This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
GROUP 01 001 Engine 001 ENGINE ASSEMBLY (all NLA) 002 Engine Gasket Kit Repair Kit, Regrind Kit 003 Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN * Timing Chain Cover, Cylinder Liner 004 Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT 005 Emission Control EMISSION CONTROL DEVICE 006 Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD * flywheel, flex plate, cam bearings 007 Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN 008 Manifold MANIFOLD intake, exhaust 009 Exhaust Tube & Muffler -- See Chassis section below 010 Oil Pump OIL PUMP & OIL STRAINER (oil filter) 011. Carburetor -- see Fuel section below 011A Carburetor, Exhaust Type -- see Fuel section below 011B Carburetor with Auto Choke -- see Fuel section below 012 Air Cleaner -- see Fuel section below 013 Fuel Strainer -- see Fuel section below 014 Fuel Pump -- see Fuel section below 015 Fuel Tank, Sedan -- see Chassis section below 016 Fuel Tank, Coupe -- See Chassis section below 018. Fuel Strainer, Sedan -- see Fuel section below 018A Fuel Strainer, Coupe -- see Fuel section below 019 Accelerator Pedal & Choke Control, see Chassis section below 020 Water Pump WATER PUMP & FAN 021 Radiator -- See Chassis section below 022 Engine Mounting -- See Chassis section below
Fuel
011. Carburetor CARBURETOR(CRANK) with Manual Choke 011A Carburetor CARBURETOR(EXHAUST & EVAPO) with Manual Choke 011B DCH Carburetor CARBURETOR with Auto Choke 011C GX Carburetor CARBURETOR (TWIN) 012 Air Cleaner AIR CLEANER To May 1971 012A GX Air Cleaner AIR CLEANER (GX) 013 Fuel Strainer -- see 018 014 Fuel Pump FUEL PUMP 015 Fuel Tank, Sedan -- see Chassis section below 016 Fuel Tank, Coupe -- See Chassis section below 018. Fuel Piping FUEL STRAINER & PIPING
Engine Electrical
Engine Control
Accelerator Linkage -- See Chassis section below Choke Cable -- See Chassis section below
Chassis & Body
Engine Support
009 Exhaust EXHAUST TUBE & MUFFLER 015. Sedan Fuel Tank FUEL TANK(SEDAN) 015A Sedan Fuel Tank FUEL TANK(SEDAN EVAPO) 016. Coupe Fuel Tank FUEL TANK(COUPE) 016A Coupe Fuel Tank FUEL TANK(COUPE EVAPO) 019 Engine Control ACCELERATOR PEDAL & CHOKE CONTROL 021 Radiator 022 Engine Mounting
Power Train
GROUP 03 042 Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER 043 Hydraulic Clutch Pedal CLUTCH PEDAL (Hydraulic Clutch) 044 Clutch Cylinder CLUTCH MASTER CYLINDER 045 Clutch Cylinder CLUTCH OPERATING CYLINDER 046 Transmission Assembly F5C56A Case 050 F4W56L Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE To March 1973 050A F4W56A Case TRANSMISSION CASE, REAR EXTENSION & SPEEDOMETER PINION(4 SPE From April 1973 051 F4W56L Gear TRANSMISSION GEAR(4 SPEED) To March 1973 051A F4W56A Gear TRANSMISSION GEAR(4 SPEED) From April 1973 052 F4W56L Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To March 1973 052A F4W56A Control TRANSMISSION CONTROL FORK & LEVER(4 SPEED) To From April 1973 055A Automatic Transmission Case TRANSMISSION CASE & FITTING(AUTOMATIC 3N71B) 055B Automatic Transmission Gear TRANSMISSION GEAR(AUTOMATIC 3N71B) 055C Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE(AUTOMATIC 3N71B) 055D Automatic Transmission Valve CONTROL VALVE(AUTOMATIC 3N71B) 056 Propeller Shaft PROPELLER SHAFT 057 Differential GEAR CARRIER & GEAR 059 Automatic Transmission Control TRANSMISSION CONTROL FLOOR SHIFT TYPE(AUTOMATIC)
Axle
