Datsun 1200 SSS
Revision as of 07:32, 8 January 2018; view current revision
Category: Models and Features
The Datsun 1200 SSS was a special version of the Datsun B110 created by Datsun New Zealand. It was sold through the 1974 model year, even though 1200 factory production stopped in 1973. Based on the B110 4-dr sedan, it featured twin sidedraught carburettors, special alloy wheels and blacked-out bonnet.
Overview and History
Third SSS sold new on South Island
3595.jpgAlbum 3595
The Datsun 1200SSS was devised by Warren Broadbent of Nissan Motor Distributors (NZ) Ltd and Dennis Marwood of Performance Development Ltd. Warren was in Japan on business early this year and felt there was a local market for a modified version of the successful 1200 after seeing the success of the bigger Datsun 1600 SSS.
85.jpgAlbum click to view
Why the 4-door sedan? The coupe would appear to be the basis for a hot-rod 1200.
Quote: The production racing class the SSS was built for was for 4 door sedans hence the deluxe sedan was the base for the little beasty.
Performance Development in Papakura did the engine modifications.
These little cars are unique to NZ, having been built up by a chap by the name of Dennis Marwood in Auckland. The joint venture commissioned by the NZ Datsun distributors back in the early to mid 1970's.
Re numbers- they built around 800 110SSS's and only around 150 [B210] 120SSS's.
As I understand it they cost approx. an extra $500 [$543, see Motor Magazine article which tended to make them rather pricey at the time.
2086.jpgAlbum 2086
Essentially the drive chain [sic] modifications were the addition of the twin Delhorto carbs + air box, extractors and a reprofiled camshaft- thats all, the cylinder head, block, gearbox and diff remained unaltered. However these modifications alone were enough to give these little cars a healthy performance edge over a standard 1200 ultimately leading to them being one of the most successful cars ever raced or rallied in this country.
10290_4a2dfcfbdb12e.jpgPost 257904 10290_4a2dfd0a339d5.jpgPost 257904
24866.jpgAlbum 24866 13790.jpgAlbum 13790
SSS Features
  • SSS grille badge
    5460.jpgAlbum click to view 5438.jpgAlbum 5438
  • SSS boot badge
    5305.jpgAlbum click to view 8098.jpgAlbum 8098
  • SSS badge on the glove box (not fitted to all SSS)
  • Wildcat Royale vinyl custom deep-dish three-spoke simulated wood steering wheel
    6595.jpgAlbum click to view SSS6787.jpgAlbum click to view SSS
  • Twin 40mm Dellorto carburetors (NOTE: Not the Hitachi Sidedraft Carburetors put on the 1200GX Engine)
    5468.jpgAlbum click to view 872.jpgAlbum click to view 195.jpgAlbum click to view
  • NZ-made intake manifold for round-port head
    6260.jpgAlbum click to view
  • badge on right rear of boot lid
  • custom air box (similar to the Japan Domestic Model GX airbox)
    6258.jpgAlbum click to view6259.jpgAlbum click to view
  • Standard 1200 cylinder (not modified)
  • Compression ratio, gear ratios, brakes and suspension remained unaltered
  • Coby extractors (headers) exhaust is 4-2-1 cast headers they have a flange after they go into 2
  • Cam spec @ 0.050": Intake opens 3deg BTDC, closes 20deg ABDC, duration 203deg. Exhaust opens 31deg BBDC, closes 6deg BTDC, duration 208deg
  • Rectangular gauges, as with the standard Sedan. Round tachometer in front of the heater box One report says it came with Round gauges as in the coupe, which is possible (since they did vary other options during the production run) but unconfirmed
  • black patches on the bonnet with black down the sills and front and rear skirts
  • driving lights (optional?)
