Headers
Revision as of 20:55, 30 August 2016; view current revision
Categories: Exhaust System | Manifold
Extractors, headers — whatever you call them — are a more efficient "tubular" version of an Exhaust Manifold.
Unless you are racing, we recommend -- instead of headers -- the cast-iron 4-into-2-into-1 factory header is recommended. It's quieter, never wears out, and fits any 1200 perfectly. See GX Exhaust Manifold.
  • Some header do not allow the stock intake manifold to fit. You can grind the intake to fit
  • Some head hit the stock block breather pipe. Make a custom pipe.
  • Headers for 1200 fit all body styles: ute, wagon, coupe and sedan
  • Headers/extractors fit both ways (A12 fits A14 and vice versa). However because A14, A15 and early A13 are "tall" blocks the header is raised up 15mm. So A12 headers on A14 engine may hit the floor.
  • Headers for A-series engines bolt to any A-series engine. Exhaust port bolt pattern is identical for all A-series engines. port shape and size is identical within 1 or 2 mm
    20540.jpgAlbum 20540
  • Headers for a particular Datsun model may not fit another. For example, Vanette or B310 headers may or may not fit B110 due to the shape of the firewall and floor
  • Like any header they may need some tweaking of the flange, not because of the engine but because of poor manufacturing of the header
For the above reasons, the GX Exhaust Manifold is recommended.
Wrapping
Heat-wrapping can gain a bit of HP if the engine is retuned for it, at the cost of accelerated wear from either moisture rotting the header or from poor welds.
6947.jpgAlbum 6947
Suppliers
  • Yourself. If you know how to weld, You can make your one out of some steel tubing and a bit of 10mm plate for the flange
    See: Manifold
AUSTRALIA
South Yokohama equal length headers
23221.jpgAlbum 23221
New Zealand
  • Coby Manufacturing in Hamilton, NZ make 2 sets of different extractors to fit the A series motors
    Euclid Ave, Hamilton Phone: 0-7-849 1765
  • Autopia in Christchurch
Tri-Mil - Long Beach, California
376.jpgAlbum 376
Bill's Datsun Shoppe: Portland, Oregon
11524.jpgAlbum 11524 24108.jpgAlbum click to view 24110.jpgAlbum click to view 24109.jpgAlbum click to view
Nissan Competition
Nissan Sports Options Department tubular headers are a direct replacement for the cast iron GX manifold. They are superior to a "shorty" header in that these are a dual outlet type, and are collected together in the exhaust extension.
Sports Options Catalog
8270.jpgAlbum 8270 15269.jpgAlbum click to view shorty-1.jpg shorty-2.jpg shorty-3.jpg datsun72b110gx5-img599x439-1437643171c0hy6l20881.jpg datsun72b110gx5-img600x450-14376431711wvmb120881.jpg datsun72b110gx5-img600x532-1437643172xek47g20881.jpg
Nissan Competition 99996-H8000 B210/210 competition header 4 into 1 design with 1.375" primaries and 2.5" collector
Competition198442.jpg 24914.jpgAlbum click to view 24913.jpgAlbum click to view
Shorty Headers
Shorty header is designed to replace cast manifold. Easy packaging comes at the expense of a full length collector. The performance is lacking compare to a typical header.
shorty-1.jpg shorty-2.jpg shorty-3.jpg 16289_54c4981e8fa95.jpgPost 463202
80.JPGAlbum click to view 195.jpgAlbum click to view 375.jpgAlbum click to view 376.jpgAlbum click to view 506.jpgAlbum click to view 591.jpgAlbum click to view 606.jpgAlbum click to view 634.jpgAlbum click to view 799.jpgAlbum click to view 1087.jpgAlbum click to view 1248.jpgAlbum click to view 1467.jpgAlbum click to view 1565.jpgAlbum click to view 1782.jpgAlbum click to view 1786.jpgAlbum click to view 1943.jpgAlbum click to view 1955.jpgAlbum click to view 2395.jpgAlbum click to view 2466.jpgAlbum click to view 2547.jpgAlbum click to view 2645.jpgAlbum click to view 2748.jpgAlbum click to view 2982.jpgAlbum click to view 3168.jpgAlbum click to view 3171.jpgAlbum click to view 3392.jpgAlbum click to view 3428.jpgAlbum click to view 3563.jpgAlbum click to view 3582.jpgAlbum click to view 3613.jpgAlbum click to view 3652.jpgAlbum click to view
th_3816.gifAlbum click to view 3922.jpgAlbum click to view 3984.jpgAlbum click to view 3985.jpgAlbum click to view 3992.jpgAlbum click to view 4744.jpgAlbum click to view 5037.jpgAlbum click to view 5309.jpgAlbum click to view 5408.jpgAlbum click to view 5775.jpgAlbum click to view 5807.jpgAlbum click to view 6174.jpgAlbum click to view 6218.jpgAlbum click to view
th_6332.gifAlbum click to view 6417.jpgAlbum click to view 6592.jpgAlbum click to view 6851.jpgAlbum click to view 6926.jpgAlbum click to view 6939.jpgAlbum click to view 6947.jpgAlbum click to view 6956.jpgAlbum click to view 8182.jpgAlbum click to view 8830.jpgAlbum click to view 8952.jpgAlbum click to view 9025.jpgAlbum click to view 9350.jpgAlbum click to view 9589.jpgAlbum click to view 9595.jpgAlbum click to view 9609.jpgAlbum click to view 9767.jpgAlbum click to view 10489.jpgAlbum click to view 10656.jpgAlbum click to view 10858.jpgAlbum click to view 10963.jpgAlbum click to view 10964.jpgAlbum click to view 10988.jpgAlbum click to view 11075.jpgAlbum click to view 11249.jpgAlbum click to view 11400.jpgAlbum click to view 11524.jpgAlbum click to view 11741.jpgAlbum click to view 11742.jpgAlbum click to view 12497.jpgAlbum click to view 12746.jpgAlbum click to view 13022.jpgAlbum click to view 13408.jpgAlbum click to view 13409.jpgAlbum click to view 13998.jpgAlbum click to view 13999.jpgAlbum click to view th_14711.jpg 15076.jpgAlbum click to view 15213.jpgAlbum click to view 15228.jpgAlbum click to view 15241.jpgAlbum click to view 15269.jpgAlbum click to view 15946.jpgAlbum click to view 16028.jpgAlbum click to view 16286.jpgAlbum click to view 16287.jpgAlbum click to view 16288.jpgAlbum click to view 18410.jpgAlbum click to view 18550.jpgAlbum click to view 18551.jpgAlbum click to view 18796.jpgAlbum click to view 19492.jpgAlbum click to view 19836.jpgAlbum click to view 19911.jpgAlbum click to view 20747.jpgAlbum click to view 21878.jpgAlbum click to view 21879.jpgAlbum click to view 21880.jpgAlbum click to view 22361.jpgAlbum click to view 23090.jpgAlbum click to view 23145.jpgAlbum click to view 23224.jpgAlbum click to view 23225.jpgAlbum click to view 23226.jpgAlbum click to view 23227.jpgAlbum click to view 23228.jpgAlbum click to view 23229.jpgAlbum click to view 23230.jpgAlbum click to view 23231.jpgAlbum click to view 23233.jpgAlbum click to view 23234.jpgAlbum click to view 23235.jpgAlbum click to view 23237.jpgAlbum click to view 23238.jpgAlbum click to view
