Cylinder Head Identification
(Redirected from Cylinder head swapping)
Categories: Engine Mechanical | Cylinder Heads
At first glance, all A-series cylinder heads look alike. But by careful notice of specific features you can identify the model.
For the cylinder head, the best way to tell which head you have is to check the casting number in the valve train area (remove the rocker cover to look for this number).
If the head you are looking at does not have a casting
number, see the next section: Distinguishing Features.
Once you have the casting number, see Nissan Part Number Prefixes for a table of the different model to part numbers. For example, H23 means the part was originally designed for B110 GX models.
  • A10 may have "180", "H01", "257", "H03" or no markings at all
  • 1971-1973 A12 may have "180", "H10" or "H39". Some have no markings at all.
    3794.jpgAlbum 3794
  • A12 GX may have "H23" or "230"
  • 76 Sunny trucks (A12) may have M30, G25, G61
  • 1974 A13 may have "H62" or "620"
  • A14 could have several different ones, such as G32, H72 (or 728), H74, H75, H77, H78, H85, H92 or H98 depending upon year, country, and emission control design.
    5254.jpgAlbum 5254
  • M24 or 246 is A14T (Hitachi Twin Carb engine)
  • H85 is A12 or A13 (newer engines)
The casting number will be the first 3 digits of the last half of the part number, as all cylinder head part numbers begin with the same 5 digits (11041). For example:
11041-H2300 or 11041-H2301 HEAD ASSY-CYLINDER A12 GX
* 11041 is the base part number for all cylinder heads
* "H23" means the part was first used on the B110 GX vehicle.
* "728" is short for H728x, indicating a B210 "H72" part
references:
ID Marks
You may find many marks/engravings/casting numbers on a cylinder head. Original A12 heads have no marks. Remove the rocker cover to see the key marks.
These are the important marks:
26064.jpgAlbum 26064
For example, this head has rear mark 'H75'
6292.jpgAlbum 6292
Look up the Type mark at A-series Cylinder Heads
The front Mark can sometimes help further identify the head.
Early or Late?
To determine if the cylinder head is from a pre-1974, or 1974-onwards engine, check for the presence of an oil passage, located here:
15689.jpgAlbum 15689
Only pre-1974 engines will have this passage in the cylinder head, from factory. It is, however, possible for this oil passage to be drilled on a 1974-onwards engine. But it is a good indicator nonetheless.
For verification of an original, pre-1974 cylinder head, inspect the cylinder head for the following:
4588.jpgAlbum 4588
Pre-1974: Oil passage boss.
8122.jpgAlbum 8122
1974-onward: No oil passage boss present.
Any A-series cylinder head can be bolted onto any A-series engine block. However, compression ratio, port size (oval port, and round port), and manifold stud pattern need to be taken into consideration. Naturally, it is best to match port type, and size (e.g round port manifold, and round port cylinder head). The most critical difference, is the rocker shaft oil passage. It was relocated in 1974, as part of the A-series engine redesign.
Cylinder head oil passage
An extra oil passage in the cylinder head is required, for some engines. For pre-1974 engines, ensure your head gasket has the corresponding hole! You can punch, or drill, a hole in the head gasket if necessary.
Missing hole
25871.jpgAlbum 25871
A12 head gasket
22067.jpgAlbum 22067
22073.jpgAlbum 22073
Top: 1974, no oil passage. Bottom: 1973, with oil passage.
The older 1967-1973 head has the oil passage:
4587.jpgAlbum 4587
Boss, on the exterior, for cylinder head identification.
4588.jpgAlbum 4588
Comparison to 1974-onward cylinder head: no oil passage. The newer, redesigned engine has the oil passage in the engine block instead.
8122.jpgAlbum 8122
Late blocks do not send the oil up through the small passage, so do not need the hole in the gasket. Instead oil flow through the head bolt hole. So late blocks can work with either old or new heads. See Block_Comparison#Head_Oiling
Factory installed brass plug in late block
20443.jpgAlbum 20443
Interchangeability
Any cylinder head old or new can be used with old or new engine.
  • A pre-1974 cylinder head will bolt onto any engine block, with no modification required.
