Block Comparison
(Redirected from M22)
Category: Engine Mechanical
The engine cylinder block changed for the 1974 model year. Early A-series Datsun engines (1966-1973) feature a front-distributor design. The A Engine Redesign of 1973 moved the distributor back to mid-engine, and moved the motor mounts back 35 mm.
B10 A10 Engine
 * no Breather Tube at rear of block
17129.jpgAlbum 17129
B110 A12 Engine
 * only two accessory bolt bosses on left side
174_56ef818ad0204.jpgPost 477472
1974-up A12/A13 (short deck engines)
* Many accessory bolt bosses
1974-up A13/A14/A15 (tall deck engines)
* Evenly-spaced Welch Plugs
6107.jpgAlbum 6107
A12
* Unevenly spaced welch plugs
19820.jpgAlbum 19820
Block Oiling
Head Oiling
Early blocks have oil coming up through the head gasket to the cylinder head. 1974-up blocks have this hole plugged, and instead the oil comes up the center head bolt hole.
See Cylinder_Head_Identification#Cylinder_head_oil_passage
Brass plug in Late block
20443.jpgAlbum 20443
Pickup
Oil Pickup Location (circled) & dipstick hole (arrow)
25675.jpgAlbum 25675
Early refers to front-distributor engines (A10 and A12) before the 1974 A-series Engine Redesign.
Dimensions
A10 Deck Height: 179.1mm
A12/A13/A12A Deck Height: 189.1mm
A14/A15 Deck Height: 204.1mm
Length (all): 393-394 mm block proper (less timing cover)
Tall Block
A14/A15 tall block engines have a Deck height of 204.1mm, or 15mm taller than an A12/A12A block. Length front-to-back is the same.
A13 - 1974 USA B210
11010-H6200 A13 BARE BLOCK 73mm/2.87" bore size
A14
* H72 or G30 cast mark with "A14" above fuel pump
* #G34 cast mark
  11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
A15
* 1979  11010-H9700
* 1980- 11010-H9905 #G34
Short Deck
A10
B10 Sunny "Datsun 1000" came with A10 engine, 998 cc, 3-main bearing block. All other A-series engines have 5-main bearings.
25622.jpgAlbum 25622
3 mains, with and without bearings installed
174_691198b6db7fe.jpgPost 499124 174_691193d06cdaf.jpgPost 499123
JDM Catalog
11010-18000 ALL Except Coupe
* uses 13035-18000 ASSY-COVER TIMING CHAIN
11010-18001 from E/# A10-184228
* uses 13035-18001 ASSY-COVER TIMING CHAIN
  13035-H1000 from 0570
 [updated to Double timing chain & pressure tensioner]
 [Fits all B10 blocks]
11010-25700 Coupe
Some B10 we re fitted with NIKKI carburetor.
17129.jpgAlbum 17129 17130.jpgAlbum 17130 17131.jpgAlbum 17131 25623.jpgAlbum 25623
174_691198966e9ee.jpgPost 499124 174_69119918e0e03.jpgPost 499124
174_691198843851f.jpgPost 499124 174_691198c7369a0.jpgPost 499124 174_691198cd9af80.jpgPost 499124 174_691198d5cdcca.jpgPost 499124
A12 Original
H10 block castings
19179.jpgAlbum 19179
11010-H2300 A12 BARE BLOCK 73mm/2.87" bore size
* USA 11010-H2300 0570- ALL <> 11010-H1000
* USA 11010-H1000 -0470
* JPN 11010-H2300 GX, running change replaced <2,0> 11010-H1000
* JPN 11010-H1000 except GX
M08 block from 1970-1973 E10 Nissan Cherry X-1R A12T
2636.jpgAlbum 2636
M15 E10 Cherry A12 single-carb
B110 A12 engine, five main bearing (so not interchangeable with A10 engine).
  • 11010-H1000 JDM, USA -0470
    • 13035-18001 ASSY-COVER TIMING CHAIN [single mark, pulley has multiple marks]
  • 11010-H2300 GX, USA non-GX from 0570-
    • 13035-H1000 ASSY-COVER TIMING CHAIN [multiple marks]
    • [chain tensioner and bolts changed 0570]
M08 - Cherry A12T
A12 GX
B110 A12GX Engine block is the same as standard block (same part number). It was fitted slightly differently, including:
  • Flat-top pistons
  • GX camshaft
  • extra connection on the Suction Pipe
26361.jpgAlbum 26361 26362.jpgAlbum 26362 26360.jpgAlbum 26360
A12 from 1974
1974 engine redesign (From October 1973), accessory mounts and engine mounts not compatible with earlier A12 engine.
