Part Numbers Index
Revision as of 09:31, 28 June 2012; view current revision
Category: Catalog
This is an index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts from Nissan can sometimes be found on eBay or other sellers (NOS or "New Old Stock").
Engine & Engine Control
GROUP 01
Engine
001  Engine ENGINE ASSEMBLY (all NLA)
002  Engine Gasket Kit Repair Kit, Regrind Kit
003  Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN
     * Timing Chain Cover, Cylinder Liner
004  Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT
005  Emission Control EMISSION CONTROL DEVICE
006  Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD
     * flywheel, flex plate, cam bearings
007  Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN
008  Manifold MANIFOLD intake, exhaust
009  Exhaust Tube & Muffler -- See Chassis section below
010  Oil Pump OIL PUMP & OIL STRAINER (oil filter)
011  Carburetor — see Fuel section below
011A Carburetor, Exhaust Type — see Fuel section below
011B Carburetor with Auto Choke — see Fuel section below
012  Air Cleaner — see Fuel section below
013  Fuel Strainer — see Fuel section below
014  Fuel Pump — see Fuel section below
015  Fuel Tank, Sedan — see Chassis section below
016  Fuel Tank, Coupe — See Chassis section below
018  Fuel Strainer, Sedan — see Fuel section below
018A Fuel Strainer, Coupe — see Fuel section below
019  Accelerator Pedal & Choke Control, see Chassis section below
020  Water Pump WATER PUMP & FAN
021  Radiator — See Chassis section below
022  Engine Mounting — See Chassis section below
Fuel
011  Carburetor (CRANK) with Manual Choke
011A Carburetor (EXHAUST & EVAPO) with Manual Choke
011B DCH Carburetor with Auto Choke
011C GX Carburetor (TWIN)
012  Air Cleaner To May 1971
012A GX Air Cleaner
013  Fuel Strainer — see 018
014  Fuel Pump
018  Fuel Piping & STRAINER
Engine Electrical
Engine Control
Accelerator Linkage — See Chassis section below
Choke Cable — See Chassis section below
Chassis & Body
Engine Support
009  Exhaust & MUFFLER
015  Sedan Fuel Tank (SEDAN)
015A Sedan Fuel Tank (SEDAN EVAPO)
016  Coupe Fuel Tank (COUPE)
016A Coupe Fuel Tank (COUPE EVAPO)
019  Engine Control ACCELERATOR PEDAL & CHOKE CONTROL
021  Radiator
022  Engine Mounting
Power Train
GROUP 03
042 Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER
043 Hydraulic Clutch Pedal CLUTCH PEDAL (Hydraulic Clutch)
044 Clutch Cylinder CLUTCH MASTER CYLINDER
045 Clutch Cylinder CLUTCH OPERATING CYLINDER
046 Transmission Assembly
    F5C56A Case
050 F4W56L Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE To March 1973
050A F4W56A Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE From April 1973
051 F4W56L Gear TRANSMISSION GEAR(4 SPEED) To March 1973
051A F4W56A Gear TRANSMISSION GEAR(4 SPEED) From April 1973
052 F4W56L Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To March 1973
052A F4W56A Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To From April 1973
055A Automatic Transmission Case TRANSMISSION CASE & FITTING(AUTOMATIC 3N71B)
055B Automatic Transmission Gear TRANSMISSION GEAR(AUTOMATIC 3N71B)
055C Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE(AUTOMATIC 3N71B)
055D Automatic Transmission Valve CONTROL VALVE(AUTOMATIC 3N71B)
056 Propeller Shaft PROPELLER SHAFT
057 Differential GEAR CARRIER & GEAR
