Part Numbers Index
From Datsun 1200 Club
Category: Catalog
This is an index of Nissan Part Numbers for Datsun 1200. It is a composite catalog from various official English and Japanese factory parts catalogs.
Engine
Engine ASSEMBLY
Engine Gasket Kit Repair Kit, Regrind Kit
Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN
 * Timing Chain Cover, Cylinder Liner
Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT
Emission Control
Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD
 * flywheel, flex plate, cam bearings
Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN
Manifold intake (inlet) & exhaust
Twin Carb Manifold Part Numbers GX intake & GX exhaust
Oil Pump & OIL STRAINER (oil filter)
Water Pump & FAN
Fuel
DCG Carburetor Manual Choke
DCH Carburetor with Auto Choke
GX Carburetor (TWIN)
Air Cleaner
GX Air Cleaner
Fuel Pump
Fuel Piping & STRAINER
Chassis
Engine Support
Exhaust & MUFFLER
Sedan Fuel Tank
Coupe Fuel Tank
Truck Fuel Tank
Engine Control ACCELERATOR PEDAL & CHOKE CONTROL
Radiator
Engine Mounting
Power Train
Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER
Hydraulic Clutch Pedal LHD
Hydraulic Clutch Cylinder LHD
Clutch Pedal & clutch cable RHD
Transmission Assembly
Transmission Case & REAR EXTENSION & SPEEDOMETER PINION
Transmission Gear
Transmission Control & FORK & LEVER
Automatic Transmission Case & FITTING
Automatic Transmission Gear
Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE
Automatic Transmission Valve CONTROL VALVE
Propeller Shaft PROPELLER SHAFT (driveshaft/tailshaft)
Differential GEAR CARRIER & GEAR
Automatic Transmission Control FLOOR SHIFT TYPE
Axle
Front Axle & ROAD WHEEL & TIRE
Front Suspension STRUT, SHOCK ABSORBER
Rear Axle & ROAD WHEEL & TIRE
Rear Suspension SPRING LEAF, SHOCK ABSORBER
Brake
Hand Brake & HAND BRAKE CABLE
Front Drum Brake
Disc Brake
Rear Brake & WHEEL CYLINDER
Brake Piping
Brake Pedal
Single Brake Master Cylinder
Tokico Brake Master Cylinder TANDEM
Nabco Brake Master Cylinder TANDEM
Steering
Steering Gear includes Steering Column
Steering Linkage
Steering Wheel & STEERING LOCK
Spare Wheel Hanger
Spare Wheel Hanger Truck & Van
Electrical
Engine Electrical System
Distributor
Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG includes Alternator Mounting
Alternator & Regulator
ALTERNATOR(HITACHI)
Starter Motor
Body Electrical System
Wiring includes Harnesses
Switch & FLASHER UNIT, HORN & CIGARETTE LIGHTER
 includes Electrical Unit, Instrument, Switch & Relay
Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND)
 * includes instrument panel
 * includes temperature gauge sender (thermal transmitter)
Room Heater & Ventilator
Radio & Clock & ANTENNA
Battery (for Battery Mounting see Front Body Panels Part Numbers)
Wiper & Washer
Head Light
Front Combination Lamp
Side Lighting SIDE MARKER LAMP
Sedan Rear Combination Lamp
Coupe Rear Combination Lamp
Van Rear Combination Lamp Part Numbers
Truck Rear Combination Lamp Part Numbers
License Lamp
Room Lamp (Dome Light)
Fog Lamp (Option)
Body & Trim
Grille RADIATOR GRILLE & FRONT BUMPER
* includes Radiator Core Support & front apron/valence (COUPE)
* PB110 Bumper Parts
Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD (bonnet) & DOOR MIRROR
* includes Radiator Core Support & front apron/valence (SEDAN)
* includes battery support frame/box
Wing Mirror
Hood Lock HOOD LOCK CONTROL
Cowl COWL TOP & COWL TOP GRILLE
Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL includes package tray & lamp holder
Dash Trim GLOVE BOX & ASH TRAY
Windshield GLASS, WEATHERSTRIP & MOULDING
Roof PANEL, SUNVISOR & INSIDE BACK MIRROR
Floor PANEL, FITTING, INSULATOR & SPARE WHEEL HANDLE
Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX
Body Side BODY SIDE PANEL & REAR WHEEL HOUSE
Body Side Trim BODY SIDE FITTING & MOULDING
Interior Side Trim BODY SIDE TRIMMING includes ash tray & weatherstripping
Rear Body REAR FENDER & REAR PANEL includes parcel tray & fuel door
Rear Window SIDE WINDOW & REAR WINDOW
Front Door PANEL, GLASS & DOOR VENTILATOR
Front Door Fitting LOCK, REGULATOR & DOOR HANDLE
Front Door Trim MOULDING, FINISH & ARM REST
Rear Door Fitting Part Numbers DOOR LOCK & REMOTE CONTROL, HANDLE, REGULATOR & GLASS
Back Door Part Numbers (WAGON)
TailGate
Truck Rear Floor includes Center Bearing Bracket
Wagon Rear Floor
Trunk & Bumper TRUNK & REAR BUMPER (boot)
Trunk Fitting TRUNK ROOM TRIMMING (COUPE) (boot)
Front Seat
Rear Seat includes COUPE TONNEAU COVER
Seat Accessories SAFETY BELT & HEAD REST
Miscellaneous
Emblem (Badge/Mark)
Key & Cylinder
Model Plate
Paint TOUCH-UP PAINT
Coolant LONG LIFE COOLANT & N.C.S. SEALER
Tool Kit includes Jack
Special Tool
Leather Top (Vinyl Roof)
Sunny Truck Options
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Part_Numbers_Index"
This page has been accessed 190,623 times. This page was last modified 00:37, 3 September 2021. Content is available under Datsun 1200 Club.
