Part Numbers Index
Revision as of 06:13, 8 January 2012; view current revision
This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
Raw Parts List Engine Part Numbers
Engine Engine assembly (all NLA)
Engine Gasket Kit
Cylinder Block & Oil pan
Timing Chain Cover -- See "Front Cover" Below
Cylinder Liner
Cylinder Head & Rocker Cover
Engine Mounting
Connecting Rods
Piston & Crankshaft & Flywheel
Front Cover & Cylinder Fitting
Camshaft & Timing Chain & Valve Mechanism
Manifolds
EGR
Emission Controls
Oil pump & Oil filter (oil strainer)
Exhaust Tube & Muffler -- See Below
Water pump & Thermostat
Radiator -- See Below
Fuel
Raw Part Number List Fuel Part Numbers
Air Pollution Control
Vacuum Control (engine vacuum & breather hoses)
Carburetor
Carburetor, Twin
Fuel Throttle (See EGI fuel injection)
Fuel filter (fuel strainer) and Fuel Piping
Fuel Pump
Air Cleaner
Air Cleaner, GX
Fuel Tank & Fuel Piping -- See Below
Engine Electrical
See section Below.
Engine Control
Accelerator Linkage -- See Below
Choke Cable -- See Below
Chassis & Body
Radiator
Engine Mounting
Accelerator Linkage
Choke Cable
Power Train
Clutch Accessory
Clutch Control
Automatic Transmission
* Accessory
* Torque Convertor & Case
* Oil Pump & Clutch
* Planetary Gear
* Control Valve
* Control Switch
* Fitting
Manual Transmission
* Accessory
* 3-speed column shift
* 4-speed
* 5-speed (GX5)
* Transmission Case
* Transmission Gear
* Shift Control
* Transmission Control & Linkage
* Propeller Shaft
* Differential (Final Drive), Gear Carrier
Console Box -- See Below
Brake
Hand Brake (Parking Brake Control)
Front Brake
Rear Brake
Clutch & Brake Pedal
Brake master cylinder
Power Brakes
Brake Piping
Chassis
Front Axle
Rear Axle
Road Wheel & Cap
Steering Gear
Steering Column
Steering Linkage
Steering wheel
Steering Column Shell
Front Suspension
Rear Suspension
Spare Tire Carrier
Electrical
Engine Electrical System
Distributor Part Numbers
Spark plugs
Coil
Alternator Accessory & Mounting
Voltage regulator
Starting Motor
Battery Mounting
Body Electrical System
Wiring Harness
Instrument Panel (Meter)
Electrical Unit, Instrument Switch & Relay
Wipers
Radio
Clock
Room Heater
Battery Mounting
Lamp Part Numbers
* Head Lamp
* Front Combination Lamp
* Fog Lamp (Options)
* Rear Combination Lamp
* License Lamp & Side Reflectors
Body & Trim
Body Panels
Front Grille & Fitting
Rear Body
Bumper
Body Side Moulding & Stripes
Front Body Panels
Cowl & Dash Fitting
Cowl Top & Grille
Front Fender & Hood (bonnet)
Hood Lock Control
Dash, Side & Instrument Panel
Dash Fitting
Glove Box & Ash Tray
Side Panel & Lock
Glass
* Windshield
Roof Panel, Sunvisor & Mirror
Floor Panel & Fitting
Floor Mat, Carpet, Kicking Plate & Console Box
Body
 Body Side Panel & Rear Wheel House
 Body Side Fitting & Moulding
 Body Side Trimming
 Rear Fender & Panel
Glass
 Windshield
 Side Window
 Rear Window
Doors
 Front Door Panel, Glass & Door Ventilator
 Front Door Lock, Regulator & Handle
 Front Door Moulding, Finish & Arm Rest
Trunk Lid & Bumper
Trunk Room Trimming
Front Seat
Rear Seat & Tonneau Cover
Safety Belt & Head Rest
Miscellaneous
Keys & Cylinder
Badges (Emblem)
Blank Key
Model Number Plate
Touch-up Paint
Long Life Coolant & N.C.S. Sealer
Tool Kit
Special Tool
Vinyl Top (Leather Top)
