Big Valves
Revision as of 04:38, 11 April 2013; view current revision
Category: Valvetrain
Stock valves for A12 engine are 35 mm intake, 29 mm exhaust. You can fit the A14-size 37mm inlet/30mm exhaust. And valves up to 40mm have been fitted for ultra high-RPM use.
The stock A12 valves (35/29) are good for small-bore (1200cc) use below for up to 6000 RPM. For larger bore engines (or higher RPM) the 37/30 valves from an A14 are better.
For racing at high RPMs, more power can be made with larger valves, but care must be taken for proper valve flow.
The 40s may require relief/flow notch in the side of the cylinder wall?
COUP1200: My A14 makes 140hp & its not EFI or turbo. I have twin 40mm webers, good extractors the head flowes 141hp. All your power gain is in the head big valves extencive amounts of porting good spark ... I dont run roller rockers & have not had a problem.you dont need to go to big with the cam mine about 74deg ... Mine makes power to 7500rpm.
feral: COOPS 1200 SEDAN AFTER RUNNING A 2:11 AT PHILLIP ISLAND CIRCUIT ... The car sounded awesome and handled very well. In typical 1200 fashion showed alot of more exotic machinery including a Porsche 924 turbo and a lotus elite a clean pair of tailights :-)
Feral
Feral used 40mm steel Inlet valves, tuliped and swirl polished, with 35mm Exhausts steel polished.
And don't forget to dial in the camshaft timing
42mm Valves
42 mm intakes are perhaps the limit for A-series cylinder heads.
Dual Valve Springs
Large valves work best at high RPM. When revving over 6000 RPM, dual valve springs are called for. The stock A12GX springs are good for 6600 RPM.
Racing/aftermarket dual springs are usually good for 9000 RPM and shouldn't be used in a street engine as they cause accelerated wear on the valve guides.
19821.jpg 21686.jpg 21687.jpg 23378.jpg 23647.jpg 23648.jpg 23649.jpg 23734.jpg
Triple Valve Springs
Big Valve
850.jpg 1500.jpg th_3816.gif 4216.jpg 6179.jpg 6885.jpg 9261.jpg 13502.jpg 17211.jpg 19033.jpg 19034.jpg 19035.jpg 19040.jpg 19115.jpg 20747.jpg
Valve Spring
504.jpg 606.jpg 700.jpg 1025.JPG 3647.jpg 4216.jpg 5089.jpg 5883.jpg 6192.jpg 6223.jpg 6691.jpg 7342.jpg 8330.jpg 8791.jpg 8830.jpg 8909.jpg 9089.jpg 9090.jpg 9767.jpg 10429.jpg 10430.jpg 10489.jpg 10656.jpg 10988.jpg 12142.jpg 12714.jpg 13010.jpg th_13792.jpg 13804.jpg 15332.jpg 15946.jpg 17517.jpg 17612.jpg 17613.jpg 17640.jpg 18222.jpg 18258.jpg 18703.jpg 19821.jpg 20353.jpg 20747.jpg 21686.jpg 21687.jpg 23378.jpg 23647.jpg 23648.jpg 23649.jpg 23734.jpg
