This is an index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts from Nissan can sometimes be found on eBay or other sellers (NOS or "New Old Stock").
Engine
Engine ASSEMBLY Engine Gasket Kit Repair Kit, Regrind Kit Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN * Timing Chain Cover, Cylinder Liner Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT Emission Control Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD * flywheel, flex plate, cam bearings Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN Manifold intake (inlet) & exhaust Twin Carb Manifold Part Numbers GX intake & GX exhaust Oil Pump & OIL STRAINER (oil filter) Water Pump & FAN
Fuel
Carburetor (CRANK) with Manual Choke Carburetor (EXHAUST & EVAPO) with Manual Choke DCH Carburetor with Auto Choke GX Carburetor (TWIN) Air Cleaner To May 1971 GX Air Cleaner Fuel Pump Fuel Piping & STRAINER
Chassis & Body
Engine Support
Exhaust & MUFFLER Sedan Fuel Tank (SEDAN) Sedan Fuel Tank (SEDAN EVAPO) Coupe Fuel Tank (COUPE) Coupe Fuel Tank (COUPE EVAPO) Truck Fuel Tank Engine Control ACCELERATOR PEDAL & CHOKE CONTROL Radiator Engine Mounting
Power Train
Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER Hydraulic Clutch Pedal LHD Clutch Pedal & clutch cable RHD Clutch Cylinder MASTER Clutch Cylinder OPERATING (slave) Transmission Assembly F5C56A Case F4W56L Case & REAR EXTENSION & SPEEDOMETER PINION(4 SPEEED To March 1973) F4W56A Case & REAR EXTENSION & SPEEDOMETER PINION(4 SPEEED From April 1973) F4W56L Gear (4 SPEED) To March 1973 F4W56A Gear (4 SPEED) From April 1973 F4W56L Control & FORK & LEVER(4 SPEED) To March 1973 F4W56A Control & FORK & LEVER(4 SPEED) To From April 1973 Automatic Transmission Case & FITTING(AUTOMATIC 3N71B) Automatic Transmission Gear (3N71B) Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE (3N71B) Automatic Transmission Valve CONTROL VALVE (3N71B) Propeller Shaft PROPELLER SHAFT (driveshaft/tailshaft) Differential GEAR CARRIER & GEAR Automatic Transmission Control FLOOR SHIFT TYPE
Axle
Front Axle FRONT AXLE, ROAD WHEEL & TIRE Front Suspension FRONT SUSPENSION(STRUT, SHOCK ABSORBER) Rear Axle REAR AXLE, ROAD WHEEL & TIRE Rear Suspension REAR SUSPENSION(SPRING LEAF, SHOCK ABSORBER)
Brake
Hand Brake & HAND BRAKE CABLE Front Drum Brake FRONT BRAKE(DRUM TYPE) Disc Brake FRONT BRAKE(DISC TYPE) Rear Brake & WHEEL CYLINDER(FOR FRONT DRUM BRAKE) Rear Brake & WHEEL CYLINDER(FOR FRONT DISC BRAKE) Brake Piping (TANDEM) Brake Pedal Single Brake Master Cylinder Tokico Brake Master Cylinder (TANDEM) To September 1971 Nabco Brake Master Cylinder (TANDEM) To September 1971 Tokico Brake Master Cylinder (TANDEM) From October 1971 Nabco Brake Master Cylinder (TANDEM) From October 1971
Steering
Steering Gear STEERING GEAR(COLLAPSIBLE) includes Steering Column Steering Linkage STEERING LINKAGE Steering Wheel STEERING WHEEL & STEERING LOCK
Electrical
Engine Electrical System
Distributor (CRANK) Distributor (EXHAUST & EVAPO) Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG * includes Alternator Mounting Alternator & Regulator ALTERNATOR(HITACHI) Starter Motor
Body Electrical System
Wiring includes Wiring Harness Switch & FLASHER UNIT, HORN & CIGARETTE LIGHTER * Includes Electrical Unit, Instrument, Switch & Relay Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND) * includes instrument panel * includes temperature gauge sender (thermal transmitter) Room Heater & Ventilator Room Heater, Heavy Duty Ventilator Radio & Clock & ANTENNA Battery (see Front Body Panels for Battery Mounting) Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE Wiper & Washer WINDSHIELD WASHER Head Light HEAD LAMP Front Combination Lamp Side Lighting SIDE MARKER LAMP Sedan Rear Combination Lamp Coupe Rear Combination Lamp License Lamp (SEDAN) License Lamp (COUPE) Room Lamp (Dome Light)
Body & Trim
