KB10
Revision as of 07:32, 24 November 2009; view current revision
Category: Datsun B10
Datsun 1000 Coupe -- you know you want one.
Advertising
Also see: Photo 4993.jpeg
Trim
KB10 was available in Deluxe and GL (Grand Luxury グランデ ラクジアリ) Trim levels.
Deluxe
Sunny Coupe: In Japan this was the DeLuxe & was the base model. It had a longer option list only because some of these options were standard equipment in the GL. The accessory list was the same as the GL.
Datsun 1000 Coupe DeLuxe: Offered in Australia only, these were pretty close in spec to the JDM DeLuxe model. Differences include 'some' Datsun badging as the deck lid emblem, & the grille emblem remained with the 'S' symbol from the original Sunny. NSW spec cars seem to have all come with a Tach, radio, two external mirrors, a heater & perhaps some other stuff, all of which were options in the Japan-market DeLuxe model. Other states may have varied the specs a little but the Aussie spec car was better equiped on the showroom floor than the equivalant Japan version. Japan cars had amber front park/blinker lenses while Aussie ones had white lenses. Everything on the brochure option list was available in Australia, including the wood rim steering wheel.
GL
Sunny Coupe GL: In Japan this had the sporty steering wheel & a few other trinkets to tart it up a bit & it was available with a floor shift auto trans as well as a short list of options & a loooong list of accessories.
GL grille was unique (blackout?) and GL black bullet mirrors
62303-25701 GRILLE-radiator C-G
Coupe GL rear badge
GL wood sports Steering Wheel
Coupe GL Pinstripe
Body Options
  • F2674-25700 GUARD-bumper rubber (Op.) Coupe [front & rear]
  • K7010-00001 BADGE-car, "SUNNY COUPE" (A) (op.) Coupe
  • K7010-00001 BADGE-car, "Sunny Coupe" (B) (op.) Coupe
  • K7010-00004 BADGE-car, "SUNNY COUPE" (A) (op.) Coupe
  • K7010-00005 BADGE-car, "Sunny Coupe" (B) (op.) Coupe
  • K7010-00003 PLATE-initial (A~Z) (B) (op.) Coupe
  • 80900-25802 ASS'Y-FINISH, door (R.H.) (op.) Coupe
  • 80900-H0301 ASS'Y-FINISH, door (R.H.) (op.) Coupe
  • 80900-H0303 ASS'Y-FINISH, door (R.H.) (op.) Coupe
  • 80901-25802 ASS'Y-FINISH, door (L.H.) (op.) Coupe
  • 80901-H0301 ASS'Y-FINISH, door (L.H.) (op.) Coupe
  • 80901-H0303 ASS'Y-FINISH, door (L.H.) (op.) Coupe
  • K5040-00010 SET-VISER, side (stainless) (op.) Coupe [visor]
  • K5040-00011 VISER-side (R.H.) (op.) Coupe
  • K5040-00012 VISER-side (L.H.) (op.) Coupe
  • K5040-00020 SET-VISER, side (plastic) (op.) Coupe [visor]
  • K5040-00021 VISER-side (R.H.) (op.) Coupe
  • K5040-00022 VISER-side (L.H.) (op.) Coupe
  • 80010-H0301 SET-CYLINDER LOCK & KEY (op.) Coupe
  • 87000-25803 COMP.-SEAT, driver reclining (check) (op.) Coupe '68
  • 87050-25803 COMP.-SEAT, assistant reclining (check) (op.) Coupe '68
  • 88300-25803 ASS'Y-CUSHION, rear seat (check) (op.) Coupe '68
  • 88600-25803 ASS'Y-BACK, rear seat (check) (op.) Coupe '68
  • 87000-H0322 COMP.-SEAT, driver reclining (check) (op.) Coupe '69
    • 1969 seats have headrests
  • 87050-H0322 COMP.-SEAT, assistant reclining (check) (op.) Coupe '69
  • 88300-H0322 ASS'Y-CUSHION, rear seat (check) (op.) Coupe '69
  • 88600-H0322 ASS'Y-BACK, rear seat (check) (op.) Coupe '69
    • 6566.jpg check pattern seats
  • 88820-25725 SET-BELT, rear seat safety (op.) Coupe
  • 88820-H0325 SET-BELT, rear seat safety (op.) Coupe
  • 88820-25700 SET-BELT, rear seat safety (op.) Coupe
  • 88820-H0300 SET-BELT, rear seat safety (op.) Coupe
  • 86850-25700 ASS'Y-RETRACTOR, safety belt (op.) Coupe
  • 62520-H0100 PLATE-closing, core support (R.H.) (op.) Coupe
  • 62521-H0100 PLATE-closing, core support (L.H.) (op.) Coupe
Click each pic for larger view and discussion.
276.jpg 277.jpg 576.jpg 733.jpg 768.JPG 769.JPG 924.jpg 925.jpg 926.jpg 927.jpg 950.jpg 965.jpg 966.jpg 1193.jpg 1285.jpg 1372.jpg 1462.jpg 1463.jpg 1465.jpg 1468.jpg 1474.jpg 1606.jpg 1608.jpg 1631.jpg 1632.jpg 1633.jpg 1787.jpg 1823.jpg 1824.jpg 2021.jpg 2022.jpg 2095.jpg 2535.jpg 2548.jpg 2999.jpg 3223.jpg 3619.jpg 3809.jpg 3810.jpg 4021.jpg 4022.jpg 4023.jpg 4210.jpg 4320.jpg 4321.jpg 4322.jpg 4454.jpg 4495.jpg 4741.jpg 4974.jpg 5120.jpg 5121.jpg 5190.jpg 5191.jpg 5745.jpg 5746.jpg 5945.jpg 5997.jpg6630.jpg 6631.jpg 6632.jpg 6633.jpg 6634.jpg 6635.jpg 6637.jpg 6638.jpg 6643.jpg 6646.jpg 6657.jpg 6720.jpg 6752.jpg 6753.jpg 6769.jpg 6770.jpg 7073.jpg 7105.jpg 7106.jpg 7269.jpg 7294.jpg7321.jpg 7323.jpg 7335.jpg 8365.jpg 8367.jpg 8481.jpg 8813.jpg 8922.jpg 8923.jpg 8924.jpg 9124.jpg 9125.jpg 9332.jpg 9741.jpg 9760.jpg
Also see: Photo 5871.jpePhoto 6482.jpePhoto 7320.jpe
