60-Series Transmission
From Datsun 1200 Club
Category: Transmission
The 60-series transmissions can handle the torque from A14 and A15 engines. So the 60 four-speed is stronger than the 56 four-speed which was used behind A12 engine. The 60-series 5-speed is a beefier model than the stock Datsun 1200 GX-5's 56-Series Transmission. These 5-speeds came in the 1977-1982 Datsun B310 (210/Sunny/140Y/150Y). The four-speeds came behind A14s & A15s.
Look for the '60' casting mark on the right side of the gearbox:
22342.jpgAlbum 22342
Also see 60 5-speed v 4-speed for more identification tips.
60-series transmissions were used exclusively behind A14 and A15 engines, due to their ability to handle more torque than the smaller 56-series. However, starting with the B310 it was also offered behind the A12.
Datsun B310 Sunny/210
* B310 GL with A12 (B310H) came with optional 5-speed 60L (B310HF)
* FS5W60L used through 1980.10 (end of A12 in Japan)
* A13 (debut 1980.11) used 60A
Nissan B140
* FS5W60B
60A 5-speed
26668.jpgAlbum 26668 26669.jpgAlbum 26669
60-series transmissions came in three varieties:
* 60L four-speed for A-series engine
* 60L five-speed for A-series engine
* 60A five-speed for A-series engine
60L for A-series engine
* Four-speed: 1975 to 1982
* Five-speed: 1977-1979 B310 Sunny (manufactured through 1979 September)
  * Dogleg shift pattern
* 1980-up B310 Sunny (from 1979 October)
* Standard shift pattern
Note that 60-series gearboxes may be available for other engine types, so make sure you get one to match the A-series engine.
FS5W60A
26670.jpgAlbum 26670 26767.jpgAlbum 26767
FS5W60B appears externally identical to 60A
31342.jpgAlbum 31342 31343.jpgAlbum 31343 31344.jpgAlbum 31344 31345.jpgAlbum 31345
60B engine face pattern
31346.jpgAlbum 31346
Gear Ratios
(see 5-speed Gear Ratios)
22723.jpgAlbum 22723
box	         4th	3rd	2nd	1st	5th	Rev
60L 4-speed     1.000	1.378	2.170	3.513		3.764
60L 5-speed     1.000	1.378	2.170	3.513	0.846	3.464
60A 5-speed A   1.000	1.378	2.170	3.513	0.821	3.764
60A 5-speed B   1.000	1.320	2.170	3.513	0.821	3.764
NOTES
  • The 1st through 4th gears are all the same -- 4-speed and 5-speed -- except for a few 5-speeds with 3rd closer to top (larger gap from 2nd to 3rd).
  • For freeway driving, the 60A has a larger overdrive and so is preferable to the 60L dogleg.
  • First gear is the same in all 60-series boxes
Swap Notes
When swapping a 60 transmission into a 1200, these parts should be obtained from the donor car:
* Transmission
* Release Lever which differs from the 1200 part
* Release Bearing sleeve, which may differ from the 1200 version
* Shifter
* #Rear Crossmember or at least the rubber insulator
* the 60a 4-speed and 60a 5-speeds are the same length as the stock Datsun 1200 transmission, and the shifter is in the same spot
Rear Crossmember
The rear engine crossmember, that is to say the Gearbox Crossmember.
B310 stock 60-series rear engine crossmembers - 60L has a 20mm dip in it. 60A is level
25665.jpgAlbum 25665
Pitroad says the South Africa Datsun Bakkie (B140) had a FS5W60A 5-speed, and that the trans crossmember might work for a B110. B140 Gearbox crossmember for FS5W60B is pictured below. It appears the tunnel mounts are fitted further back than in the 1200.
B140 stock 60A (5-speed) & stock 60L (4-speed)
18129.jpgAlbum 18129
  • 11321-H6201 B210 A14 0978-0874 [60-series 4-speed]
  • 11321-H7300 B210 A14 0974- [60-series 4-speed]
  • 11323-H7310 [63-series 5-speed]
  • 11321-H6201 INSULATOR ASSY-ENGINE MOUNTING REAR B310 A12A MANUAL [56-series]
The 60-series insulators sit on top of the crossmember, and bolts from the bottom.
Gearbox rubber mount (see Part Numbers)
B310 60-series rear engine mount
1706.jpgAlbum 1706
Using 1200 Crossmember
The stock 1200 crossmember can be adapted to fit a 60-series transmission. It depends on which 60 (60L vs 60A).
