Part Numbers Index
Revision as of 23:35, 29 April 2012; view current revision
Category: Catalog
This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
GROUP 01
001 Engine 001 ENGINE ASSEMBLY (all NLA)
002 Engine Gasket Kit Repair Kit, Regrind Kit
003 Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN
* Timing Chain Cover, Cylinder Liner
004 Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT
005 Emission Control EMISSION CONTROL DEVICE
006 Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD
* flywheel, flex plate, cam bearings
007 Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN
008 Manifold MANIFOLD intake, exhaust
009 Exhaust Tube & Muffler -- See Chassis section below
010 Oil Pump OIL PUMP & OIL STRAINER (oil filter)
011. Carburetor -- see Fuel section below
011A Carburetor, Exhaust Type -- see Fuel section below
011B Carburetor with Auto Choke -- see Fuel section below
012 Air Cleaner -- see Fuel section below
013 Fuel Strainer -- see Fuel section below
014 Fuel Pump -- see Fuel section below
015 Fuel Tank, Sedan -- see Chassis section below
016 Fuel Tank, Coupe -- See Chassis section below
018. Fuel Strainer, Sedan -- see Fuel section below
018A Fuel Strainer, Coupe -- see Fuel section below
019 Accelerator Pedal & Choke Control, see Chassis section below
020 Water Pump WATER PUMP & FAN
021 Radiator -- See Chassis section below
022 Engine Mounting -- See Chassis section below
Fuel
011. Carburetor CARBURETOR(CRANK) with Manual Choke
011A Carburetor CARBURETOR(EXHAUST & EVAPO) with Manual Choke
011B DCH Carburetor CARBURETOR with Auto Choke
011C GX Carburetor CARBURETOR (TWIN)
012 Air Cleaner AIR CLEANER To May 1971
012A GX Air Cleaner AIR CLEANER (GX)
013 Fuel Strainer -- see 018
014 Fuel Pump FUEL PUMP
018. Fuel Piping FUEL STRAINER & PIPING
Engine Electrical
Engine Control
Accelerator Linkage -- See Chassis section below
Choke Cable -- See Chassis section below
Chassis & Body
Engine Support
009 Exhaust EXHAUST TUBE & MUFFLER
015. Sedan Fuel Tank FUEL TANK(SEDAN)
015A Sedan Fuel Tank FUEL TANK(SEDAN EVAPO)
016. Coupe Fuel Tank FUEL TANK(COUPE)
016A Coupe Fuel Tank FUEL TANK(COUPE EVAPO)
019 Engine Control ACCELERATOR PEDAL & CHOKE CONTROL
021 Radiator
022 Engine Mounting
Power Train
GROUP 03
042 Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER
043 Hydraulic Clutch Pedal CLUTCH PEDAL (Hydraulic Clutch)
044 Clutch Cylinder CLUTCH MASTER CYLINDER
045 Clutch Cylinder CLUTCH OPERATING CYLINDER
046 Transmission Assembly TRANSMISSION ASSEMBLY(4 SPEED)
050 F4W56L Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE To March 1973
050A F4W56A Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE From April 1973
051 F4W56L Gear TRANSMISSION GEAR(4 SPEED) To March 1973
051A F4W56A Gear TRANSMISSION GEAR(4 SPEED) From April 1973
052 F4W56L Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To March 1973
052A F4W56A Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To From April 1973
055A Automatic Transmission Case TRANSMISSION CASE & FITTING(AUTOMATIC 3N71B)
055B Automatic Transmission Gear TRANSMISSION GEAR(AUTOMATIC 3N71B)
055C Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE(AUTOMATIC 3N71B)
055D Automatic Transmission Valve CONTROL VALVE(AUTOMATIC 3N71B)
056 Propeller Shaft PROPELLER SHAFT
057 Differential GEAR CARRIER & GEAR
059 Automatic Transmission Control TRANSMISSION CONTROL FLOOR SHIFT TYPE(AUTOMATIC)
Axle
GROUP 04
060 Front Axle FRONT AXLE, ROAD WHEEL & TIRE
061 Front Suspension FRONT SUSPENSION(STRUT, SHOCK ABSORBER)
062 Rear Axle REAR AXLE, ROAD WHEEL & TIRE
063 Rear Suspension REAR SUSPENSION(SPRING LEAF, SHOCK ABSORBER)
Brake
GROUP 05
064 Hand Brake HAND BRAKE & HAND BRAKE CABLE
065 Front Drum Brake FRONT BRAKE(DRUM TYPE)
065A Disc Brake FRONT BRAKE(DISC TYPE)
066 Rear Brake REAR BRAKE & WHEEL CYLINDER(FOR FRONT DRUM BRAKE)
066A Rear Brake REAR BRAKE & WHEEL CYLINDER(FOR FRONT DISC BRAKE)
067 Brake Piping BRAKE PIPING(TANDEM)
068 Brake Pedal BRAKE PEDAL
070 Tokico Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM TOKICO) To September 1971
070A Nabco Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM NABCO) To September 1971
070B Tokico Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM TOKICO) From October 1971
070C Nabco Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM NABCO) From October 1971
Steering
GROUP 06
072 Steering Gear STEERING GEAR(COLLAPSIBLE) includes Steering Column
073 Steering Linkage STEERING LINKAGE
074 Steering Wheel STEERING WHEEL & STEERING LOCK
Electrical
GROUP 02
Engine Electrical System
023 Distributor DISTRIBUTOR(CRANK)
023A Distributor DISTRIBUTOR(EXHAUST & EVAPO)
024 Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG
  * includes Alternator Mounting
025A Alternator & Regulator ALTERNATOR & REGULATOR
025C ALTERNATOR(HITACHI)
