Revision as of 09:55, 30 November 2018; view current revision
Category: Datsun B210
Datsun model series B210 was the third-generation Sunny. They were sold during Model years 1974-1978 and marketed in various countries as the Datsun B210 or Datsun Sunny. In some countries it was designated Datsun 120Y, Datsun 140Y or Datsun 160Y depending on the engine fitted. The B210 was designed to be more luxurious than the spartan B110, so it has a 40mm longer Wheelbase with some models considerably heavier than the original Datsun 1200.
It is common to confuse the "Datsun B-210" (B210) with the "Datsun 210" (B310), but they are different generations altogether, sold during different years. For more details and how the Sunny family developed, see History of Datsun 1200.
Japan Brochures| USA Brochures
22859.jpgAlbum 22859 22860.jpgAlbum 22860 22861.jpgAlbum 22861
Variations
Model Prefix
 B210 base engine (A12)
HB210 High engine (A14) USA, heavy-duty suspension (13" wheels)
HB211 High engine (A14) JDM, light-duty suspension (12" wheels)
PB210 Excellent 1400, 1974-1975 with L14 engine
GB211 Excellent 1600 (L16) from 1976 February
Prefix & Suffix Codes
7513.jpgAlbum 7513
ID Plates
Chassis Identification under-hood plates
Australia-assembled ADR plate
22381.jpgAlbum 22381 7513.jpgAlbum 7513
See main article: Australia-assembled
B211 Japan-market, H7405, B-B210, A12
B210 USA-market 1400
18183.jpgAlbum 18183
B210 Japan-market "Sunny 1200"
B210 South Africa "140Y"
11434.jpgAlbum 11434
B211 Japan-market "Sunny 1400" (A14)
15317.jpgAlbum 15317
H72 = 1975 B210 with A14 engine (Applied Model Codes)
20010.jpgAlbum 20010 20051.jpgAlbum 20051
78HP A14 (H73) 1977 5-speed coupe with POST electronic ignition (non-California)
1974 Canada with A13 engine
Models
  • Truck: the 120Y Truck is actually a 1200 Truck, not a B210-based model
    See B120 bakkie
  • VB210 Panel Wagon (some countries) -- not offered in Japan
Series
B210 could be divided into two series.
EARLY (1974-1975 models)
* small suspension & brakes
* non-chrome (black or gray) bumpers (USA)
LATE (1976-1978 models)
* larger suspension & brakes
* blackout tail panel
* chrome bumpers (USA)
* New Grille with a clearly rectangular center section
Early Sedan Grille:
Early Coupe Grille (also used by USA Sedans):
th_B210earlygrilleUSA.jpg 11916_4a3c6139ee283.jpgUpload click to view 8761.jpg
Late Sedan grille (also used by USA coupes)
Late Coupe Grille
15432.jpgAlbum click to view 10994_4aefbc82e6507.jpgUpload click to view 2531_4a78c1b0429bc.jpg
Trim
* Standard - least expensive model
* Semi-Deluxe - for Vans
* Deluxe - upgraded model
* Super-Deluxe - for Vans
* GL (Grand Luxe) - luxury model
* GX (Grand Luxe special), available as 4-dr or Coupe
  * JDM: Highest trim level
    * Some GX models had the A12T or A14T twin-carb engine
    * Other GX models had the A12S or A14S single-carb engine
  * USA: GX models had a standard A14S (single-carb engine)
120Y GX Malaysia
26326.jpgAlbum 26326
725.JPGAlbum 725 1708.jpgAlbum 1708 5890.jpgAlbum 5890
Common rectangular-gauge dash (GL Sedan pictured):
10874.jpgAlbum 10874
High-line round-gauge dash (JDM Coupes DX/GL/GX and GX Sedan):
11371.jpgAlbum 11371
GX
GX (Grand Luxe special), available as 4-dr or Coupe (only as Coupe for North America).
MALAYSIA
* 120Y GX coupe
North America
* All 1976-1978 coupes were GX with single-carb A14S engine
* GX was not offered 1973-1975
Japan GX | badges | blackout rear panel | side lamps | hubcaps | blackout grille
badges, blackout rear panel
3655.jpgAlbum 3655
highline gauges
3656.jpgAlbum 3656
side lamps, blackout grille
3657.jpgAlbum 3657
hubcaps
3658.jpgAlbum 3658
Malaysia 120Y GX
Early 5-speed coupes were DX models. For 1978 both a DX and a GX coupe was sold both badged "B210GX" in USA.