GROUP 04 060 Front Axle FRONT AXLE, ROAD WHEEL & TIRE 061 Front Suspension FRONT SUSPENSION(STRUT, SHOCK ABSORBER) 062 Rear Axle REAR AXLE, ROAD WHEEL & TIRE 063 Rear Suspension REAR SUSPENSION(SPRING LEAF, SHOCK ABSORBER)
Brake
GROUP 05 064 Hand Brake HAND BRAKE & HAND BRAKE CABLE 065 Front Drum Brake FRONT BRAKE(DRUM TYPE) 065A Disc Brake FRONT BRAKE(DISC TYPE) 066 Rear Brake REAR BRAKE & WHEEL CYLINDER(FOR FRONT DRUM BRAKE) 066A Rear Brake REAR BRAKE & WHEEL CYLINDER(FOR FRONT DISC BRAKE) 067 Brake Piping BRAKE PIPING(TANDEM) 068 Brake Pedal BRAKE PEDAL 070 Tokico Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM TOKICO) To September 1971 070A Nabco Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM NABCO) To September 1971 070B Tokico Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM TOKICO) From October 1971 070C Nabco Brake Master Cylinder BRAKE MASTER CYLINDER(TANDEM NABCO) From October 1971
Steering
GROUP 06 072 Steering Gear STEERING GEAR(COLLAPSIBLE) includes Steering Column 073 Steering Linkage STEERING LINKAGE 074 Steering Wheel STEERING WHEEL & STEERING LOCK
Electrical
GROUP 02
Engine Electrical System
023 Distributor DISTRIBUTOR(CRANK) 023A Distributor DISTRIBUTOR(EXHAUST & EVAPO) 024 Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG * includes Alternator Mounting 025A Alternator & Regulator ALTERNATOR & REGULATOR 025C ALTERNATOR(HITACHI) 026 Starter Motor STARTER MOTOR
Body Electrical System
027 Wiring includes Wiring Harness 028 Switch SWITCHES, FLASHER UNIT, HORN & CIGARETTE LIGHTER * Includes Electrical Unit, Instrument, Switch & Relay 029A Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND) * includes instrument panel * includes temperature gauge sender (thermal transmitter) 030. Room Heater & Ventilator 030A Room Heater, Heavy Duty 030C Ventilator 031 Radio & Clock RADIO,ANTENNA & CLOCK 033 Battery (see Front Body Panels for Battery Mounting) 034 Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE 035 Wiper & Washer WINDSHIELD WASHER 036 Head Light HEAD LAMP 037 Front Combination Lamp Part Numbers FRONT COMBINATION LAMP 038 SIDE MARKER LAMP Side Lighting 039 Sedan Rear Combination Lamp REAR COMBINATION LAMP(SEDAN) 39A Coupe Rear Combination Lamp REAR COMBINATION LAMP(COUPE) 040 License Lamp LICENCE LAMP(SEDAN) 040A License Lamp LICENCE LAMP(COUPE) 041 Room Lamp ROOM LAMP (Dome Light)
Body & Trim
Sedan
GROUP 07 BODY (SEDAN) 081 Grille RADIATOR GRILLE & FRONT BUMPER(SEDAN) 082 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(SEDAN) * includes Radiator Core Support & front apron/valence * includes battery support frame/box 083 Hood Lock HOOD LOCK CONTROL(SEDAN) 084 Cowl COWL TOP & COWL TOP GRILLE(SEDAN) 085 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(SEDAN) includes package tray 086 Dash Trim GLOVE BOX & ASH TRAY(SEDAN) 087 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(SEDAN) 088 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(SEDAN) 089 Floor FLOOR PANEL, INSULATOR & SPARE WHEEL HANDLE(SEDAN) 090 Floor Trim FLOOR MAT, KICKING PLATE & CONSOLE BOX(SEDAN) includes carpet 091 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(SEDAN 2 DOOR) 092 Body Side Trim BODY SIDE FITTING & MOULDING(SEDAN) 093 Interior Side Trim BODY SIDE TRIMMING(SEDAN) includes ash tray & weatherstripping 094 Rear Body REAR FENDER & REAR PANEL(SEDAN) includes parcel tray & fuel door 095 Rear Window SIDE WINDOW & REAR WINDOW(SEDAN) 096 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(SEDAN 2 DOOR) 097 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(SEDAN 2 DOOR) 098 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(SEDAN 2 DOOR) 105 Trunk & Bumper TRUNK & REAR BUMPER(SEDAN) (boot) 106 Front Seat FRONT SEAT(SEDAN) 107 Rear Seat REAR SEAT(SEDAN) 108 Seat Accessories SAFETY BELT & HAND REST(SEDAN)