More bolt holes for more accessories.
Engine mount bosses are 35 mm farther back (in photo, mount is forward, on accessories mounts)
19202.jpgAlbum 19202
AC compressor bracket bolt holes
28304.jpgAlbum 28304 27774.jpgAlbum 27774
Revised Block
23474.jpgAlbum 23474
Early Block
23475.jpgAlbum 23475
Dimension (late engine)
25421.jpgAlbum 25421
B210 JDM
* 11010-H5000
* 11010-G1600 From June 1975 (?)
* Both use 11110-H5000 PAN ASSY-OIL
* Both use 13035-H1000 COVER-timing chain
B120 JDM (from Oct 1975)
* 11010-G1600 7510-7907
* 11010-G1618 7908-8503
  11110-H5000 PAN ASSY-OIL 7510-8503
* 11010-G1619 8504-
* 11110-G3401 PAN ASSY-OIL 8504-8910
* All use 13035-H1000 Timing Chain Cover
** 11110-H9701 PAN ASSY-OIL 8910-
B310 JDM
* 11010-H5000 Van -7909
* 11010-H9460 Van 7910-8010
* 11010-H8500 Sedan, Coupe -8010
* 11010-H9463 Van 8011-8109, 8110-
* All use 11110-H5000 PAN ASSY-OIL
* All use 13035-H1000 or 13035-H1010 COVER-timing chain
H50 (1974 B210 A12) has only 2 accessory bolt bosses
H10 A12 B110 etc.
H72 A14 B210 etc. rear wheel drive
M72 A14 N10 Front wheel drive
H85 - B310 A12
H86 - A12A/A13
#M79 - A12
A12 with 3 accessory bolt bosses
No drain plug (undrilled boss)
Single drain plug
Dual drain plugs (M22? casting number)
17799.jpgAlbum 17799 17797.jpgAlbum 17797
H86 - A12A/A13
G32?
6107.jpgAlbum 6107 6109.jpgAlbum 6109
  • New A12 has offset center core plug (same as original A12), but with two drain plug bosses
  • A14 has re-spaced center core plug and single drain plug boss
M22
A12 M22 F-2 block without 'M2' mark
31391.jpgAlbum 31391
A12 block with 'M22' left side rear, and a large POST 'M2' cast mark on left side front
18118_54a4789c3b5b6.jpgUpload click to view 25127.jpgAlbum 25127
Apparently M2 indicates a factory replacement block. L-series, Z-series, KA-series and A-series were all available with blocks marked M2.
Cast 'M22' in the usual place, and cast 'A12' above the fuel pump boss
16008_54b38d15ca1d9.jpgUpload click to view 16008_54b38d4380d9d.jpgUpload click to view 16008_54b38d2d09b57.jpgUpload click to view
A12 M22 block
* Late model design (A Engine Redesign)
* Twin drain plugs on left side
* Late model scalloped crankshaft
* POST reportedly has smaller-than-normal 25mm Welch Plugs on left side
13814.jpgAlbum 13814 7711_4b5d1a8e267b8.jpgPost 301649 18118_54a389bc05af0.jpgPost 462282
M79
* single drain plug casting
* dual drain plug casting
M79 may or may not be drilled and tapped for the second drain plug.
30689.jpgAlbum 30689 30690.jpgAlbum 30690
Single drain plug
30688.jpgAlbum 30688
no drain plug
30687.jpgAlbum 30687
H85
H85 is the B310 Sunny 1977-1980 A12A block with 75mm bore.
B310 CAN A12
B310 JPN Sedan, Coupe -1980.10
JDM B310 sedan and coupe after October 1980 used the #H86 block with slightly larger 76mm bore and was marked 'A13'.
identifying features
* Block Code H85
* low deck height (like all A12)
* ID pad is just below top of block is stamped 'A12'
174_614288239ae7e.jpgPost 495859
174_6142885150408.jpgPost 495859 174_6142886c66828.jpgPost 495859 174_614288b4dafe3.jpgPost 495859 174_614288c111d7f.jpgPost 495859 174_614288ce2b51a.jpgPost 495859
A12A
A12A debuted 1977 in Japan in sedan/coupe (but not wagon or van). 1978 in North America B310. The bore is 2mm larger than A12.
75mm/2.95" bore size
6713.jpgAlbum 6713
North America B310
* 11010-H8500 CAN 1278-0779
* 11010-H8502 CAN
* 11010-H9001 CAN 0879-
* 11010-H9960 USA 0879-
  * uses 11110-H5000 OIL PAN
JAPAN
11010-H8500 7712-8010
A13, 1980
For JDM B310 sedans & coupe, the A13S replaced the A12S November 1980. B310 vans kept using the A12. Not to be confused with TS 1300 engine, which was an overbored A12. A13 uses 76mm bore like the A15.
