Headers
Revision as of 22:46, 14 September 2016; view current revision
Categories: Exhaust System | Manifold
Extractors, headers — whatever you call them — are a more efficient "tubular" version of an Exhaust Manifold.
Unless you are racing, we recommend -- instead of headers -- the cast-iron 4-into-2-into-1 factory header. It's quieter, never wears out, and fits any 1200 perfectly. See GX Exhaust Manifold.
23145.jpgAlbum 23145
  • Some header do not allow the stock intake manifold to fit. You can grind the intake to fit
  • Some head hit the stock block breather pipe. Make a custom pipe
  • Headers for 1200 fit all body styles: ute, wagon, coupe and sedan
  • Headers/extractors fit both ways (A12 fits A14 and vice versa). However because A14, A15 and early A13 are "tall" blocks the header is raised up 15mm. So A12 headers on A14 engine may hit the floor
  • Headers for A-series engines bolt to any A-series engine. Exhaust port bolt pattern is identical for all A-series engines. port shape and size is identical within 1 or 2 mm
    20540.jpgAlbum 20540
  • Headers for a particular Datsun model may not fit another. For example, Vanette or B310 headers may or may not fit B110 due to the shape of the firewall and floor
  • Like any header they may need some tweaking of the flange, not because of the engine but because of poor manufacturing of the header
For the above reasons, the GX Exhaust Manifold is recommended.
Long-tube 4-into-1 header
16287.jpgAlbum 16287 16286.jpgAlbum 16286 16288.jpgAlbum 16288
Wrapping
Heat-wrapping can gain a bit of HP if the engine is retuned for it, at the cost of accelerated wear from either moisture rotting the header or from poor welds.
6947.jpgAlbum 6947
Suppliers
  • Yourself. If you know how to weld, You can make your one out of some steel tubing and a bit of 10mm plate for the flange
    See: Manifold
AUSTRALIA
  • Stewart Wilkins
    • Extractors - Datsun 1200/120Y/Sunny 4:2:1 Mandrel Bends $380.00 (August 2016)
  • Hurricane (August 2016)
    • HU075ST for A12, A14, A15
    • HU167ST (interference design) C20 Van
    • HU285STM for Datsun 1200 2-into-1
      799.jpgAlbum 799
South Yokohama equal length headers
23221.jpgAlbum 23221
New Zealand
  • Coby Manufacturing in Hamilton, NZ make 2 sets of different extractors to fit the A series motors
    Euclid Ave, Hamilton Phone: 0-7-849 1765
  • Autopia in Christchurch
Tri-Mil - Long Beach, California
376.jpgAlbum 376
Bill's Datsun Shoppe: Portland, Oregon
11524.jpgAlbum 11524 24108.jpgAlbum click to view 24110.jpgAlbum click to view 24109.jpgAlbum click to view
Nissan Competition
Nissan Sports Options Department tubular headers are a direct replacement for the cast iron GX manifold. They are superior to a "shorty" header in that these are a dual outlet type, and are collected together in the exhaust extension.
Sports Options Catalog
8270.jpgAlbum 8270 15269.jpgAlbum click to view shorty-1.jpg shorty-2.jpg shorty-3.jpg datsun72b110gx5-img599x439-1437643171c0hy6l20881.jpg datsun72b110gx5-img600x450-14376431711wvmb120881.jpg datsun72b110gx5-img600x532-1437643172xek47g20881.jpg
Nissan Competition 99996-H8000 B210/210 competition header 4 into 1 design with 1.375" primaries and 2.5" collector
Competition198442.jpg 24914.jpgAlbum click to view 24913.jpgAlbum click to view
Shorty Headers
Shorty header is designed to replace cast manifold. Easy packaging comes at the expense of a full length collector. The performance is lacking compare to a typical header.
shorty-1.jpg shorty-2.jpg shorty-3.jpg 16289_54c4981e8fa95.jpgPost 463202
Click any picture to see it full size and read details or post a comment.
80.JPG 195.jpg 375.jpg 376.jpg 506.jpg 591.jpg 606.jpg 634.jpg 799.jpg 1087.jpg 1248.jpg 1467.jpg 1565.jpg 1782.jpg 1786.jpg 1943.jpg 1955.jpg 2395.jpg 2466.jpg 2547.jpg 2645.jpg 2748.jpg 2982.jpg 3168.jpg 3171.jpg 3392.jpg 3428.jpg 3563.jpg 3582.jpg 3613.jpg 3652.jpg
th_3816.gifAlbum click to view 3922.jpg 3984.jpg 3985.jpg 3992.jpg 4744.jpg 5037.jpg 5309.jpg 5408.jpg 5775.jpg 5807.jpg 6174.jpg 6218.jpg
th_6332.gifAlbum click to view 6417.jpg 6592.jpg 6851.jpg 6926.jpg 6939.jpg 6947.jpg 6956.jpg 8182.jpg 8830.jpg 8952.jpg 9025.jpg 9350.jpg 9589.jpg 9595.jpg 9609.jpg 9767.jpg 10489.jpg 10656.jpg 10858.jpg 10963.jpg 10964.jpg 10988.jpg 11075.jpg 11249.jpg 11400.jpg 11524.jpg 11741.jpg 11742.jpg 12497.jpg 12746.jpg 13022.jpg 13408.jpg 13409.jpg 13998.jpg 13999.jpg th_14711.jpg 15076.jpg 15213.jpg 15228.jpg 15241.jpg 15269.jpg 15946.jpg 16028.jpg 16286.jpg 16287.jpg 16288.jpg 18410.jpg 18550.jpg 18551.jpg 18796.jpg 19492.jpg 19836.jpg 19911.jpg 20747.jpg 21878.jpg 21879.jpg 21880.jpg 22361.jpg 23090.jpg 23145.jpg 23224.jpg 23225.jpg 23226.jpg 23227.jpg 23228.jpg 23229.jpg 23230.jpg 23231.jpg 23233.jpg 23234.jpg
