Weber 32/36 Carburetor
Revision as of 02:37, 11 November 2012; view current revision
Category: Fuel System
The Weber DGV series is a two-barrel progressive linkage downdraft carburetor. It runs on the smaller venturi for better economy and throttle response until the throttle is pushed down to about half way, at which point the larger throttle starts to open. At full throttle both side are wide open. Italian design. High fuel-economy. Excellent top-end power. Tunable. Available. Easy to work on. Did I mention inexpensive?
Also see: Choosing A Carburetor
The Weber DGV series is a 2-barrel carburetor from the Italian company of Weber. With all their racing and OEM experience, you know they know how to design carburetors. The 32/36 features progressive throttle design for good economy (with first bore open) and great power when both bores open). Being a down-draft carburetor it is easily adapatable to many stock engines, including Nissan A engines.
Features:
  • designed for engines displacing 1200cc-2300cc
  • versatility, can be applied to street or racing
  • wide adaptability to all kinds of engines
  • easy installation, a simple adapter and linkage is only need. Or a installation kit designed just for the A-engine can be purchased from a Weber distributor
  • low initial cost, either brand-new or used
  • trouble-free maintenance
  • excellent drivability due to many circuits (idle, off idle, power valve, etc)
  • increased fuel economy
  • improved performance
The DGV Series carbs feature models with manual, water or electric choke actuation. The DGV also has a power valve circuit to facilitate low vacuum (full throttle) conditions.
DGxV series name was generated from the Italian:
  • Doppio - twin
  • G - Right-hand oriented
  • V - Verticalle (verticle) or V (power valve-equipped)
x can be either: 1) none - manual choke 2) E - electric choke or 3) A - Aqua (water) choke
There is also a corresponding DFV-series, which are identical except they are a mirror-image of the DGV (for left-hand orientation). In the DFV, the primary and secondary barrel position reversed in the body. The throttle lever in the DFV rotates in a clockwise motion while the DGV rotates anti-clockwise.
Right-hand (DGV) vs. Left-hand (DFV)
Measurements
  • Bores: 32/36 (Primary bore/Secondary bore)
  • Venturis: different sizes
  • Bore spacing: 43mm
  • Stud spacing: 47mm x 93mm
Choosing between 32/36 and 38/38
For even more performance at a slight penalty in fuel economy see, the Weber DGAS carburetor synchronous opening model (both throttles open simultaneously). This is a high performance alternative to most any DGV applications.
Notice that both throttle are geared to open together
quote:
The 32/36 DGV progressive carburetor as used in any Redline Weber kit is pre-calibrated and set to run on most normal standard and stock engines and provide a performance and fuel economy improvement. If that engine has been upgraded or improved with other performance items there will be a need to recalibrate or rejet the carburetor in some situations. There is a performance jet kit just for the Jeep applications Pt No. 701-DGV.
The 38 DGAS synchronous carburetor when supplied in kit form from Redline Weber is also pre-calibrated for use on stock or slightly modified motors and will not be over carbureted. It also provides the best starting point for engines that are ultimately going to be upgraded with additional performance Items with performance over fuel economy being the ultimate goal.
For more details on choosing between DGV and DGAS series, see www.redlineweber.com
Weber DGV Models
They are available in different venturi sizes:
  •  ?? - 330 CFM
  • 26/27 - 26mm primary venturi: 270 CFM
  • 23/27 - 23mm primary venturi: 235 CFM (1979-82 Fords)
  • 23/29 - 1979-up Chevrolet Chevette
Curent Weber Part Numbers:
  • 22680-033B DGEV electric choke (E = electric)
  • 22680-051 DGAV water choke (A = aqua)
  • 22680-056 DFEV
  • 22680-070 DFAV
redlineweber.com
Weber 32/36 models
DGV manual choke
DGEV automatic (electric) choke
DGAV automatic (water heated) choke
DFEV/DFAV mirror-image to DGV series
Holley 180 Australian licensed version of Weber 32/36
Holley 5200 US licensed version of Weber 32/36
Holley G180/Holley 5200 Series
In 1970 the Holley carburetor company licensed the DGV design from Weber. Inside the carb it actually says "Weber", but outside there is a different brand name. Holley's first version was the Holley 5200, fitted to the 2-liter German Ford OHC ("Cologne") engine in the 1971 Ford Pinto.