059 Automatic Transmission Control TRANSMISSION CONTROL FLOOR SHIFT TYPE(AUTOMATIC)
Axle
GROUP 04
060 Front Axle FRONT AXLE, ROAD WHEEL & TIRE
061 Front Suspension FRONT SUSPENSION(STRUT, SHOCK ABSORBER)
062 Rear Axle REAR AXLE, ROAD WHEEL & TIRE
063 Rear Suspension REAR SUSPENSION(SPRING LEAF, SHOCK ABSORBER)
Brake
GROUP 05
064  Hand Brake & HAND BRAKE CABLE
065  Front Drum Brake FRONT BRAKE(DRUM TYPE)
065A Disc Brake FRONT BRAKE(DISC TYPE)
066  Rear Brake & WHEEL CYLINDER(FOR FRONT DRUM BRAKE)
066A Rear Brake & WHEEL CYLINDER(FOR FRONT DISC BRAKE)
067  Brake Piping (TANDEM)
068  Brake Pedal
070  Tokico Brake Master Cylinder (TANDEM) To September 1971
070A Nabco Brake Master Cylinder (TANDEM) To September 1971
070B Tokico Brake Master Cylinder (TANDEM) From October 1971
070C Nabco Brake Master Cylinder (TANDEM) From October 1971
Steering
GROUP 06
072 Steering Gear STEERING GEAR(COLLAPSIBLE) includes Steering Column
073 Steering Linkage STEERING LINKAGE
074 Steering Wheel STEERING WHEEL & STEERING LOCK
Electrical
GROUP 02
Engine Electrical System
023  Distributor (CRANK)
023A Distributor (EXHAUST & EVAPO)
024  Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG
     * includes Alternator Mounting
025A Alternator & Regulator
025C ALTERNATOR(HITACHI)
026  Starter Motor
Body Electrical System
027  Wiring includes Wiring Harness
028  Switch & FLASHER UNIT, HORN & CIGARETTE LIGHTER
     * Includes Electrical Unit, Instrument, Switch & Relay
029A Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND)
     * includes instrument panel
     * includes temperature gauge sender (thermal transmitter)
030  Room Heater & Ventilator
030A Room Heater, Heavy Duty
030C Ventilator
031  Radio & Clock & ANTENNA
033  Battery (see Front Body Panels for Battery Mounting)
034  Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE
035  Wiper & Washer WINDSHIELD WASHER
036  Head Light HEAD LAMP
037  Front Combination Lamp
038  Side Lighting SIDE MARKER LAMP
039  Sedan Rear Combination Lamp
039A Coupe Rear Combination Lamp
040  License Lamp (SEDAN)
040A License Lamp (COUPE)
041  Room Lamp (Dome Light)
Body & Trim
Sedan
GROUP 07 BODY (SEDAN)
081 Grille RADIATOR GRILLE & FRONT BUMPER(SEDAN)
082 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(SEDAN)
    * includes Radiator Core Support & front apron/valence
    * includes battery support frame/box
083 Hood Lock HOOD LOCK CONTROL(SEDAN)
084 Cowl COWL TOP & COWL TOP GRILLE(SEDAN)
085 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(SEDAN) includes package tray
086 Dash Trim GLOVE BOX & ASH TRAY(SEDAN)
087 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(SEDAN)
088 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(SEDAN)
089 Floor FLOOR PANEL, INSULATOR & SPARE WHEEL HANDLE(SEDAN)
090 Floor Trim FLOOR MAT, KICKING PLATE & CONSOLE BOX(SEDAN) includes carpet
091 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(SEDAN 2 DOOR)
092 Body Side Trim BODY SIDE FITTING & MOULDING(SEDAN)
093 Interior Side Trim BODY SIDE TRIMMING(SEDAN) includes ash tray & weatherstripping
094 Rear Body REAR FENDER & REAR PANEL(SEDAN) includes parcel tray & fuel door
095 Rear Window SIDE WINDOW & REAR WINDOW(SEDAN)
096 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(SEDAN 2 DOOR)
097 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(SEDAN 2 DOOR)