  • A 1974-onward engine block will work with any cylinder head. But, in the case of bolting a 1974-onward cylinder head to a pre-1974 engine block, a minor oil passage must be created.
27011.jpgAlbum 27011
Method 1:
I took off the head, marked it with the old head gasket, and drilled it on a 45° angle. junior
Method 2: Cut the head gasket between the oil feed hole and the center head bolt hole:
174_59a79dec6c22b.jpgPost 485962
Method 3:
I have seen a crude system where a 1200 head gasket was placed on the head to determine the position of the oil feed hole in the block. This was centerpunched & a very shallow hole was drilled. [about 1 to 1.5mm] then an angle grinder was used to grind a small trench across the gasket face to provide an oil passage froom this shallow hole to the nearest head bolt hole.
Crude as hell, but it worked. A very steady hand would be a prerequisite.
Personally, I would suggest a milling machine if this method is used.
question about oil blockage
Combustion Chamber
All Datsun A-series production cylinder heads have a wedge-shaped combustion chamber. However, most USA models are equipped with a cylinder head that is open-chambered, for lower NOx emissions. The 'heart-shaped' combustion chamber has a superior power output due to the closed-chamber design, with a large quench area.
3795.jpgAlbum 3795
  • A,B: Heart-shaped high-compression chamber - good for maximum power and fuel economy
    Also known as closed-chamber, peanut-shaped, butterfly-shaped or kidney-shaped.
  • C: 360° open chamber, for reduced emissions.
  • D: Bathtub chamber (from 1982 Sunny Truck G61 head).
Any combustion chamber design will work on any A-series engine.
The classic closed chamber is less likely to ping with low-octane fuel. When paired with flat-top pistons, it requires high octane fuel
30357.jpgAlbum 30357
Comparison - Closed Chamber vs. Open Chamber
PICT0370.jpg 26426.jpgAlbum 26426
Comparo: H23 vs H89 vs H10
20539.jpgAlbum 20539
Open Chamber (small CC, high compression, but nevertheless an open chamber)
11417.jpgAlbum 11417
Chamber Size
  • A12 closed chamber: 27-29cc
  • A12T: (M08 head) 32 +/- .5 per 1981 Nissan Racing book
    • for 11:1 with GX flat-top pistons, GX headgasket,
    • mill head 0.9mm (0.035 inch) for 25.6 cc
  • A12 GX: 29.1 cc (as per FIA papers)
  • H75: 31cc
  • H89: 29-31cc
  • H92: 31cc (A14E head) 29.1 +/- .5 per 1981 Nissan Racing book
  • H95: 35cc (A15 dish: 6cc)
See also: CCing
Intake Ports
  • Round - Best for low-RPM operation (more power under 4,000 RPM)
    1233.jpgAlbum 1233 6119.jpgAlbum 6119
    All A12s, later A13s, some A14s, and (reportedly) Vanette A15s.
  • Small oval (28 mm x 30 mm). The 1974 A13 has this design.
  • Small oval, with swirl obstruction. These are better for emissions and fuel economy (H95 head, 1981-1982 USA all engines)
    4444.jpgAlbum 4444
  • Regular oval (28 mm x 34 mm). These standard A14/A15 ports are best suited for high-RPM operation, or for the larger displacement engines.
    26285.jpgAlbum 26285 14888.jpgAlbum 14888 14886.jpgAlbum 14886 12714.jpgAlbum 12714
    NOTE: the top of the port comes up to the centerline of the top manifold studs.
  • ^Regular oval (28 mm x 34 mm) notched for injectors. A14E/A15E 92HP engines
The cylinder head for the A14 EFI engine has less intake and exhaust resistance.
Datsun Competition Tune-up Manual model N10 Series (March 1982 Pub. No. CT2E-0N10P0)
GX Oval vs. A14 Oval Comparison.
5215.jpgAlbum 5215
Top: GX ports go much higher than A14/A15 ovals.
Port Shape
Early head with oval ports is either an A12GX head, or its twin, the early A12T head from the Nissan Cherry (E10). These are the high-revving heads for the factory Hitachi Twin Carb engines.