5200 was used on:
  • All Ford 2.3 liter carbureted engines
  • USA models with 2.8 V6 carbureted engines
  • Ford Pinto/Mercury Bobcat 2.0 and 2.3
  • Mercury Capri German-made Capri circa 1974
  • Mustang II (1974-1978)
  • Fox-body Fords (1978-1986): Mustang/Capri, Fairmont/Zephyr, LTD/Marquis, Granada, Thunderbird
  • 1979-1982 Ford Courier pickup 2-liter engine (Isuzu truck)
The Holley 5210 variation was designed for the Chevrolet Vega 2.3 liter engine and first used in 1973. The main difference is a built-in GM-style fuel filter in the top casting.
5210 was used on
  • 1973-1977 Chevrolet Vega
  • 1977 Pontiac Astre
  • Pontiac "Iron Duke"
  • Chevette
  • 2-liter Audi engine (Porsche 924 engine) in the AMC Gremlin
5220 variation of 5210 was used on:
Chevette Carburetor:
In Australia, the G180 is a licensed version of the Weber 32/36 and fitted to:
All these Holley models are nearly identical. There are small differences between each model and between the Webers.
NOTE: Some Holley 5200/G180 carbs have only a primary idle system, while others have both primary and secondary idle system.
Go to the library and get this book: "Holley Carburetor Systems 5200 Series" by Mike Urich, HPBooks. Or just $8 from Amazon.com
Reference: "Holley 5200 Carburetor Handbook" by Mike Urich, HPBooks
Airflow, CFM
5200 series carbs are mostly fitted with 26mm primary and 27 mm secondary venturis, giving 270 CFM @ 3 inches mercury (note that this is equivalent to a 4-barrel type rating of 193 CFM -- 4-barrel carbs are rated at 1.5 inch mercury).
  • 270 CFM: 26/27 venturis (193 CFM equivalent to 4-bbl style rating)
  • 235 CFM: 23/27 (some, starting in 1978)
  • 245 CFM: 23/29 (1979 up Chevette)
The 245 CFM model sounds like a good candidate for a 1200cc engine as compared to the stock Hitachi carb's 20/26 venturis.
Holley carbs can be identified by a metal tag attached to a top screw, or by a stamping on the side of the carb base plate.
  • 1st number: Engineering/List number, as noted in some parts listings
  • 2nd number (if present): List revision
  • Last number: Date. First three digits are day of year (0=Jan 1, 356 =Dec 31), last digit is the year (0=1970, 9=1979)
Variations
Some 52xx carbs have:
  • External Fuel bowl vent. Most have internal venting. Some have emission style venting which is connected to a charcoal canister (you can connect it to the air cleaner -- inside the filter portion)
  • External Fuel bowl vent with solenoid control. As above, but you need to wire the solenoid to 12V. Failure to do so will cause running problems
  • Idle-cutoff solenoid (Anti-dieseling solenoid), identified by a wiring connector. You need to wire the solenoid to 12V. Failure to do so will cause failure to idle. The carb will run good except it won't idle. See Carburetor_Adjustment#Anti-dieseling_solenoid_valve
  • Fuel return fitting. A/C cars sometimes have this. Datsun 1200s do not have a fuel return line. Block this line.
  • Secondary idle system. Most 5200s only have a primary idle.
  • Screw-in vs Press-in idle circuit restrictors (don't worry about these, they are not normal tuning items). Some newer ones have a restriction in the circuit well (installed from carb top rather than on the side)
  • Mixture screw restrictor cap (idle limiter). Remove this unless local laws require them
  • Idle transfer circuit: holes vs narrow slot vs wide slot. The slots apparently are better, but you can't modify this so don't worry about it.