  • Datsun Competition rally spec 270 degree camshaft with 70 degree overlap
  • 12x4" slotted Jellybean ("slotted mag") wheels by Ward Wheels with radial tyres and 'Datsun' center caps. Later 1200SSS and 120Y SSS had Triden jellybeans by Cheviot
    B7A43AEED997D340181F3F0930F7622E.jpgPost click for topic 85.jpgAlbum click to view478.jpgAlbum click to view 5467.jpgAlbum click to view
  • 1200 sedans were assembled in New Zealand and came in a greater range of colours than the fully imported coupes
    117.jpgAlbum click to view
  • B110 SSS didn't come with side stripes, as did the later B210 (120Y) version
  • center console below heater with tachometer. The tacho was usually VDO, but Smiths and others seem to have been fitted to some
  • (some) two flat-black rectangle stripes on bonnet and boot
    3595.jpgAlbum click to view
  • boot spoiler on some SSS vehicles (not all)
    2445.jpgAlbum click to view
  • dealer option: spotlights
  • ??? black-painted sills
  • (some) have steeply-raked boot spoiler
  • coupe-spec Cowl Top Grille
  • carpet
  • based on the Deluxe body,which provides the Deluxe interior arm rest door handles
  • wider, high back front seats, same as fitted the later 1200 New Zealand wagons
    6606.jpgAlbum click to view
discussion: Datsun 1200 SSS
Jelly Bean mags
f.jpgPost click for topic
Performance
The SSS had 55 road horsepower, compared to about 40rhp for a good standard 1200, and an increase in engine bhp from 69 to about 90bhp. The motor develops the extra horses at the same rpm. And the mild camshaft offers a wide power range.
The Pukekohe circuit time was about 7 seconds (!) faster than the best lap for a standard 1200.
ACCELERATION [1200 SSS] (Standard 1200 as tested October 1971 given in brackets):
.. 0 - 60mph ............. 11.9s . (14.0s)
.. Standing quarter mile . 18.1s . (18.8s)
MOTORMAN magazine
MOTORMAN magazine out of New Zealand tested both a regular 1200 and a 1200 SSS and note this:
We didn't take the 0-90mph time with the standard car because it was near the Datsun's top speed, but the SSS version took half a minute to reach this velocity, and continued to pull strongly to its maximum of 100mph [compared to regular 1200 at about 90 mph].
The downside? Only 28 miles per gallon, instead of the usual 38 mpg from a standard 1200. Those big Dellortoes must have been plenty thirsty.
Magazine Articles
  • Motorman Nov 1972 (pp 15-16) - "Datsun 1200SSS Road Test"
  • Motorman Jul 1973 (pp 12-13) - track test of the racing version
  • Sports Car World Mar 1973 - From New Zealand - Two hot cars built for the Benson & Hedges 500 Fiat 125T and Datsun 1200 SSS
Comments
Twin dellortos and manifold for 1200/A12 I have for sale a pair of 40 DHLA Dellortos and a manifold to suit a 1200. These are ORIGINAL from a 1200SSS which was a New Zealand only model. The 1200 engine with these carbs, extractors and a mild cam made 90 hp -vs- 68 hp for the standard model. Considerably more than the highly prized 1200GX. BOLT ON HORSEPWER! They are in good working order. Will not suit an A14 or A15 as those engines have oval inlet ports. These suit A12/1200 motors with round inlet ports."
6260.jpgAlbum 6260
That seems reasonable price wise (well at least carb wise), but be aware that the inlet manifolds were Kiwi cast by Dennis Marwood (the guy that got the Datsun OK to make the SSS in NZ) and they are awful!!!! None of them fit properly and to get them to match the head ports it is necessary to drill the mounting holes oversize to lift the manifold upwards to locate it better. All Marwood manifolds are like this - just a nasty design - some are better than others, but they are all pretty nasty in terms of alignment with the head ports........
Cheers
5050.jpgAlbum 5050
Quote: a few more bits of trivia for you. The brains behind the 1200 SSS was Dennis Marwood, he is still racing though in an Alfa these days. He owns Autoquip Marketing in Auckland. He can be a bit of a grumpy bugger to talk to sometimes too so be warned. The dellortos were hung of a locally made manifold which Dennis still sells and had Coby extractors. The cam was a rally spec 270" from the Datsun Competition range though they probably bought one and had it copied!!! The air box is a fabricated piece in a similar style to the factory GX item. The wheels were 12" jelly beans made in Palmerston North by a company called Ward Wheels,it changed it's name to Aldic 10 yrs ago but I am not sure if they are still around. I have a set of wheels and a brand new 1 in the box. I know of more if you really want some but you are limited in your choice of tyres. All the cars I've seen had deep dish steering wheels that tended to crack through the spokes so they are getting hard to find. The stripes were limited to the bonnet and bootlid and were 2 flat black rectangles nothing too flash. These cars were very successful in the endurance races in the 70s and I have a super rare brochure showing a SSS cornering hard at Pukekohe Raceway and it's handling and performance bing praised by it's drivers Mark Petch and Frank Radisich ( Yes Pauls Father !!) I also have a sales brochure for them which I hope to be able to add to this site soon. The 120Y SSS had identical running gear and many were robbed to build 1200SSSs because they were more popular. As far as how many were built is a mystery to me maybe Dennis can tell you. Also the SSS had a huge for it's day boot spoiler which was almost upright and I would love to find one to take a mould off. The SSS didn't get any special build plates etc so they are very easy to fake. The sad thing is because they were built from locally assembled cars many of them have rusted away and the rest have been thrashed in competition so good ones are bloody hard to find.