Coupe
GROUP 08 BODY (COUPE) 111 Grille RADIATOR GRILLE & FRONT BUMPER(COUPE) * includes Radiator Core Support & front apron/valence 112 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(COUPE) * includes battery support frame/box 113 Hood Lock HOOD LOCK CONTROL(COUPE) 114 Cowl COWL TOP & COWL TOP GRILLE(COUPE) 115 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(COUPE) includes Package Tray 116 Dash Trim GLOVE BOX & ASH TRAY(COUPE) 117 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(COUPE) 118 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(COUPE) 119 Floor FLOOR PANEL & FITTING(COUPE) 120 Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX(COUPE) 121 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(COUPE) 122 Body Side Trim BODY SIDE FITTING & MOULDING(COUPE) 123 Interior Side Trim BODY SIDE TRIMMING(COUPE) includes ash tray & weatherstripping 124 Rear Body REAR FENDER & REAR PANEL(COUPE) includes parcel tray & fuel door 125 Rear Window SIDE WINDOW(COUPE) 126 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(COUPE) 127 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(COUPE) 128 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(COUPE) 129 Rear Window REAR WINDOW(COUPE) 130 Trunk & Bumper TRUNK LID & REAR BUMPER(COUPE) (boot) 131 Trunk Fitting TRUNK ROOM TRIMMING(COUPE) (boot) 132 Front Seat FRONT SEAT(COUPE) 133 Rear Seat REAR SEAT & TONNEAU COVER(COUPE) 134 Seat Accessories SAFETY BELT & HEAD REST(COUPE)
Truck
101 Front View includes RADIATOR GRILLE, FRONT BUMPER, COWL TOP GRILLE and mirrors Radiator Grille Front Bumper Cowl Cowl top, grille and seals Wing Mirror 102 Hood Ledge & Dash Fitting 882 Hood Ledge Part Numbers HOOD LEDGE 882 Dash Fitting Part Numbers DASH FITTING 103 Hood Hinge & Lock Hood Hinge Hood Lock Control 104 Front Window includes trimming Windshield Rear-view (Inside) Mirror Sunvisor 105 Instrument Includes dash PAD, trim, GLOVE BOX & ASH TRAY * & PACKAGE TRAY, FLARE HOLDER 106 Floor Trimming Dash Trimming Floor Trimming 107 Floor Fitting Front Floor Fitting Console Box 108 Dash Side Trimming Dash Side Trimming Body Side Trimming Roof Trimming 109 Door Door 109a Door Hinge Door Fitting 109b Door Trimming Side Visor 110 Door Window & Lock Door Window Door Lock & Remote Control Door Handle & Regulator 111 Seat フロント シート <トリム> Seat Head Restraint Safety Seat Belt 112 Body Side Fitting Side Moulding includes side vent Fuel Filler Door Rear Bumper Back Window Rear Gate Fitting Rear Floor Fitting 113 Front Body Panel 812 Radiator Core & Apron Panel Front Fender Panel Hood Ledge & Hood Panel * includes battery support frame/box 114 Dash Panel Dash Panel Front Floor Panel Front Pillar Panel Roof Panel Back Lower Panel 115 Rear Body Panel (Short Body) 116 Rear Body Panel (Long Body) includes Center Bearing Bracket Rear Body Side Panel Rear Floor Panel 840 フロア パネル Back Panel Rear Gate Panel Center Bearing Bracket 117 Key Set Label
Miscellaneous
GROUP 09 167 Emblem EMBLEM (Badges) 168 Key & Cylinder KEY & CYLINDER 169 Key & Cylinder BLANK KEY 170 Model Plate MODEL NO. PLATE プレート、モデル ナンバー 171 Paint TOUCH-UP PAINT 172 Coolant LONG LIFE COOLANT & N.C.S. SEALER 173 Tool Kit TOOL KIT includes Jack 173A Special Tool SPECIAL TOOL 175 Leather Top LEATHER TOP (Vinyl Roof)