  • Double-venturi is used on some newer versions for better driveability and fuel economy. This is preferred unless you have a drag racer in which case the single-venturi is better (at about 7% better airflow).
Choke:
  • Water-heated
  • Water-heated with electric assist
  • Electric
  • Deceleration valve fitting. Some models have this just under the air cleaner flanged by the choke. Plug this fitting.
Holley 6500
The Holley 6200/6500 is a feedback version of the 5200 carburetor, an electronically controlled jet system. Early models used a vacuum switch while newer models used an O2 sensor (Lambda sensor).
Holley previously sold an electronic "dial a jet" package that would plug into the 6500, bypassing the oxygen sensor and letting you control the amount of fuel through a dial on the dashboard. This was the "Holley Electronic Carburetor" system with a 11-position controller module, that varied mixture about 12 jet sizes just by turning the dial. A "computer" was optional and monitored fuel economy and other factors.
reference: Aaron
The 6500 used a modified power valve assembly. Instead of a simple open/closed valve, this is a metred valve. It is controlled by a needle raised/lowered by a solenoid on the carb.
Components needed are:
  • Carb
  • Lambda (Oxygen) sensor (for 6510/6520 models)
  • Control box
  • Solenoid and Vacuum Control Valve
  • Wiring
The 6500 Vacuum Feedback model (no O2-sensor) was used on:
  • 1978-1980 Ford 2.3 liter California market
  • 1981-up Ford 2.3 liter USA Federal + California markets
The 65xx Electronic Feedback model (with O2-sensor) was used on:
  • 6510: 1980 Chevette, California market
  • 6510: 1981 Chevette, Federal + California markets
  • 6520: 1980 Dodge Omni/Plymouth Horizon, California market
  • 6520: 1981 Dodge Omni/Plymouth Horizon, Federal + California markets
Buying a Used Weber
Used Webers run around $50 for a bare carb to $200 for a pristine used kit.
If you buy a used one, unless it came from an A-series engine plan on making or buying the linkage and adapter.
Be sure the used DGV does not have this common defect:
  • Worn throttle shafts. Try to move the shaft side-to-side. It should not. If it moves even a little bit, pass on it. It will require drilling and rebushing to fix this
Progressive vs. Non-Progressive Carburetors
For a discussion of the progressive 32/36 vs. the synchronous 38/38, the IDF (Solex 40 style) and the DCOE racing series see Which Weber is right for me?.
The 38mm DGAS carb should be the only consideration if the engine is in the future or currently going to have any level of additional engine modification. Such as headers, free flowing exhaust, a cam, or rebuilt engine. Usually these motors will be improved over stock with oversize pistons and towing cam. The 38 will enhance the improvements of any of these items ... It will provide considerably more initial torque and acceleration but the top end performance will not be significantly improved over the 32/36 when used on a stock [4.2 liter] motor.
Note, that is better torque -- but not better throttle response. The 32/36 should be smoother than the 38/37 for a small street-going motor like the A14.
Electric Choke?
The DGV electric choke works great and hooks up the stock Datsun electric wire. Take the choke off and make sure the spring still has "springiness" to it. If not, replace it. To test it, the choke should just barely close the throttle in the coldest of mornings. After several minutes of running the engine, the spring should heat up and fully open the choke. If it's weak, just get a new one. The Holley chokes fits the Weber carb. Electric chokes come on the Chryslers and Chevrolet Chevette, so should be readily available from any parts store.
DGAV - Automatic choke, water heated DGEV - Electric choke DGV - manual choke
Does your 32/36 have a non-adjustable electric choke? Simply drill the face off the rivet, push them through and add screws (it's probably already threaded). Now you have an adjustable choke.
Fords and Vegas had a water heated choke which could be used instead of an electric choke.
The electric choke on the 1200 (1972 and up have electric choke) has power supplied from the ignition switch circuit. However, this is switch on/off by the choke relay from a signal put out by the alternator/regulator "N" wire. This means the choke only gets power when the ignition is ON and the alternator is putting out power (engine running). Other makers use an oil pressure switch for the same purpose. For a 1971 car, you could simply hook it up directly, the downside would be if you let the car sit with IGN on for a while before starting the choke would open up, even if it is cold outside, possibly preventing the engine from starting.
