Part Numbers Index
Revision as of 10:11, 7 January 2012; view current revision
This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine Engine assembly (all NLA)
Engine Gasket Kit
Cylinder Block & Oil pan
Cylinder Head & Rocker Cover
Engine Mounting
Piston & Crankshaft & Flywheel
Front Cover & Cylinder Fitting
Camshaft & Valve Mechanism
Manifolds
EGR
Emission Controls
Oil pump & Oil filter (oil strainer)
Exhaust Tube & Muffler
Water pump & Thermostat
Radiator
Accelerator Linkage
Fuel
Air Pollution Control
Vacuum Control (engine vacuum hose routing)
Carburetor
Fuel Throttle (See EGI fuel injection)
Fuel filter (fuel strainer) and Fuel Piping
Fuel Pump
Air Cleaner
Fuel Tank & Fuel Piping
Power Train
Clutch Accessory
Clutch Control
Automatic Transmission
* Accessory
* Torque Convertor & Case
* Oil Pump & Clutch
* Planetary Gear
* Control Valve
* Control Switch
* Fitting
Manual Transmission
* Accessory
* Transmission Case
* Transmission Gear
* Shift Control
* Transmission Control & Linkage
* Propeller Shaft
* Differential (Final Drive)
Brake
Hand Brake (Parking Brake Control)
Front Brake
Rear Brake
Clutch & Brake Pedal
Brake master cylinder
Power Brakes
Brake Piping
Chassis
Front Axle
Rear Axle
Road Wheel & Cap
Steering Gear
Steering Column
Steering Linkage
Steering wheel
Steering Column Shell
Front Suspension
Rear Suspension
Spare Tire Carrier
Electrical
Engine Electrical System
Distributor
Alternator Accessory & Mounting
Starting Motor
Wiring Harness
Instrument Panel (Meter)
Switch & Relay
Battery Mounting
Lamp Part Numbers
* Head Lamp
* Front Combination Lamp
* Fog Lamp
* Rear Combination Lamp
* License Lamp & Side Reflectors
Body & Trim
Body Panels
* Body Complete & Touchup Paint
Front Grille & Fitting
Rear Body
Front Bumper
Rear Bumper
Body Side Moulding & Stripes
Front Body Panels
Cowl & Dash Fitting
Dash Trimming
Side Panel & Lock
Glass
Dashboard
Seats
Carpet
Badges
Paint
Doors
Mirrors
Visors
Console
Bonnet (Hood)
