Air Cleaner
From Datsun 1200 Club
Category: Engine Mechanical
Datsun 1200 protected its engine with a paper-type filter element air in a real metal air cleaner housing.
North America (Canada)
15695.jpgAlbum 15695
B210 stickers
8710_593ba9655d53a.jpgPost 485406 8710_593ba94c348a1.jpgPost 485406
Datsun 1200 warm region type air cleaner:
3149.jpgAlbum 3149
Datsun 1200 Cold Region type (hot/cold type) air cleaner -- has a hose connector for hot air. This is discussed below in Anti-Icing
14992.jpgAlbum 14992
Datsun 1200 Cold Region type 2
17031.jpgAlbum 17031 174_67e766688d61d.jpgPost 498832
Datsun 1200 Cold Region A.T.C. (automatic) type air cleaner is identified by the round flap actuator
Air cleaner base to carburetor seal (INSULATOR)
19454.jpgAlbum 19454
stickers
8710_5945b371cd7a3.pngPost click for topic 8710_5946666fe4185.jpgPost 485457
Bprojects
174_56eb5077b2016.jpgPost 477350
Tightening
Turn the wingnut down until it contacts the air cleaner lid. Then tighten the wing nut 3 turns:
14993.jpgAlbum 14993
Removal
The air cleaner must be removed to inspect the carburetor or vacuum hoses.
Cleaner Removal
  1. IMPORTANT: If you have a warm/cold air cleaner, first remove the hoses as outlined below
  2. Twist and pull the thick breather hose straight up out of the rocker cover
  3. Remove the two 10mm-headed bolts from the side of the air cleaner away from the engine
  4. Remove the one 10mm-headed bolt from the bracket next to the rocker cover
  5. Untwist the wingnut holding the air cleaner top on. Carefully remove the washer & rubber piece
  6. lift the lid off and remove the air filter element
  7. lift the air cleaner body straight up
Hot/Cold Air Cleaner
If you have an warm/cold air type air cleaner do this first before attempting to remove the air cleaner:
  1. Grab the hot air tube just underneath the air cleaner snout. Carefully twist the hot air tube to loosen it. If it won't twist, unscrew the clamp first. Be careful not to damage the cardboard tubing. After it is loose, pull it down off the bottom of the air cleaner snout. Leave the bottom of the tube connected, only separate it from the air cleaner
    174_65b7feb7e7a39.jpgPost 498236
If you have the ATC type (vacuum controlled) air cleaner do this:
  1. Twist and pull the ATC vacuum hose out of the intake manifold port
  2. Disconnect the vacuum hose at the rear of the air cleaner
Also See
Also see:
* GX Air Cleaner
* Air Intake Systems for upgrades/alternatives, including cold air intakes
Air Filter
See Main Article: Filters#Air Filter
Anti-Icing
To prevent ice up in winter, air cleaners for temperate markets have a temperature control. For example, this Japan-market air cleaner draws hot air to prevent icing (carb icing can over at temperatures several degreesn freezing):
The hot air is drawn up from the exhaust manifold
174_65b7fe8590d62.jpgPost 498236
Automatic Temperature Control
Some JDM 1200s and 1972 USA models use an Automatic Temperature Control air cleaner for year-round constant inlet temperature. This protects again carb icing, but also regulates the temperature for consistent jetting. For details, see ATC.
Types
Datsun 1200 changed several times:
Side Stay
* #H10 original style
* B210 new-manifold style (sedan/coupe)
* W85 style 1979-1989
Front Stay (for EGR manifold)
* G19 style with large front clip
* 95W style 1989-1994 3-bolt front stay
GX
See main article: GX Air Cleaner
H10
H10 style used by:
* B110
* B120 -7907
* B210 1973-1975
* VB210 B210 wagon
* B310.VAN(-7909) B310 wagon
1977 VB210 Japan:
Late A-engine
From 1976, B210 (except VB210) changed to a front bracket type air cleaner. This was to provide more clearance for the EGR valve.
Thin bracket bolts to the very last manifold bolt
air_pump_before.jpg 174_5869c079481c1.jpgPost 483040
Likewise, B310 Wagon, Sedan & Coupe changed to a front bracket type air cleaner, while VB310 Van stayed similar to the 1200 air cleaner. This applied to A12/A12A as well as A14/A15 engines.
B310
1570.jpgAlbum 1570 21587.jpgAlbum 21587
B310 with TVV bracket on Air Cleaner Stay
8856.jpgAlbum 8856
Mid-model Pickup
Ute/Sunny Truck 1979.August-1989.October
Uses the new front-bolt air cleaner -- like the late B210.
26384.jpgAlbum 26384
1984 June
Late Sunny Truck
1989 October brought a new intake manifold so the air cleaner now mounts with thin bracket at rear, and double-bracket at front.
With air duct
Includes ATC air temp regulator
New type 3-bolt Support bracket
Charcoal Canister
B140
B140 bakkie
16893.jpgAlbum 16893
1200 SSS
Twin Dellorto air cleaner for Datsun 1200 SSS
B310 EGI
Fuel Injection
27672-H8505 air intake duct
B310 With AIS
Air Injection System
* with Smog Pump
* without Smog Pump
Air Injection System without Smog Pump
Smog Pump type: Front bracket with EGR attachment
Front-side Rocker cover Breather Hose
Side: Rear Breather Hose, Front Smog Hose
Fender side: Rear bracket for Smog Valve
N13
Pulsar#N13 Remote filter, or could modify to fit sidedrafts.
