Toyota 4A engine
Revision as of 03:53, 15 March 2009; view current revision
Category: Engine Modifications
The Toyota 4A engine variations are a popular swap into Datsun 1200s. These are 1600cc engines, so are a significant upgrade in terms of cubic inches alone. However, it is the DOHC 4AGE that shines with impressive power. Also notable is the 4AGEZ supercharged engine from the Toyota MR2.
NOTE to newbys: Beware of mentioning rotary-powered or Toyota 4AGE-powered 1200s. Some club members may get offended! But really, these are also excellent engines that fit in fairly well. Just don't tell anybody ;-)
Counterpoint: The 4AGE weighs the same as the better engine... Nissan's CA18DE. The CA18DE is 200cc larger, has bigger everything. So you can get away with the same mods as a 4age and get more power.
The biggest thing that has to be done was a fabricated header, because the 4A manifold is large and does not clear the LHD steering box. You may not have any trouble with a RHD car.
Swap Overview
The conversion isn't bolt-on its all fab work:
  • Engine mounts
  • Gearbox mount
  • Custom cooling system pipes
  • Custom exhaust
No one sells a "kit" to fit the 4AGE into a Datsun 1200.
FWD 4AGE's use a distributor which ends up in the 1200 glovebox and heater/demister box. This means modifying all that. That isn't easy. It's almost always a FWD engine in Australia, unless you can get a Japanese RWD AE86 Engine.
Source for Engine
RWD 4A Engines
  • AE71 was the 1983 Corolla, with carbureted 4AS SOHC engine.
  • AE85/AE86 was the last RWD series (1984-1986) with fuel injected DOHC 4AGE engine
826.jpg Toyota Twin-Cam
4AGE 16V engine is arguably one of the best 1.6 litre motors ever put together. 75KW to 100KW power ratings. The suzuki g13b or g16b weigh 15kgs less than an a15. At around 80kgs the nearest rival is the 4age at 130kg. 108 rwhp from a stock 4AGE.
4AGE 20V engine: 120 kw.
  • 4065
4AGZE: factory supercharged motor with about 135KW. It has stronger con-rods and pistons fitted as standard, thus more suited to forced induction without much change. They are 25kgs lighter than a Nissan CA18DET engine. Most people take off the supercharger and place on a turbo for much better performance and then loosely call it a "4AGTE".
Formula Atlantic 4AGE puts out 240 bhp.
Gearbox
Use the gearbox that came with the engine. Don't try to fit it to the Datsun gearbox, because the Toyota box is much stronger.
There is just enough room for the t50 in a Datsun 1200 manual tunnel. The 1200's speedometer cable screws straight on.
T50 tranmission is less expensive than the Supra W55 box & plenty strong enough for the 4AGE. They've been putting them behind 5 litre Holden & Ford V8's for years. The w55 conversion for 4AGE is $1000-up (for new parts), not including the w55 itself. Don't have to cut the tunnel, put in a T50 5 speed, just cut off the two mounts in the tunnel, cleanly and the box fits perfectly.
T50 is good to handle the torque from a 4AGE, but not from a 4AGZE (supercharged engine). A turbo conversion should be OK at low boosts. Otherwise you'll need a stronger tranmission like this one:
[1]
For drag racing, an automatic is fastest. Use Ford C4, or Toyota Trimatic. Both require custom bellhousing.
Since this is not Datsun-specific, For more details, search http://www.toyota-mods.org/ or visit http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Gearboxe s.html
Differential
The AE86 rear live axle assembly is strong, and bolts into the Datsun 1200. Put the whole thing in there, and use the Toyota wheels while you're at it.
Projects
DatsunDonnie
Donnie in Victoria, Canada has a fantastic 4AGE-powered 2-door sedan:
Had it at the drags the other night-15.95@86mph sound good? 7100 RPM through the traps!
Donnie used the stock Datsun 1200 radiator.
Kululadotgroen
In Rooihuiskraal there is this one:
Also see: Kululadotgroen article
9486.jpg 9487.jpg 9489.jpg 9490.jpg 9491.jpg 9492.jpg 9493.jpg 9494.jpg 9495.jpg 9496.jpg 9497.jpg 9498.jpg 9499.jpg 9505.jpg 9506.jpg 9507.jpg 9508.jpg 9509.jpg 9510.jpg 9511.jpg 9512.jpg 9513.jpg 9514.jpg 9515.jpg 9516.jpg 9517.jpg 9518.jpg 9519.jpg 9520.jpg 9521.jpg 9522.jpg 9523.jpg 9524.jpg 9525.jpg 9526.jpg 9668.jpg 9669.jpg 9670.jpg 9671.jpg 9672.jpg 9673.jpg 9674.jpg 9675.jpg 9676.jpg 9677.jpg 9678.jpg 9679.jpg 9680.jpg 10833.jpg 10835.jpg 10952.jpg 10953.jpg 10954.jpg 12440.jpg 12441.jpg 12442.jpg 12662.jpg 12670.jpg 12671.jpg 12672.jpg 12673.jpg 12674.jpg 12675.jpg 12676.jpg 12692.jpg 12693.jpg 12896.jpg 13128.jpg 13129.jpg 13377.jpg 13378.jpg 13379.jpg 13380.jpg 14068.jpg 14365.jpg 14388.jpg 14389.jpg 15122.jpg 15123.jpg 15124.jpg 15125.jpg
Jason's 1200 Coupe
Out of Vancouver, WA: 1609.jpg 4003.jpg
  • Toyota 4AGE DOHC engine
  • Toyota T50 5-speed
  • Corolla EFI fuel tank is in the back compartment
  • 77 Corolla SR5 rear with LSD pumpkin
  • 175/70R-13 tires
3Rotor
See all pics from 10936 - 10947, starting with:
Wogboy
Turbo conversion
The clutch is original datto 1200. I used the datsun clutch fork and cut the opposite side of the bellhousing on the t50. Then is used the toyota thrust race, ground down the datto clutch fork to clear , then welded a couple of allen keys(strong steel) to reinforce the clutch fork. The result was the sweetest clutch action I have ever felt. Lucky but amazing.So I have a mechanical clutch.
Normo's Ute
(now sold)
4639.jpg 4642.jpggearbox crossmember
Swap Notes
9499.jpg Sump Fitment
The 4A has a front sump oil pan, actually shorter than the a12, so you can position it lower in the chassis.
9494.jpg front clearance
9491.jpg rear clearance
9508.jpg Air Inlet
9495.jpg Shifter
9509.jpg VW Golf Radiator
9673.jpg Water pump hose
9522.jpg Pedal Boxes
Brake booster
10002.jpg right mount
Discussions
2080.jpg Ruda's 11-sec Bakkie 826.jpg 826.jpg 1603.jpg 1607.jpg 1609.jpg 2146.jpg 3019.jpg 4065.jpg 4331.jpg 4639.jpg 4640.jpg 4641.jpg 4642.jpg 5456.jpg 5457.jpg 8867.jpg 8868.jpg 8884.jpg 10002.jpg 10936.jpg 10937.jpg 10938.jpg 10939.jpg 10940.jpg 10941.jpg 10942.jpg 10943.jpg 10944.jpg 10945.jpg 10946.jpg 10947.jpg 14388.jpg 14412.jpg 14711.jpg 15206.jpg 15215.jpg 16189.jpg 17185.jpg 18246.jpg
