springs
* shims, ground to fit
* head modified to clear the high-lift lobes clear
Commonly used Solid lifters (bucket-over-shim):
* Toyota 1ZZ
* Aftermarket for Nissan VG30DE/VG30DETT, RB, VG, VQ)
  Z32 Nissan 300ZX 0289-0896
  13231-79S00
* Tomei lifter kit $400 usd
B210 Swap Notes
The B210 is about 40mm wider than a B110, so crossmembers from Datsun 510/610/710 and A10/B310 fit -- more or less.
See slider@ratsun's build thread at Ratsun.net
  • You can use an S13 engine crossmember. It bolts right to the B210 chassis with minor slotting of the holes. Use the S13 front suspension too crossmember, arms, struts and brakes with 120Y springs. S13 swaybar does not fit with the width.
  • Crossmember had to be hammered in at the red circles in the picture to clear, and rearbolt-holes had to be moved 3mm each side.
  • NOTE: Track width is increased very much
  • 120Y castor arms used. Just drill one or two new holes in the control arms. Basicly bolt-on.
Differential
For information on choosing a rear axle, see Rear Axle Swaps. The Datsun 1200 ute assembly is recommended for stock-power CA18DET. More torque than that calls for stronger diffs.
Clutch & Flywheel
NOTE:
  • CA16 uses a smaller clutch than CA18
  • CA18/CA18DET uses a 6-bolt crankshaft. CA20 uses an 8-bolt crankshaft
24899.jpgAlbum 24899 18542.jpgAlbum 18542 16025.jpgAlbum 16025 16026.jpgAlbum 16026 16027.jpgAlbum 16027 3059.jpgAlbum 3059 3507.jpgAlbum 3507 14239.jpgAlbum 14239
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=CA_engine_fitting"
This page has been accessed 13,251 times. This page was last modified 08:48, 22 April 2019. Content is available under Datsun 1200 Club.