60A crossmember bosses are level with 1200 brackets, so spacers can be fitted
21066.jpgAlbum 21066
60L bosses are 20mm above the 1200 brackets, so no spacers are needed
9665_4cf0c96919da4.jpgPost 347474
The main problem is that the 60-series bosses are further back than the 56-series:
21067.jpgAlbum 21067
To compensate for this:
Automatic-tunnel 1200
Automatic 1200s will fit the 60 by reversing the stock 1200 crossmember (reference).
Manual-tunnel 1200
Stock 1200 mount fitment (56-series)
884.jpgAlbum 884 4648.jpgAlbum 4648
60-series fitment with stock unmodified 1200 crossmember -- using simple adapter plate between rubber mount and gearbox:
26446.jpgAlbum 26446
The wide holes bolt to the 60 transmission mount boss
26367.jpgAlbum 26367
The narrow holes bolt to the top of the 56 rubber mount
C dimension is the offset
Similar treatment done with non-Nissan gearbox:
18921.jpgAlbum 18921 18922.jpgAlbum 18922 18923.jpgAlbum 18923 18924.jpgAlbum 18924
Simple rectanguler plate with four holes drilled
60L fitment with stock 1200 crossmember. The rubber mount is modified (plate welded to the rubber mount top plate, and the original holes trimmed off for factory appearance):
21885.jpgAlbum 21885 21895.jpgAlbum 21895 21897.jpgAlbum 21897
9665_4cf0c96919da4.jpgPost click for topic 9665_4cf0c97c3f088.jpgPost click for topic 9665_4cf0c98b46e65.jpgPost click for topic
POST Chris's Rip Snorter A12 & Red B10 -- classic cut & shut. Slice up the old mount & crossmber then reweld it.
21066.jpgAlbum 21066 21067.jpgAlbum 21067 21068.jpgAlbum 21068 21069.jpgAlbum 21069
60-series fitment with modified 60-series crossmember:
- crossmember narrowed, cut to fit into 1200 tunnel
- tabs welded to the crossmember
Using B310 Mount
Or, use the B310 60-series rubber insulator with a simple custom crossmember that bolts to the original crossmember points.
60-series rubber mount
* See Gearbox Crossmember#Rubber_Insulator for part numbers
NOTE: There is a difference in how a 60L 5-speed and a 60A 5-speed mounts. Apparently the 60L is lower by 20mm. When using a 60A custom crossmember, 20 mm spacers may be required to fit a 60L.
Flat Steel Crossmember 60A
Flat steel plate using BMW transmission mounts. Angle-iron can be used with the lip cut down as shown
9C693D40-9CCA-48F7-A6F4-166B38E44B59.jpg 6DA4B68C-10F0-4499-98CD-3BE77AF7DBD3.jpg
Template for drilling the holes
BMW gearbox insulators
Flat Steel Crossmember 60L
Fabricate a u-shaped flat steel adapter for the 60-series insulator, then bolt on for a 60L (4 or 5 speed). For the 60A, it will fit with long bolts and spacers.
60 custom crossmember for Datsun 1200
1703.jpgAlbum 1703 1705.jpgAlbum 1705
6567.jpgAlbum 6567
A sleeker version can also be fabricated:
15858.jpgAlbum 15858
* The rubber insulator picture is a stock 60-series rubber unit.
Bprojects 60-series Install Kits
Bprojects sells a sophisticated kit which doesn't need long bolts or spacers. It includes both the rubber mount and the new conversion crossmember.
VENDOR: Bprojects Product: 56-60A Conversion Member kit☁ 60A 5-speed
VENDOR: Bprojects Product: 56-60L Conversion Member kit☁ 60L dogleg 5-speed or 4-speed 60-series
Fits 60A 5-speed to Datsun 1200 manual tunnel
60A | 60L difference is length of "ears"
27362.jpgAlbum 27362 27363.jpgAlbum 27363
Pitroad 60A Fitting Kit
Pitroad sells a kit to place a 60A into a 1200:
25671.jpgAlbum 25671 25668.jpgAlbum 25668 25670.jpgAlbum 25670 25669.jpgAlbum 25669
They say it will also work for 60L if 20mm spacers are used.
