This is an index of Nissan Part Numbers for Datsun 1200. It is a composite catalog from various official English and Japanese catalogs.
Engine
Engine ASSEMBLY Engine Gasket Kit Repair Kit, Regrind Kit Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN * Timing Chain Cover, Cylinder Liner Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT Emission Control Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD * flywheel, flex plate, cam bearings Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN Manifold intake (inlet) & exhaust Twin Carb Manifold Part Numbers GX intake & GX exhaust Oil Pump & OIL STRAINER (oil filter) Water Pump & FAN
Fuel
Carburetor Manual Choke DCH Carburetor with Auto Choke GX Carburetor (TWIN) Air Cleaner To May 1971 GX Air Cleaner Fuel Pump Fuel Piping & STRAINER
Chassis
Engine Support
Exhaust & MUFFLER Sedan Fuel Tank Coupe Fuel Tank Truck Fuel Tank Engine Control ACCELERATOR PEDAL & CHOKE CONTROL Radiator Engine Mounting
Power Train
Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER Hydraulic Clutch Pedal LHD Clutch Pedal & clutch cable RHD Clutch Cylinder Transmission Assembly Transmission Case & REAR EXTENSION & SPEEDOMETER PINION Transmission Gear Transmission Control & FORK & LEVER Automatic Transmission Case & FITTING Automatic Transmission Gear Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE Automatic Transmission Valve CONTROL VALVE Propeller Shaft PROPELLER SHAFT (driveshaft/tailshaft) Differential GEAR CARRIER & GEAR Automatic Transmission Control FLOOR SHIFT TYPE
Axle
Front Axle & ROAD WHEEL & TIRE Front Suspension STRUT, SHOCK ABSORBER Rear Axle & ROAD WHEEL & TIRE Rear Suspension SPRING LEAF, SHOCK ABSORBER
Brake
Hand Brake & HAND BRAKE CABLE Front Drum Brake Disc Brake Rear Brake & WHEEL CYLINDER Brake Piping Brake Pedal Single Brake Master Cylinder Tokico Brake Master Cylinder TANDEM Nabco Brake Master Cylinder TANDEM
Steering
Steering Gear includes Steering Column Steering Linkage Steering Wheel & STEERING LOCK
Electrical
Engine Electrical System
Distributor Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG includes Alternator Mounting Alternator & Regulator ALTERNATOR(HITACHI) Starter Motor
Body Electrical System
Wiring includes Harnesses Switch & FLASHER UNIT, HORN & CIGARETTE LIGHTER includes Electrical Unit, Instrument, Switch & Relay Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND) * includes instrument panel * includes temperature gauge sender (thermal transmitter) Room Heater & Ventilator Radio & Clock & ANTENNA Battery (for Battery Mounting see Front Body Panels Part Numbers) Wiper & Washer Head Light Front Combination Lamp Side Lighting SIDE MARKER LAMP Sedan Rear Combination Lamp Coupe Rear Combination Lamp Van Rear Combination Lamp Part Numbers Truck Rear Combination Lamp Part Numbers License Lamp Room Lamp (Dome Light)
Body & Trim
Grille RADIATOR GRILLE & FRONT BUMPER * includes Radiator Core Support & front apron/valence (COUPE) Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD (bonnet) & DOOR MIRROR * includes Radiator Core Support & front apron/valence (SEDAN) * includes battery support frame/box Wing Mirror Hood Lock HOOD LOCK CONTROL Cowl COWL TOP & COWL TOP GRILLE Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL includes package tray & lamp holder Dash Trim GLOVE BOX & ASH TRAY Windshield GLASS, WEATHERSTRIP & MOULDING Roof PANEL, SUNVISOR & INSIDE BACK MIRROR Floor PANEL, FITTING, INSULATOR & SPARE WHEEL HANDLE Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX Body Side BODY SIDE PANEL & REAR WHEEL HOUSE Body Side Trim BODY SIDE FITTING & MOULDING Interior Side Trim BODY SIDE TRIMMING includes ash tray & weatherstripping Rear Body REAR FENDER & REAR PANEL includes parcel tray & fuel door Rear Window SIDE WINDOW & REAR WINDOW Front Door PANEL, GLASS & DOOR VENTILATOR Front Door Fitting LOCK, REGULATOR & DOOR HANDLE Front Door Trim MOULDING, FINISH & ARM REST Rear Door Fitting Part Numbers DOOR LOCK & REMOTE CONTROL, HANDLE, REGULATOR & GLASS Back Door Part Numbers (WAGON) TailGate Truck Rear Floor includes Center Bearing Bracket Trunk & Bumper TRUNK & REAR BUMPER (boot) Trunk Fitting TRUNK ROOM TRIMMING (COUPE) (boot) Front Seat Rear Seat includes COUPE TONNEAU COVER Seat Accessories SAFETY BELT & HEAD REST
Miscellaneous
Emblem (Badge/Mark) Key & Cylinder Model Plate Paint TOUCH-UP PAINT Coolant LONG LIFE COOLANT & N.C.S. SEALER Tool Kit includes Jack Special Tool Leather Top (Vinyl Roof)