Exhaust Ports
All heads have nearly square exhaust ports.
th_469.jpgAlbum click to view
Intake Ports
* Round port 28mm: A12
* Round port 28mm lowered: A14 GFU
* Small Oval port 28x30mm: A13, A12A
* Medium Oval port 28x34mm: A14
* Large Oval port 30x34.5mm: A12GX Engine
Port Sizes
PortsSize (mm)ExhaustRaisedNote
round2827x26no1971 A12
round28?lowered1977 GFU
Oval - Small28x30?no1973 A13
Oval - Medium28x3228x26noA14E, A15E
Oval - Regular28x3428x26noMany A14s
Oval - Large (GX)30x35 - 3627x29 or 28x26YesA12GX (1971-1973)
GX extra-large oval ports (36 mm tall)
20540.jpgAlbum 20540
Port Comparison
Wet, Dry Intake Manifolds
Coolant passages are below the intake ports (present or not). If present, they can be large holes or small holes.
Intake/Exhaust manifold bolt pattern
Early A12 differs from the A14. A12 changed in 1976, but A12 Wagons and Trucks continue to use the old pattern until 1979-1980.
982_.jpgAlbum click to view
Top: New bolt pattern
18992.jpgAlbum 18992
Bottom: Original bolt pattern
The bolt pattern on the cylinder heads also differ. early A10/A12 heads are only drilled for the older pattern. Newer A12 (1980s/1990s) are drilled for newer pattern. Some newer heads are drilled for both.
4440.jpgAlbum 4440
Bolt pattern
Valve Springs
The following A-series heads had dual valve springs. There is a small-diameter spring inside the main spring.
So dual springs are a good indication of a special head, but not conclusive. You will need to check the intake port sizes and other features to make a final determination.
Valves
All A-series engine use valves with 8mm diameter stem
ValvesIntake Part No.In. SizeExhaust Part No.Ex. SizeLength
A10, early A12, late A12 Van13201-H100035mm13202-1800029mm103.8
A12GX/A12T13201-H230035mm13202-H230029mm103.8
Late A12, A13, A12AS13201-H230035mm13202-H740029mm103.8
A13(1974),A14 & A1513201-H620037mm13202-H6200, 13202-H890030mm103.8
A12A, A14, A15 1981-82 USA13201-H950035mm13202-H950030mm100.0
A12A, A14, A15 1981-82 canada13201-H620037mm13202-H620030mm103.8
Nissan Competition tuliped99996-H110037mm99996-H110030mm103.8
A12GX Identification
A true A12GX cylinder head has all these features:
  • Dual valve springs
  • No casting numbers
  • Large Oval port 30x34.5mm. These ports are raised, and extend above upper intake bolts
  • 27x29 mm exhaust ports
  • closed combustion chamber - heart shaped, large size combustion chamber of 29.1 cm3
  • large water holes (one under each intake port). Each hole is about the diameter of a pencil (non-GX heads have small holes)
  • Seven upper intake face bolts, nine bolt holes (vs only 5 for other pre-74 heads)
  • As with all pre-74 heads, Oil passage on head face (spark plug side), oil boss on side face between plugs 2 & 3 just above head face
  • SAME valve sizes as standard A12: 29mm exhaust, 35mm intake
  • NO bosses on sparkplug side between 1&2 and 3&4
One way to identify a GX, when the head is still installed: Look for the oil passage boss (indicating an early head), and for seven studs on the top of the inlet/exhaust manifold gasket. This combination is a good indicator of an GX (or early A12T) head. Regular early heads have only five studs along the top of the gasket.
  • 5 mm water ports below the intake ports
  • closed chambers
  • oil hole between push rod holes for Nos. 2 & 3 cylinders
GX and A12T (non-GX) heads have small bulges on the top side (for the raised manifold bolts):
23095.jpgAlbum 23095
Datsun Competition heads have raised ports ceilings visible on the top face.