See: Wiring
Throttle linkage
If you have the money to spare, get a $400 Weber 32/36 kit for the A-series engine. It will looks professional and work great.
The Weber kit includes a bracket for the Factory Hitachi Lever, which bolt onto the Weber.
CAUTION: Do not overtighten
The Weber part looks like this:
click
click
On the other hand, if you want to save money, you can make your own linking.
  • Take the throttle wheel of the stock Datsun Hitachi carburetor, then fit it to the DGV throttle shaft. Create a mount for the cable.
  • ddgonzal used the stock Datsun throttle cable, but modified the Weber linkage which was for another type of engine and used some thin strap steel to make a bracket
This is by far the hardest part of fitting a DGV to your A engine.
Book and manuals
Where to buy?
Carbs
2976.jpg Kit
Parts Suppliers
Weber "Kit "
Kits run around $350-$400 USD and include:
New carb
adapter for your existing inlet manifold
air filter
throttle linkage
all necessary gaskets
You can get a kit for your specific application, or a generic one with "universal" throttle linkage and other parts.
Weber Kit K8624 - Datsun B110/B210 DGAV
Weber Kit K624 - Datsun B210/B310 DGEV
Pierce Manifolds $400
Alamo $380
Google Search
Adapters
You can make a DGV-compatible intake, buy an adapter plate, or make your own.
See Main Article: Weber DGV Adapters
Air Cleaners
You can buy one specially made for DGVs, or adapt the stock A12 cleaner to fit. Lots of companies sell chrome, alloy, round or rectangular filters
How to hook up the crankcase breather?
See discussion engine question?? in the main forum.
Carburetor Tuning
Tuning is a Must
If you buy a kit for your specific engine, it will run fairly good out of the box, but should still be tuned to match your engine. If you obtain one second-hand, count on swapping jets, emulsions tube and other tuning parts to make your engine run right. Black smoke, smelly exhaust, jerky acceleration and poor fuel economy is what you get before you tune it. It may "feel powerful", but you can make it run even better with some patience and the right parts.
See Main Article: Weber DGV Tuning
  • Tuning
  • Jetting
  • Adjustments
Fuel Pump Requirement
The 32/36 requires a low-pressure fuel feed (2.5 to 3 lbs). This matches the stock Datsun 1200 pump (2.6 lbs).
If using newer A14/A15 pumps which can go up to 3.6 lbs, or electric fuel pumps, a fuel pressure regulator is recommended. Excessive pressure can cause problems with the float, at the least cause erratic operation due to float spillage and at the worst causing flooding (gasoline overflowing the float chamber).
The flow rate (volume) of the pump depends on how much horsepower your engine puts out. Weber recommends their electric 6 gallon/hour pump for "up to 200 hp". That should satisfy any A12, even a full racing A12. Fortunately the stock B110 pump puts out approximately 6 gallons per hour so it should be sufficient for any A12 with 32/36 carburetor.
To be sure your pump meets the specifications, you may perform a Fuel pump pressure test.
591.jpg 798.jpg 589.jpg 1054.jpg 1232.jpg 1235.jpg 1329.jpg 1330.jpg 1362.jpg 1470.jpg 1521.jpg 1628.jpg 1630.jpg 1775.jpg 1776.jpg 2027.jpg 2030.jpg 2466.jpg 2763.jpg 2764.jpg 2765.jpg 2766.jpg 3421.jpg 3816.gif 4552.jpg 4764.jpg 4918.jpg 6329.jpg 6614.jpg 6704.jpg 6851.jpg 8120.jpg 9386.jpg 9609.jpg 10474.jpg 10656.jpg 10870.jpg 10872.jpg 12794.jpg 12796.jpg 12797.jpg 13319.jpg 13337.jpg 15241.jpg
28/36
Blower
Turbo
DCNF
Twin DGV
