This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine Engine assembly (all NLA) Engine Gasket Kit Cylinder Block & Oil pan Cylinder Head & Rocker Cover Engine Mounting Piston & Crankshaft & Flywheel Front Cover & Cylinder Fitting Camshaft & Valve Mechanism Manifolds EGR Emission Controls Oil pump & Oil filter (oil strainer) Exhaust Tube & Muffler Water pump & Thermostat Radiator Accelerator Linkage
Fuel
Air Pollution Control Vacuum Control (engine vacuum hose routing) Carburetor Fuel Throttle (See EGI fuel injection) Fuel filter (fuel strainer) and Fuel Piping Fuel Pump Air Cleaner Fuel Tank & Fuel Piping
Power Train
Clutch Accessory Clutch Control Automatic Transmission * Accessory * Torque Convertor & Case * Oil Pump & Clutch * Planetary Gear * Control Valve * Control Switch * Fitting Manual Transmission * Accessory * Transmission Case * Transmission Gear * Shift Control * Transmission Control & Linkage * Propeller Shaft * Differential (Final Drive)
Brake
Hand Brake (Parking Brake Control) Front Brake Rear Brake Clutch & Brake Pedal Brake master cylinder Power Brakes Brake Piping
Chassis
Front Axle Rear Axle Road Wheel & Cap Steering Gear Steering Column Steering Linkage Steering wheel Steering Column Shell Front Suspension Rear Suspension Spare Tire Carrier
Electrical
Engine Electrical System Distributor Alternator Accessory & Mounting Starting Motor Wiring Harness Instrument Panel (Meter) Switch & Relay Battery Mounting Lamp Part Numbers * Head Lamp * Front Combination Lamp * Fog Lamp * Rear Combination Lamp * License Lamp & Side Reflectors
Body & Trim
Body Panels * Body Complete & Touchup Paint Front Grille & Fitting Rear Body Front Bumper Rear Bumper Body Side Moulding & Stripes Front Body Panels Cowl & Dash Fitting Dash Trimming Side Panel & Lock Glass Dashboard Seats Carpet Badges Paint Colors Doors Mirrors Visors Console Bonnet (Hood)