A12GX vs A12T
Datsun B210 twin carb A12 engine (A12T) uses a cylinder head nearly identical to A12GX. Differences include:
  • Block face missing oil passage hole on B210 head
  • Spark side threaded boss for B210 fuel rail
  • Front side threaded boss for B210 high-mounted alternator bracket
  • Rear face: no obvious differences
  • Manifold face: no obvious differences
26105.jpgAlbum 26105 26106.jpgAlbum 26106 26107.jpgAlbum 26107 26108.jpgAlbum 26108 26109.jpgAlbum 26109
Four Sides
Head Front Face
3-bolt
1293.jpgAlbum 1293
5-bolt
776.jpgAlbum 776 13032.jpgAlbum 13032
Block-off plug for AIS hole
Block-off plate for AIS hole
23098.jpgAlbum 23098
Rear Face
WATER OUTLET
early: low
late:  high
BOLT HOLE BOSSES
* none
* all the way to the left side
* bolt holes in center
No bolts, high water outlet (original A12/13 style)
30358.jpgAlbum 30358 28762.jpgAlbum 28762
Left bolts, low water outlet
Mid-bolts, high water outlet
18300.jpgAlbum 18300
Undrilled bolt bosses
16432.jpgAlbum 16432
Air passage head casting H72 (air passage might not be drilled)
22084.jpgAlbum 22084
H75 (air passage undrilled)
30419.jpgAlbum 30419
Spark-side Bosses
Look at the accessory/bracket mounting holes to help identify a cylinder head.
Variations
* No bosses
* One boss (between #1 and #2 near top)
* Two boss (between 1-2, 3-4)
* Three boss (between 1-2, 3-4, plus a front boss)
The bosses are used on newer engines for the fuel rail and Air Injection/Air Induction (EAI) pipes.
Three boss. Two top bosses and a front boss
8122.jpgAlbum 8122
Three boss with oil passage
22086.jpgAlbum 22086
No bosses. A10 or Early A12
18298.jpgAlbum click to view
No bosses. Early heads used a fuel rail that bolts to the valve cover
4588.jpgAlbum 4588
One boss (undrilled)
15690.jpgAlbum click to view
One boss (drilled):
3640.jpgAlbum click to view
Two boss (example: G25 sunny truck head 1979-1989 and G61 1989-1994)
26231.jpgAlbum 26231
Air Induction (EAI) Pipe Brackets (B310.A13 shown)
Manifold-side Bosses
Variations
* No boss
* Front boss only
* Rear boss only
* Both Front and Rear bosses
In addition, bosses can be present but not drilled & tapped. For example, an H72 casting can be processed either way (drilled or undrilled). The difference merits a different Part Number, for example H72 casting part number 11041-H7200 and H72 casting part number 11041-H7240.
Front Boss location
Various fittings can be inserted: Plugs, switches or valves
8226.jpgAlbum 8226
Rear boss location
No Boss
Without boss, early A14
Without boss, 5-bolt face:
2547.jpgAlbum 2547
Undrilled Boss
A12 with boss, not drilled (late B110)
4587.jpgAlbum 4587
A14 with front boss undrilled
5215.jpgAlbum 5215
Front Boss Drilled & Tapped
With boss (fitted with vacuum switch in this photo)
14137.jpgAlbum 14137
Late A12
1233.jpgAlbum 1233
Front and Rear Bosses
Both bosses drilled and tapped (H72 107 industrial A14)
11415.jpgAlbum click to view
With rear boss not drilled, front boss drilled
2983.jpgAlbum 2983
Blank rear boss, tapped front boss
6290.jpgAlbum 6290
With rear boss drilled, front boss undrilled
5249.jpgAlbum 5249
5250.jpgAlbum 5250
Rear Boss Only
With rear boss (no front boss) H89
1234.jpgAlbum 1234
Alternator Mounting
Left Side
Early A-series engine (front distributor) mounted the alternator on the left side of engine, because the distributor and oil pump are on the right side.
  • B10,B110,E10: on left side of engine, down low
  • Upper bracket bolts to front face of head
15170.jpgAlbum 15170 7891.jpgAlbum 7891
Right Side
Late A-series engine moved the distributor to mid-block, freeing up room for a right-mounted alternator.
  • B210, some B310: up high
    • Upper bracket bolts to Upper bolt hole on head
  • Some B310: up low
    • Upper bracket bolts to lower bolt hole on head
3265.jpgAlbum 3265
Visual ID
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Cylinder_Head_Identification"
This page has been accessed 180,040 times. This page was last modified 06:37, 5 July 2025. Content is available under Datsun 1200 Club.
