Dashboard
Revision as of 08:47, 6 May 2016; view current revision
Category: Body
Various dashes were used for various countries, trims, and years. Standard and DX used rectangular gauges, while GL and GX used round gauges. All USA models use round gauges.
Terminology
In Nissan official terminology, the "dash" is the cowl & firewall. But in common usage, the dash is the instrument panel or gauges therein and sometimes refers to the dash pad.
Dash Panels -- see Firewall ダツシュ パネル
Instrument Panel is the entire removable pod assembly (commonly called the Dash) インストルメント パネル
The metal frame is the Instrument Panel Assembly
Gauge Cluster - see Cluster Gauge
Dash facia is Cluster Lid.  クラスター リツド
Dash pad is the Instrument Panel Pad.  インストルメント パツド
Dash includes the pad, instrument panel, and dash frame
Glovebox is on the passenger side
Defroster vents connect to the dash frame
Instrument Panel
  • Rectangular gauge instrument cluster (角/kaku): Standard, Deluxe Sedan
  • Round gauge instrument cluster (丸/maru): Deluxe Coupe, GL, GX
Comparo
1350.jpg DX Coupe
5172.jpg GL
11440.jpg 1970-1971 (flat type)
13214.jpg 1972 (hooded type)
defrost finisher (ventilation garnishes/ventilation trim)
68820-H1000 FINISHER-DEFROSTER
Trim Levels
Datsun 1200 trim packages received different factory equipment.
RECTANGLE GAUGE
STD:      Rectangle with OPTION clock
DX Sedan: Rectangle with OPTION clock
NOTE: North America DX sedan came with round gauges
ROUND GAUGE
DX Coupe: Round with OPTION clock
GL:       Round with clock
GX:       Round with Tachometer
          * clock moved to Console
          * 180 kph speedometer
Tachometer and Clock were both OPTION
Datsun Sunny Excellent 1400 PB110 trim levels were outfitted the same way except that DX Sedans came with round-gauge dashes.
1972 Facelift
See main article: Facelift Dash
Kilometers vs Miles
Miles only
Miles only
Kilometers only
Dual range Kms with miles
Sunny Truck Dash
Early
1971-1978 rectangle dash
Mid
1978-1989 Brown Round
Late
1989-1994 Gray Round
full
Note:
full
full
full
B140 Bakkie
  • "NISSAN" clock delete plate
Pad
Nissan calls the Dash pad the Instrument Panel Pad. Reference: Dash Trim Part Numbers
RHD
68910-H1000 ASS'Y-PAD, instrument [round or square]
68910-H2501 PAD-INSTRUMENT PB110 (black) DX,GL,GX
68910-H2600 PAD-INSTRUMENT PB110 (blue) GL
68910-H2700 PAD-INSTRUMENT PB110 (brown) GX
68910-H3100 PAD ASS'Y-instrument 1972 [Facelift]
68910-H2500 PAD-INSTRUMENT B120 -7803 BLACK
68910-G1060 PAD-INSTRUMENT 7804-8910 DARK BROWN
68910-95W00 PAD-INSTRUMENT 8910- GRAY
LHD
68910-H1600 LHD ASSY-PAD INSTRUMENT $306.10 USD
Maddat Code DP1200 - Datsun 1200 Dash Pad. Datsun 1200 RHD genuine Nissan dash pad, Brown only.
Facia (Cluster Lid)
Dash facia is called by Nissan the Cluster Lid (gauge cluster lid). Reference: Meter Part Numbers
RHD
LHD
Close up around heater/radio section
Dash Frame
The dash frame is the metal part of the dashboard, which Nissan calls the Instrument Panel Assembly Reference: Dash Part Numbers
Dash Top
The top of the dash contains:
PB110
* Early: Flat instrument panel
* Late: Podded instrument panel
Early - Same as 1970-1971 1200, but offered in additional colors
full
See PB110 Brochure
1972 - Same as 1972 Datsun 1200
full
Cluster
Early
Late - same as 1972 B110
CLUSTER LID
H25 Gray Metallic DX
H26 Gold Metallic GL/GX
H31 Gray Metallic DX    from '72-1
H33 Gold Metallic GL/GX from '72-1
Sunny Excellent 1400 (PB110) hooded dash
1972 PB110 Facelift double-hump dash
full
full
Facelift PB110
full
Facelift PB110
full
Facelift PB110 Glove Box door is thick, with a prominent curve
full
Glovebox Lid
EARLY GLOVE BOX LID
H10 Black DX,GL,GX
H26 Blue  GL
H27 Brown GX
LATE GLOVE BOX LID
?Looks same as 1972 B110
Standard Dash
1975 October B120
full
full
1977 April B120 (和52年4月)
th_1977_B120_dash-1.jpg th_1977_B120_dash-2.jpg th_1977_B120_dash-3.jpg th_1977_B120_dash-4.jpg th_1977_B120_dash-5.jpg th_1977_B120_dash-6.jpg th_1977_B120_dash-7.jpg th_1977_B120_dash-8.jpg th_1977_B120_dash-9.jpg
50.JPG 268.jpg 286.jpg 804.jpg 838.jpg 1085.jpg 1206.jpg 1448.jpg 1451.jpg 2035.jpg 2041.jpg 2073.jpg 2149.jpg 2181.jpg 2299.jpg 2760.jpg 2937.jpg 2970.jpg 3122.jpg 3410.jpg 3895.jpg 3901.jpg 3902.jpg 4180.jpg 4181.jpg 4409.jpg 4818.jpg 4939.jpg 5044.jpg 6457.jpg 6465.jpg 6595.jpg 6703.jpg 7265.jpg 7373.jpg 7507.jpg 7890.jpg 8400.jpg 8807.jpg 8809.jpg 9789.jpg 9792.jpg 9940.jpg 10456.jpg 11145.jpg 11149.jpg 11578.jpg 11581.jpg 12155.jpg 12506.jpg 12507.jpg 13107.jpg 24579.jpg
Round Dash
See Round Dash Photo Index
1981 April
full
Custom Dash
mrwilson
mrwilson made this fantastic dash as a one-off. Photos of the mold are at mrjpwilson photobucket.
120Y dash in Datsun 1200. Fits right in.
This one features a wooden dash pad. Spotted in a Datsun 1200 picopita.
Silvia
Sylvia is a popular dash swap into a 1200.
mcgee's dash
th_0f3bea2284ee4daefb2d1432ef3186ff.jpg th_a32b7aafd64d9b8b63c29893b6793d05.jpg th_a337ad600272fb423cef6a23d8cf9b12.jpg th_204af1c4f3c69001f24aa40a8510b1bb.jpg th_P1020130.jpg th_P1020068.jpg
Charade
Charade G200
Starlet
13670.jpg Starlet Dash in 1200
aidaniel
project build
th_29112008228.jpg th_29112008229.jpg th_29112008230.jpg th_02122008231.jpg th_02122008232.jpg th_07122008245.jpg
Stainless
Fibreglass
7628.jpg 7893.jpg 8589.jpg 8929.jpg 8930.jpg 8931.jpg 11126.jpg 13092.jpg 13119.jpg 13275.jpg 13276.jpg
Wood
burl finish
full
Fascia
Starion
Mitsubishi Starion dash. Tony's ute also has Starion 2.0 engine.
Misc
1801.jpg 2912.jpg 5876.jpg 6448.jpg 6655.jpg 6842.jpg 7066.jpg 7703.jpg 7813.jpg 8208.jpg
Aircraft-style fitted dash sold for 50,000 yen on Yahoo Auction in 2014