Grille RADIATOR GRILLE & FRONT BUMPER * includes Radiator Core Support & front apron/valence (COUPE) Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD (bonnet) & DOOR MIRROR * includes Radiator Core Support & front apron/valence (SEDAN) * includes battery support frame/box Hood Lock HOOD LOCK CONTROL Cowl COWL TOP & COWL TOP GRILLE Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL includes package tray Dash Trim GLOVE BOX & ASH TRAY Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR Floor * FLOOR PANEL, INSULATOR & SPARE WHEEL HANDLE (SEDAN) * FLOOR PANEL & FITTING(COUPE) Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX Body Side BODY SIDE PANEL & REAR WHEEL HOUSE Body Side Trim BODY SIDE FITTING & MOULDING Interior Side Trim BODY SIDE TRIMMING includes ash tray & weatherstripping Rear Body REAR FENDER & REAR PANEL includes parcel tray & fuel door Rear Window SIDE WINDOW & REAR WINDOW Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST Rear Door Fitting Part Numbers DOOR LOCK & REMOTE CONTROL, HANDLE, REGULATOR & GLASS Trunk & Bumper TRUNK & REAR BUMPER (boot) Trunk Fitting TRUNK ROOM TRIMMING (COUPE) (boot) Front Seat FRONT SEAT Rear Seat REAR SEAT includes COUPE TONNEAU COVER Seat Accessories SAFETY BELT & HEAD REST
Coupe
GROUP 08 BODY (COUPE) 111 Grille RADIATOR GRILLE & FRONT BUMPER(COUPE) * includes Radiator Core Support & front apron/valence 112 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(COUPE) * includes battery support frame/box 113 Hood Lock HOOD LOCK CONTROL(COUPE) 114 Cowl COWL TOP & COWL TOP GRILLE(COUPE) 115 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(COUPE) includes Package Tray 116 Dash Trim GLOVE BOX & ASH TRAY(COUPE) 117 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(COUPE) 118 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(COUPE) 119 Floor FLOOR PANEL & FITTING(COUPE) 120 Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX(COUPE) 121 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(COUPE) 122 Body Side Trim BODY SIDE FITTING & MOULDING(COUPE) 123 Interior Side Trim BODY SIDE TRIMMING(COUPE) includes ash tray & weatherstripping 124 Rear Body REAR FENDER & REAR PANEL(COUPE) includes parcel tray & fuel door 125 Rear Window SIDE WINDOW(COUPE) 126 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(COUPE) 127 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(COUPE) 128 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(COUPE) 129 Rear Window REAR WINDOW(COUPE) 130 Trunk & Bumper TRUNK LID & REAR BUMPER(COUPE) (boot) 131 Trunk Fitting TRUNK ROOM TRIMMING(COUPE) (boot) 132 Front Seat FRONT SEAT(COUPE) 133 Rear Seat REAR SEAT & TONNEAU COVER(COUPE) 134 Seat Accessories SAFETY BELT & HEAD REST(COUPE)
Wagon
Rear Door Fitting Part Numbers DOOR LOCK & REMOTE CONTROL, HANDLE, REGULATOR & GLASS Back Door Part Numbers
Truck
101 Front View includes RADIATOR GRILLE, FRONT BUMPER, COWL TOP GRILLE and mirrors Radiator Grille Front Bumper Cowl Cowl top, grille and seals Wing Mirror 102 Hood Ledge & Dash Fitting 882 Hood Ledge Part Numbers HOOD LEDGE 882 Dash Fitting Part Numbers DASH FITTING 103 Hood Hinge & Lock Hood Hinge Hood Lock Control 104 Front Window includes trimming Windshield Rear-view (Inside) Mirror Sunvisor 105 Instrument Includes dash PAD, trim, GLOVE BOX & ASH TRAY * & PACKAGE TRAY, FLARE HOLDER 106 Floor Trimming Dash Trimming Floor Trimming 107 Floor Fitting Front Floor Fitting Console Box 108 Dash Side Trimming Dash Side Trimming Body Side Trimming Roof Trimming 109 Door Door 109a Door Hinge Door Fitting 109b Door Trimming Side Visor 110 Door Window & Lock Door Window Door Lock & Remote Control Door Handle & Regulator 111 Seat フロント シート <トリム> Seat Head Restraint Safety Seat Belt 112 Body Side Fitting Side Moulding includes side vent Fuel Filler Door Rear Bumper Back Window Rear Gate Fitting Rear Floor Fitting 113 Front Body Panel 812 Radiator Core & Apron Panel Front Fender Panel Hood Ledge & Hood Panel * includes battery support frame/box 114 Dash Panel Dash Panel Front Floor Panel Front Pillar Panel Roof Panel Back Lower Panel 115 Rear Body Panel (Short Body) 116 Rear Body Panel (Long Body) includes Center Bearing Bracket Rear Body Side Panel Rear Floor Panel 840 フロア パネル Back Panel Rear Gate Panel Center Bearing Bracket 117 Key Set Label
Miscellaneous
GROUP 09 167 Emblem (Badge/Mark) 168 Key & Cylinder 169 Key & Cylinder BLANK KEY 170 Model Plate MODEL NO. PLATE プレート、モデル ナンバー 171 Paint TOUCH-UP PAINT 172 Coolant LONG LIFE COOLANT & N.C.S. SEALER 173 Tool Kit includes Jack 173A Special Tool 175 Leather Top (Vinyl Roof)