12634.jpgAlbum 12634 12635.jpgAlbum 12635 12636.jpgAlbum 12636 12637.jpgAlbum 12637 12682.jpgAlbum 12682 12683.jpgAlbum 12683 12684.jpgAlbum 12684 12694.jpgAlbum 12694 12695.jpgAlbum 12695 12696.jpgAlbum 12696
Vanette
Factory A-series top-hat for use with remote filter.
See main article: Vanette Air Cleaner
B120
Datsun 1200 truck
16500 Air Cleaner (less stays)
Original bolt-pattern manifold type
16500-H7803 -7801
16500-H7813 -7801 カンレイチ シヨウ (ATC)
16500-G1661 7802-7907 with idle compensator
16500-G1671 7802-7907 カンレイチ シヨウ
Change to new bolt-pattern manifold type
* all ATC type
16500-W8512 7908-8503 [front 2-bolt stay]
16500-G1900 8504-8910
16500-95W00 8910- [front 3-bolt stay]
B310
Datsun Sunny B310
JAPAN Air Cleaner (less stays)
Sedan/coupe (front stay type) all with ATC
16500-H8501 -7812
16500-H8502 7910-7909 > 16500-H8501
16500-H7500 7910-8010 U20 idle compensator
16500-W8512 8110-     H10 idle compensator
Van (VB310) side stay (#H10) type w/o ATC
16500-W8512 7910-8109 Van
16500-G1660 A12S.V -7909
16500-G1670 A12S.V -7909 F/COLD
16500-H9601 A14S.V -7909
16500-H9611 A14S.V -7812 F/COLD
16500-H9612 A14S.V 7901-7909 F/COLD
Fuel Injection
16500-H9200 EGI
B310 front-stay type
Sidedraft Air Cleaner
See Main Article: Sidedraft_Air_Filters
No Air Cleaner
16574-H1001 SUPPORT-AIR CLEANER,FRONT A12
* 08363-61214 M6 MACHINE SCREW WITH LOCK WASHER
[Stud for intake manifold: M8]
16573-H1001 SUPPORT-AIR CLEANER, REAR A12
* 08363-61214 M6 MACHINE SCREW WITH LOCK WASHER (4)
B110 originally used instead of the machine screws:
* 08120-61210 M6 BOLT
* 08915-13610 M6 WASHER-LOCK
* 08915-43610 M6 WASHER-PLAIN
H10 Rear Stay post
8710_56c04c6ebe743.jpgUpload click to view 8710_56c04c2f586f5.jpgUpload click to view 8710_56c04c20a8b83.jpgUpload click to view
H10 Stays (supports) used by
* B110
* B120 -7907
* B210 1973-1975
* VB210
* B310.VAN(-7909)
B120 Sunny Truck changed to new style intake manifold in 1979
982_.jpgAlbum click to view
Mid B120 7908-8910 {CHANGE TO NEW STYLE INTAKE MANIFOLD]
AIR CLEANER SUPPORT, FRONT
* 16574-W8501 7908-8109 [same as B310.Van(8011-8109)]
* 16574-G1900 8110-8910 [same as B310.Van(8110-)]
* 77720-89919 BOLT (for Front Support)
AIR CLEANER SUPPORT, REAR
* 16573-W8500 7908-8109 [same as B310.Van(7910-8109)]
* 16573-G1901 8110-8910 [same as B310.Van(8110-)]
* 08120-61262 MACHINE SCREW WITH LOCK WASHER (4)
1981 October 16573-G1901 Support has large clip for EGR VVT valve
Late B120 8910- {CHANGE TO MANIFOLD]
AIR CLEANER SUPPORT [2-BOLT]
* 16574-95W00 8910- [bolts to rearmost manifold bolt]
* 77720-89919 BOLT
AIR CLEANER SUPPORT [3-BOLT]
* 16573-95W00 8910- [bolts to front of  manifold]
* 08120-61262 MACHINE SCREW WITH LOCK WASHER (3)
1989 October 16573-95W00 for new intake manifold thin bracket bolts to last manifold bolt
Stay
willieoec-img600x450-1327287856t0yvgx33925.jpg willieoec-img600x450-1327287855qcr3xe33925.jpg
220.JPG 291.jpg 759.gif 1005.jpg 1133.jpg 1693.jpg 2687.jpg 2771.jpg 2772.jpg 2773.jpg 3149.jpg 3461.jpg 3492.jpg 3503.jpg 3712.jpg 4151.jpg 5252.jpg 5315.jpg 5468.jpg 5773.jpg 7495.jpg 8115.jpg 8996.jpg 9006.jpg 9112.jpg 9113.jpg 11690.jpg 12636.jpg 12938.jpg 13219.jpg 13380.jpg 13817.jpg 14541.jpg 21032.jpg 14541.jpg 14545.jpg 14757.jpg 14758.jpg 14856.jpg 14992.jpg 14993.jpg 15631.jpg 15675.jpg 15694.jpg 15695.jpg 15729.jpg 16116.jpg 16117.jpg 16663.jpg 16774.jpg 16775.jpg 16776.jpg 16866.jpg 16893.jpg 17031.jpg 17032.jpg 18165.jpg 18250.jpg 18929.jpg 18976.jpg 19110.jpg 19233.jpg 19454.jpg 20723.jpg 20805.jpg 20806.jpg 21214.jpg 21533.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Air_Cleaner"
This page has been accessed 55,120 times. This page was last modified 08:13, 29 March 2025. Content is available under Datsun 1200 Club.