H86 BLOCK ASSY-CYLINDER
11010-H8660 A13S 8011-JAPAN B310
15874.jpgAlbum 15874 7779.jpgAlbum 7779 5987.jpgAlbum 5987
Tall Deck
Tall-deck engines have about 25cm between the bell housing section and the cylinder head.
28768.jpgAlbum 28768 20446.jpgAlbum 20446 30359.jpgAlbum 30359
1974 A13
USA model B210 (HLB210) for 1974 came with unique pre-A14 tall block engine.
11010-H6200 [1974] A13 BARE BLOCK 73mm/2.87" bore size
* 11110-H6200 ASSY-PAN OIL
* 11110-H7200 ASSY-PAN OIL FOR SERVICE
* 11110-H7201 ASSY-PAN OIL FOR SERVICE
* Uses 13035-H1000 Timing Chain Cover
The A13 block looks similar to an A14, so check the stamp of the Engine ID Mark to see whether it says 'A13' or 'A14'.
Engine Type Stamp is below #4 spark plug, aft of distributor
16699.jpgAlbum 16699
A14
A14 debuted late 1974 for the 1975 model year.
North America B210
11010-H7200 B210 USA/CANADA
* B210 USA uses Mid Sump oil pan
* 11110-H6200 ASSY-PAN OIL -0275
* 11110-H7200 ASSY-PAN OIL 0375-0875
* 11110-H7201 ASSY-PAN OIL 0975-
North American B310
* 11010-H7200 -0779 USA, -1179 CAN
* 11010-H9905 0879- USA [same as A15]
* 11010-H9900 0879- USA
* 11010-H9115 1279-0780 CAN
11110-H5000 OIL PAN [same as JDM B210 A12/A14]
A14 cast "A14" above fuel pump
H72
H72 Casting mark with "29027A03" cast mark
H72 with "28X23A01" cast mark
18284_557bb0637cead.jpgPost 469285
M72
M72 is Applied Model Code for F10. There appears to be no difference from #H72
18237.jpgAlbum 18237
174_680ddc3938a84.jpgPost 498877 174_680ddc88419f9.jpgPost 498877 174_680ddc9254d37.jpgPost 498877 174_680ddc98aa76b.jpgPost 498877 174_680ddca64a9c9.jpgPost 498877 174_680ddcf5bc2d9.jpgPost 498878 174_680ddcffe2e21.jpgPost 498878 174_680dddfc05946.jpgPost 498879 174_680dde213ea32.jpgPost 498879
A15
North America B310
* 11010-H9700 -0779 [different from A14]
* 11010-H9905 0879- [cast mark 'G34', shared with A14]
11110-H9700 OIL PAN [this oil pan is unique to A15]
Nissan Competition
* 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
Unkown casting, note the two vertical ribs on the back, above the bellhousing flange
30359.jpgAlbum 30359 30360.jpgAlbum 30360 30361.jpgAlbum 30361 30362.jpgAlbum 30362 30363.jpgAlbum 30363
G34
Late A14/A15 block casting 'G34'. This block is machined either for A14 or A15, then given a part number.
  • Different from the earlier #H97 A15 block
  • #A14 from 1980 also used this rationalized block
H99 11010-H9905 0879- A14/A15
    11010-H9900 0879- A14 only
Is H91 machined from a G34 casting? 11010-H9115 1279-0780 A14 CANADA
Look for casting number on left side of block
18871.jpgAlbum 18871 18870.jpgAlbum 18870
with G34 pistons
18872.jpgAlbum 18872
20677_57942d76a0d0e.jpgPost 480071 20677_57942d8e17f33.jpgPost 480071 20677_57942d5d29e0d.jpgPost 480071 20677_57942d82bfe3f.jpgPost click for topic
G34 cast mark, also "8" and "238193"
A14 G34
G34 A14 with "C028X" mark
u29192282higkz26-img600x450-1222754743jupnux96499.jpg u29192282higkz26-img600x450-1222754743gds1vs96499.jpg
G34 A14
20446.jpgAlbum 20446 20447.jpgAlbum 20447 20444.jpgAlbum 20444
G34 A15
6107.jpgAlbum 6107 6108.jpgAlbum 6108 6109.jpgAlbum 6109 10246.jpgAlbum 10246
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Block_Comparison"
This page has been accessed 54,764 times. This page was last modified 03:54, 30 November 2025. Content is available under Datsun 1200 Club.