098 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(SEDAN 2 DOOR)
105 Trunk & Bumper TRUNK & REAR BUMPER(SEDAN) (boot)
106 Front Seat FRONT SEAT(SEDAN)
107 Rear Seat REAR SEAT(SEDAN)
108 Seat Accessories SAFETY BELT & HAND REST(SEDAN)
Coupe
GROUP 08 BODY (COUPE)
111 Grille RADIATOR GRILLE & FRONT BUMPER(COUPE)
112 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(COUPE)
113 Hood Lock HOOD LOCK CONTROL(COUPE)
114 Cowl COWL TOP & COWL TOP GRILLE(COUPE)
115 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(COUPE) includes Package Tray
116 Dash Trim GLOVE BOX & ASH TRAY(COUPE)
117 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(COUPE)
118 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(COUPE)
119 Floor FLOOR PANEL & FITTING(COUPE)
120 Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX(COUPE)
121 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(COUPE)
122 Body Side Trim BODY SIDE FITTING & MOULDING(COUPE)
123 Interior Side Trim BODY SIDE TRIMMING(COUPE) includes ash tray & weatherstripping
124 Rear Body REAR FENDER & REAR PANEL(COUPE) includes parcel tray & fuel door
125 Rear Window SIDE WINDOW(COUPE)
126 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(COUPE)
127 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(COUPE)
128 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(COUPE)
129 Rear Window REAR WINDOW(COUPE)
130 Trunk & Bumper TRUNK LID & REAR BUMPER(COUPE) (boot)
131 Trunk Fitting TRUNK ROOM TRIMMING(COUPE) (boot)
132 Front Seat FRONT SEAT(COUPE)
133 Rear Seat REAR SEAT & TONNEAU COVER(COUPE)
134 Seat Accessories SAFETY BELT & HEAD REST(COUPE)
Truck
101 Front View includes RADIATOR GRILLE, FRONT BUMPER, COWL TOP GRILLE and mirrors
 Radiator Grille
 Front Bumper
 Cowl Cowl top, grille and seals
 Wing Mirror
102 Hood Ledge & Dash Fitting
 882 Hood Ledge Part Numbers HOOD LEDGE
 882 Dash Fitting Part Numbers DASH FITTING
103 Hood Hinge & Lock
 Hood Hinge
 Hood Lock Control
104 Front Window includes trimming
 Windshield
 Rear-view (Inside) Mirror
 Sunvisor
105 Instrument Includes dash PAD, trim, GLOVE BOX & ASH TRAY
 * & PACKAGE TRAY, FLARE HOLDER
106 Floor Trimming
 Dash Trimming
 Floor Trimming
107 Floor Fitting
 Front Floor Fitting
 Console Box
108 Dash Side Trimming
 Dash Side Trimming
 Body Side Trimming
 Roof Trimming
109 Door
 Door 109a
 Door Hinge
 Door Fitting 109b
 Door Trimming
 Side Visor
110 Door Window & Lock
 Door Window
 Door Lock & Remote Control
 Door Handle & Regulator
111 Seat フロント シート <トリム>
 Seat
 Head Restraint
 Safety Seat Belt
112 Body Side Fitting
 Side Moulding includes side vent
 Fuel Filler Door
 Rear Bumper
 Back Window
 Rear Gate Fitting
 Rear Floor Fitting
113 Front Body Panel 812
 Radiator Core & Apron Panel
 Front Fender Panel
 Hood Ledge & Hood Panel
114 Dash Panel
 Dash Panel
 Front Floor Panel
 Front Pillar Panel
 Roof Panel
 Back Lower Panel
115 Rear Body Panel (Short Body)
116 Rear Body Panel (Long Body) includes Center Bearing Bracket
 Rear Body Side Panel
 Rear Floor Panel 840 フロア パネル
 Back Panel
 Rear Gate Panel
117 Key Set
Label
Miscellaneous
GROUP 09
167  Emblem (Badge/Mark)
168  Key & Cylinder
169  Key & Cylinder BLANK KEY
170  Model Plate MODEL NO. PLATE  プレート、モデル ナンバー
171  Paint TOUCH-UP PAINT
172  Coolant LONG LIFE COOLANT & N.C.S. SEALER
173  Tool Kit includes Jack
173A Special Tool
175  Leather Top (Vinyl Roof)