026 Starter Motor STARTER MOTOR
Body Electrical System
027 Wiring includes Wiring Harness
028 Switch SWITCHES, FLASHER UNIT, HORN & CIGARETTE LIGHTER
* Includes Electrical Unit, Instrument, Switch & Relay
029A Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND)
* includes instrument panel
* includes temperature gauge sender (thermal transmitter)
030. Room Heater & Ventilator
030A Room Heater, Heavy Duty
030C Ventilator
031 Radio & Clock RADIO,ANTENNA & CLOCK
033 Battery (see Front Body Panels for Battery Mounting)
034 Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE
035 Wiper & Washer WINDSHIELD WASHER
036 Head Light HEAD LAMP
037 Front Combination Lamp Part Numbers FRONT COMBINATION LAMP
038 SIDE MARKER LAMP Side Lighting
039 Sedan Rear Combination Lamp REAR COMBINATION LAMP(SEDAN)
39A Coupe Rear Combination Lamp REAR COMBINATION LAMP(COUPE)
040 License Lamp LICENCE LAMP(SEDAN)
040A License Lamp LICENCE LAMP(COUPE)
041 Room Lamp ROOM LAMP (Dome Light)
Body & Trim
Sedan
GROUP 07 BODY (SEDAN)
081 Grille RADIATOR GRILLE & FRONT BUMPER(SEDAN)
082 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(SEDAN)
    * includes Radiator Core Support & front apron/valence
    * includes battery support frame/box
083 Hood Lock HOOD LOCK CONTROL(SEDAN)
084 Cowl COWL TOP & COWL TOP GRILLE(SEDAN)
085 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(SEDAN)
086 Dash Trim GLOVE BOX & ASH TRAY(SEDAN)
087 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(SEDAN)
088 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(SEDAN)
089 Floor FLOOR PANEL, INSULATOR & SPARE WHEEL HANDLE(SEDAN)
090 Floor Trim FLOOR MAT, KICKING PLATE & CONSOLE BOX(SEDAN) includes carpet
091 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(SEDAN 2 DOOR)
092 Body Side Trim BODY SIDE FITTING & MOULDING(SEDAN)
093 Interior Side Trim BODY SIDE TRIMMING(SEDAN) includes ash tray & weatherstripping
094 Rear Body REAR FENDER & REAR PANEL(SEDAN) includes parcel tray & fuel door
095 Rear Window SIDE WINDOW & REAR WINDOW(SEDAN)
096 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(SEDAN 2 DOOR)
097 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(SEDAN 2 DOOR)
098 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(SEDAN 2 DOOR)
105 Trunk & Bumper TRUNK & REAR BUMPER(SEDAN) (boot)
106 Front Seat FRONT SEAT(SEDAN)
107 Rear Seat REAR SEAT(SEDAN)
108 Seat Accessories SAFETY BELT & HAND REST(SEDAN)
Coupe
GROUP 08 BODY (COUPE)
111 Grille RADIATOR GRILLE & FRONT BUMPER(COUPE)
112 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(COUPE)
113 Hood Lock HOOD LOCK CONTROL(COUPE)
114 Cowl COWL TOP & COWL TOP GRILLE(COUPE)
115 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(COUPE)
116 Dash Trim GLOVE BOX & ASH TRAY(COUPE)
117 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(COUPE)
118 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(COUPE)
119 Floor FLOOR PANEL & FITTING(COUPE)
120 Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX(COUPE)
121 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(COUPE)
122 Body Side Trim BODY SIDE FITTING & MOULDING(COUPE)
123 Interior Side Trim BODY SIDE TRIMMING(COUPE) includes ash tray & weatherstripping
124 Rear Body REAR FENDER & REAR PANEL(COUPE) includes parcel tray & fuel door
125 Rear Window SIDE WINDOW(COUPE)
126 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(COUPE)
127 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(COUPE)
128 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(COUPE)
129 Rear Window REAR WINDOW(COUPE)
130 Trunk & Bumper TRUNK LID & REAR BUMPER(COUPE) (boot)
131 Trunk Fitting TRUNK ROOM TRIMMING(COUPE) (boot)
132 Front Seat FRONT SEAT(COUPE)
133 Rear Seat REAR SEAT & TONNEAU COVER(COUPE)
134 Seat Accessories SAFETY BELT & HEAD REST(COUPE)
Truck
101a Cowl Cowl top and seals
101b/311 Grille RADIATOR GRILLE & FRONT BUMPER includes Radiator Core Support
* includes Grille Badge
103 Hood Hinge & Lock
812 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD
882 Hood Ledge Part Numbers HOOD LEDGE
882 Dash Fitting Part Numbers DASH FITTING
104 Front Window includes trimming
105 Instrument
106 Floor Trimming includes Dash Trimming
107 Floor Fitting includes Front Floor Trimming & Console Box
108 Dash Side Trimming includes Body Side Trimming & Roof Trimming
109 Door includes Hinge & Door Fitting
110 Door Window & Lock includes Door Handle & Regulator
111 Seat include Head Restraint フロント シート <トリム>
112 Body Side Fitting includes Back Window
840 Floor FLOOR PANEL フロア パネル
Miscellaneous
GROUP 09
167 Emblem EMBLEM (Badges)
168 Key & Cylinder KEY & CYLINDER
169 Key & Cylinder BLANK KEY
170 Model Plate MODEL NO. PLATE
171 Paint TOUCH-UP PAINT
172 Coolant LONG LIFE COOLANT & N.C.S. SEALER
173 Tool Kit TOOL KIT includes Jack
173A Special Tool SPECIAL TOOL
175 Leather Top LEATHER TOP (Vinyl Roof)
