Optional for the Datsun 1200 was a 8,000 RPM Kanto-Seiki tachometer. It was usually housed in the Deluxe instrument panel to the left of the Speedometer. It may also be placed in the optional floor Console.
See main article: Tachometer Wiring
PB110
Options
S1
Ute
SSS
B140
Location
Factory brochures show the tachometer in either dash or console.
Dash
Tacho in dash, blank plate in Console
Console
In Center
24855-H1800 1200 TACHOMETER 8000 RPM![]()
24855-H2300 1200 TACHOMETER 8000 RPM GX
24855-H1075 1200 FACTORY RACE TACHOMETER Calibrated to 10,000RPM with adjustable redline needle. Installation same as 24855-H1800.![]()
24855-H3100 1972 B110 8000 RPM [Facelift] (Except GX)
24855-H3400 1972 B110 GX 8000 RPM [Facelift]![]()
620 Tachometer
The Datsun 620 truck tachometers fits Datsun 1200 and looks very similar. But USA models have 6500 rpm yellow line, 7000 rpm redline for L16/L18/L20B engine (1200 tach has 6400 rpm redline).
620 in Japan did not have a factory tachometer option.
1972-1975 early 620 USA * 24840-B6400 KIT-TACHOMETER OP -0775 * 24054-B6400 ASSY-CABLE,TACHOMETER![]()
1976-1978 late 620 USA * 24855-B8000 ASSY-TACHOMETER OP 0875- * tachometer wiring is built into every 1976-1978 620
The later Tachometer Wiring is different. It is a typical tap connection, instead of the Datsun 1200 'passthru' induction wiring.
Comparison
Early 1200 Tachometer has wiring loop:
Late 1200 Tachometer/620 Tachometer has no wiring loop:
These two types are wired completely different. See Tachometer Wiring.
Facelift
Mechanical Drive
Datsun Competition offered a mechanical tachometer.
See main article: Tach Drive
Aftermarket Tachometers
rev counter tacho tach rpm gauge タコメータ