4672.jpgAlbum 4672 6728.jpgAlbum 6728 6729.jpgAlbum 6729
Racing
Shell 200 at Levin
Grant Aitken/Barry Vuyk (Datsun 1200 SSS) during the 1974 B&H 500
Bryan Innes/Dennis Marwood 1972 B & H 500 race car
8099.jpgPost click for topic
Several 1200s at the 1972 B & H race in Pukekohe with a Fiat 125T in foreground
B & H SSS
Example
on eBay - September 2016: POST Datsun 1200 SSS for sale
174_57ea59674cc05.jpgPost 481490 174_57ea597c9b5b7.jpgPost 481490 174_57ea59900dcd2.jpgPost 481490 174_57ea599692347.jpgPost 481490
120Y SSS
After the B110 SSS, Nissan New Zealand marketed a B210-based 120Y SSS.
See Main Article: 120Y SSS
85.jpg 117.jpg 478.jpg 552.gif 605.jpg 616.jpg 906.jpg 1103.jpg 1216.jpg 1222.jpg 1242.jpg 1278.jpg 1406.jpg 2016.jpg 2044.jpg 2082.jpg 2084.jpg 2085.jpg 2086.jpg 2241.jpg 2242.jpg 2442.jpg 2443.jpg 2445.jpg 2652.jpg 2934.jpg 3175.jpg 3176.jpg 3495.jpg 3509.jpg 3595.jpg 3596.jpg 3638.jpg 3828.jpg 3829.jpg 3851.jpg 3854.jpg 3989.jpg 4063.jpg 4064.jpg 4414.jpg 4492.jpg 4493.jpg 4524.jpg 4672.jpg 5050.jpg 5305.jpg 5384.jpg 5438.jpg 5460.jpg 5467.jpg 5468.jpg 5548.jpg 5549.jpg 5567.jpg 5697.jpg 5821.jpg 6258.jpg 6259.jpg 6260.jpg 6408.jpg 6595.jpg 6606.jpg
th_6622.gifAlbum click to view 6625.jpg 6647.jpg 6728.jpg 6729.jpg 6787.jpg 7599.jpg 7791.jpg 8096.jpg 8097.jpg 8098.jpg 8099.jpg 8604.jpg 8905.jpg 9398.jpg
th_10299.jpgAlbum click to view 11022.jpg 11023.jpg 11381.jpg 11729.jpg 11747.jpg 11956.jpg 12059.jpg 12060.jpg 12061.jpg 12114.jpg 12366.jpg 12407.jpg 12435.jpg 12456.jpg 12578.jpg 12787.jpg
th_13041.jpgAlbum click to view 13347.jpg 13400.jpg 13405.jpg 13463.jpg 13943.jpg 13944.jpg 13945.jpg 13995.jpg 14168.jpg 14491.jpg 14811.jpg 15026.jpg 15236.jpg 15491.jpg 15613.jpg 15894.jpg 16571.jpg 16572.jpg 16573.jpg 16574.jpg 16575.jpg 16576.jpg 16577.jpg 16617.jpg 16618.jpg 16685.jpg 16722.jpg 16897.jpg 16936.jpg 16939.jpg 17620.jpg
Wiki Photos
Click any thumbnail to see it full size (on external web site).
20020995436_48d39a9234_k.jpg 20750853444_635999a787_k.jpg 20750853444_635999a787_k.jpg DSCN7076.jpg DSCN7077.jpg GM.jpg GM-.jpg GM_.jpg WayneMurdoch.jpg