22671.jpgAlbum 22671
Home-built Kits
ang94541 60A kit
2403.jpgAlbum 2403
Rolands 60A kit made from flat steel with B310 rubber
28854.jpgAlbum 28854 28853.jpgAlbum 28853 28841.jpgAlbum 28841 28840.jpgAlbum 28840
tsillay 60A kit
2698.jpgAlbum 2698
EDP 60A adapter
Unknown adapter
21810.jpgAlbum 21810 21809.jpgAlbum 21809
clyon's 60A adapter
OR, cut down a 60-series crossmember and weld angle-iron to it:
holes offset ~40mm and ~230mm apart
24065.jpgAlbum 24065 24066.jpgAlbum 24066
Custom Crossmember
Various type can be used, including:
* Wide crossmember, bolted to floor pans
* Modified stock crossmember
* Solid-mount
Wide Crossmember
A wide crossmember can be bolted to the floor pan using large washer for reinforcement. Then the original 1200 gearbox body brackets can be removed, providing enough space for the reverse lamp switch.
See Main Article: Wide gearbox crossmember
Modified Crossmember
A 1200 crossmember was welded to a B210 crossmember
Solid Mount
If you don't mind vibrations, the rubber isolator can be left out. This makes the 60A 5-speed easy to bolt up. The 60L can be treated similarly but needs spacers.
The 60A is flush to the existing 1200 mounting ears
So a flat bar can be used (the stock B310 crossmember dips down to provide room for the rubber mount)
The new crossmember (flat bar) just needs offset bolts, making it into a sort of u-shaped flat bar
Crossmember Modification
Remove the 1200 original crossmember tunnel brackets and fit a wide crossmember. See Custom Crossmember
OR fit a custom low-profile crossmember. This is what is used with V8 in Datsun, so it should be plenty strong
174_574f745ab3730.jpgPost 479063 174_574f7466add31.jpgPost 479063 174_574f7479137a6.jpgPost 479063
OR for a more factory look ...
Remove the 1200 original crossmember bosses and move them back
5008.jpgAlbum 5008 5009.jpgAlbum 5009
The brackets are tack-welded, so you can drill out the welds, and remove the brackets in one piece.
Use a simple flat plate (8mm thick) for the crossmember and use the 60-series rubber insulator mount.
Use the stock 1200 crossmember and insulator. Idea - will this work? Cut the corners off the stock 1200 rubber mount, drill new holes farther apart so it fits the larger gearbox:
26063.jpgAlbum 26063
B140 Gearbox crossmember for 4-speed 60L or for 5-speed (60A/60B). These may bolt right in after the 1200 tunnel brackets are moved back?
Uses the stock B140/B210/B310 (A14/A15) rubber insulator
Using B310-style insulator
13822_543ba7c0463c8.jpgPost 460546 13822_54e5bdd6ba271.jpgPost 463918
Tailshaft
The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
7474.jpgAlbum 7474
Reverse Switch
The location of the Reverse Switch can differ between all the different transmission. It is a problem when fitting any 60-series gearbox in to the small 1200 manual tunnel. The reverse-light switch is right where the Datsun 1200 chassis x-member mount is.
6567.jpgAlbum click to view
Options to work around this problem include:
Move The Crossmember
  • Move it back
or
  • use a floor-mounted crossmember
See #Modified_Crossmember
Plug
Remove the Reverse Switch, discard it, then plug the hole. A spare A12 engine-block drain plug fits (from the side of the engine block). Optionally you can fit a switch to the shifter to activate the reverse lamp.
* Fit a shifter-mounted Reverse Switch
* Fit a switch plug in the transmission
28804.jpgAlbum 28804
If you screw the plug in too far you end up effectively stopping the shift from traveling over far enough to make either the shift up to 5 or down to reverse. There must be a millimeter or so play.
Or you can modify the reverse switch (grind the head down and seal it) and screw it back in as a plug
21071.jpgAlbum 21071
Clearance Tunnel
Cut a hole in the side of the tunnel bracket and let the switch protrude into it. This is what POST Ziggy did. You can add a cover inside the passenger compartment.
Tunnel Swap
Fit a tunnel removed from an automatic-transmission 1200, a B140, or a larger Tunnel such as B210 or 610 which helpfully is the exact shape needed for a 1200.
Swap Into Datsun 1200
(A special note of thanks to Davo1200 who started this article originally in the old Tech Section)
How do I install a 5 speed Sunny box?
Vanette Transmission
FS5W60A vs RS5W60A 5-speed comparo
4650.jpgAlbum 4650
RS5W60A -> FS5W60A CONVERSION KIT
174_5768a575a82f7.jpgUpload click to view
Parts
FS5W60A Factory Service manual PDF http://032516d.netsolhost.com/transmission_book_300dpi.pdf
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=60-Series_Transmission"
This page has been accessed 265,419 times. This page was last modified 19:59, 27 November 2025. Content is available under Datsun 1200 Club.
