Big Valves
Revision as of 21:40, 24 July 2018; view current revision
Category: Valvetrain
Stock valves for A12 engine are 35 mm intake, 29 mm exhaust. You can fit the A14-size 37mm inlet/30mm exhaust. And valves up to 42mm have been fitted for ultra high-RPM use.
The stock A12 valves (35/29) are good for small-bore (1200cc) use below for up to 6000 RPM. For larger bore engines -- or higher RPM -- the 37/30 valves from an A14 are better.
For racing at high RPMs, more power can be made with larger valves, but care must be taken for proper valve flow.
9546_4a6f7b83239a7.jpgPost 266302 9546_4a6f7bde8c31e.jpgPost 266302 9546_4a6f7c3f1cc0e.jpgPost 266302
The 40s may require relief/flow notch in the side of the cylinder wall?
20353.jpgAlbum 20353 20747.jpgAlbum 20747 700.jpgAlbum 700 6691.jpgAlbum 6691 9027.jpgAlbum 9027 12142.jpgAlbum 12142 15324.jpgAlbum 15324 20264.jpgAlbum 20264
POST COUP1200: My A14 makes 140hp & its not EFI or turbo. I have twin 40mm webers, good extractors the head flowes 141hp. All your power gain is in the head big valves extencive amounts of porting good spark ... I dont run roller rockers & have not had a problem.you dont need to go to big with the cam mine about 74deg ... Mine makes power to 7500rpm.
feral: COOPS 1200 SEDAN AFTER RUNNING A 2:11 AT PHILLIP ISLAND CIRCUIT ... The car sounded awesome and handled very well. In typical 1200 fashion showed alot of more exotic machinery including a Porsche 924 turbo and a lotus elite a clean pair of tailights :-)
7240.jpgAlbum 7240
Feral
Feral used 40mm steel Inlet valves, tuliped and swirl polished, with 35mm Exhausts steel polished.
1501.jpgAlbum 1501 1245.gifAlbum click to view 1498.jpgAlbum 1498 1499.jpgAlbum 1499 1500.jpgAlbum 1500 1502.jpgAlbum 1502
And don't forget to dial in the camshaft timing
3639.jpgAlbum 3639
41mm
GX head with 41 mm intake valves & 32 mm exhaust valves
42mm Valves
42 mm intakes are perhaps the limit for A-series cylinder heads.
20264.jpgAlbum 20264 12142.jpgAlbum 12142
Dual & Triple Valve Springs
Large valves work best at high RPM. When revving over 6000 RPM, dual valve springs are called for. The stock A12GX springs are good for 6600 RPM (and some report higher RPMs).
Tomei Valves
Tomei valves Fitted to A12 GX head. Tomei valves with 7mm stems. Intake valves 40mm, exhaust valves 33mm. The stems have a thinner design for maximizing air flow rate within the port with the reduced air flow resistance. The cylinders need extra notching at the top of the bore to accommodate these large valves.
23472.jpgAlbum 23472 23473.jpgAlbum 23473 25142.jpgAlbum 25142 25143.jpgAlbum 25143 25144.jpgAlbum 25144 25145.jpgAlbum 25145 25146.jpgAlbum 25146 25147.jpgAlbum 25147 25148.jpgAlbum 25148
Big Valve
850.jpg 1500.jpg th_3816.gif 4216.jpg 6179.jpg 6885.jpg 9261.jpg 13502.jpg 17211.jpg 19033.jpg 19034.jpg 19035.jpg 19040.jpg 19115.jpg 20747.jpg
Valve Spring
504.jpg 606.jpg 700.jpg 1025.JPG 3647.jpg 4216.jpg 5089.jpg 5883.jpg 6192.jpg 6223.jpg 6691.jpg 7342.jpg 8330.jpg 8791.jpg 8830.jpg 8909.jpg 9089.jpg 9090.jpg 9767.jpg 10429.jpg 10430.jpg 10489.jpg 10656.jpg 10988.jpg 12142.jpg 12714.jpg 13010.jpg th_13792.jpg 13804.jpg 15332.jpg 15946.jpg 17517.jpg 17612.jpg 17613.jpg 17640.jpg 18222.jpg 18258.jpg 18703.jpg 19821.jpg 20353.jpg 20747.jpg 21686.jpg 21687.jpg 23378.jpg 23647.jpg 23648.jpg 23649.jpg 23734.jpg
