Optional for the Datsun 1200 was a 8,000 RPM Kanto-Seiki tachometer. It was usually housed in the Deluxe instrument panel to the left of the Speedometer. It may also be placed in the optional floor Console.
See main article: Tachometer Wiring
PB110
Options
S1
Ute
SSS
B140
Location
Factory brochures show the tachometer in either dash or console.
Dash
Tacho in dash, blank plate in Console
Console
In Center
- 24855-H2300 1200 TACHOMETER 8000 RPM GX
- 24855-H1075 1200 FACTORY RACE TACHOMETER Calibrated to 10,000RPM with adjustable redline needle. Installation same as 24855-H1800.
- 24855-H3100 1972 B110 8000 RPM [Facelift] (Except GX)
620 Tachometer
Datsun 620 truck tachometer fits Datsun 1200 and looks very similar.
1972-1975 * 24840-B6400 KIT-TACHOMETER OP -0775 * 24054-B6400 ASSY-CABLE,TACHOMETER
1976-197824855-B8000 ASSY-TACHOMETER OP 0875-
The later Tachometer Wiring is different. It is a typical tap connection, instead of the Datsun 1200 'passthru' induction wiring.
Comparison
Early 1200 Tachometer has wiring loop:
Late 1200 Tachometer/620 Tachometer has no wiring loop:
These two types are wired completely different. See Tachometer Wiring.
Facelift
Aftermarket Tachometers
rev counter tacho tach rpm gauge タコメータ