GX was the highest trim level, included more gauges and carpet.
STD Standard rubber mat 2drs 1975.5 up
* includes Honeybee
DX Deluxe most USA B210s
GL Grand Luxe - not sold in USA
GX some coupes from Dec 1976
22127.jpgAlbum 22127
Design
The B210 was the third-generation Sunny, replacing the B110. The theme for the B210 re-design included:
  • improvement "to be more likeable and satisfactory to a greater number of people".
  • Exterior design: style of "Streamline and a Cut" with "Young and Dynamic" image -- instead of the "rational" styling of the B110. "Sharp and Soft" atmosphere, "Long-nosed proportion" (long wheelbase?), and "Streamed and Dynamic" style.
  • Interior design: "Oval Scoop Cockpit"
    • Increased driver roominess. Front compartment larger, rear compartment smaller
  • Quieter operation (reduced NVH)
The side panel is finished by plum faces and sharp folds all over, and the stream of the fold and roof drip like an ebbing wave keeps sharpness in the free and easy touch.
reference: Service Bulletin Vol. 188 "Introduction of New Datsun B210 Series", Nissan Motor Co., Ltd., Tokyo, Japan, 1973.
Others have simply called it "coke-bottle" styling -- dynamic with a pinched waist.
One oddity about the B210 is that the bonnet latch release was moved from inside the car to outside. In this feature it was inferior to the B110. By 1976 it was moved back inside.
Bonnet
HOOD PANEL ASSY
65100-H5000 1973-1975 [power bulge]
65100-H7200 1976-1978 [slightly scalloped around headlights?]
65100-H5800 Excellent [center crease, scalloped around headlights]
early
4715.jpgAlbum 4715
late
6483.jpgAlbum 6483
Excellent (early and late)
8166.jpgAlbum 8166
Bumpers
See B210 Bumpers
Grille
See B210 Grille
Mirrors
See Main Article: B210 mirrors
Badges
See main article: B210 Badges
Front Lights
Japan B210 used twin-reflector front lamps, similar to late B120.
20150607210845329.jpg 5296.jpgAlbum 5296
Worldwide B210 had front combination lights similar to 1974-up ute:
322338478.jpg 18103_54afab67e76d9.jpgPost 462595
For more details, see: Front_Combination_Lamp#B210
B110: single reflector, spade connectors
B210: double reflector, square connector
B120: double reflector, spade connectors (1974-up)
Worldwide B210 front combination lights were below the B210 Bumpers, with cutouts in the bumper for clearance.
1956.jpgAlbum 1956 7431.jpgAlbum 7431
North America B210 had front combination lights in the grille.
H58 PB210/GB610
Japan: All red with two bulbs
* type 1073 bulb 26717-89900 (23W) for turn signal
* 26715-89920 (8/3.2W)
Australia: Amber and clear
26126-H6100 LH [Ever Wing PL-4646E]
26121-H6100 RH [Ever Wing PL-4645E]
Europe: Amber and clear
North America: All amber with single bulb
* Single type 1034 bulb (26717-89920, 12V-23/8W)
Fog Lamps
Worldwide also offered Fog Lamps options (not available in North America where the combo lamps were in the grille)
14242.jpgAlbum 14242 20639.jpgAlbum 20639
Side Lights
H50 vertical style
H58 parallelogram style (PB210 & GB211)
A55 Export horizontal style (amber lens, H62/H72 assy)
A55 North America rear reflector (red lens) (H69 coupe/H72 sedan)
H50 Japan market Datsun B210 Flasher lamp
H58 Sunny Excellent style
Export B210 Side Lamp uses the 240Z pointed-rectangular lenses & trim. Same as late 510 in USA. North America models did not flash, only used as running lamps/reflector.
Australia
B210_side-marker-lamp_AUS.jpg 24061.jpgAlbum 24061
North America rear side reflector
20762_.jpg generic.jpg 12838.jpgAlbum 12838 20762.jpgAlbum 20762
Tail Lights
B210 SEDAN
3282.jpgAlbum 3282 4252.jpgAlbum 4252 5140.jpgAlbum 5140
26551-H6200 USA (perhaps a different reflective standard?)
26551-H5000 JDM (looks the same as USA)
Sedan with rear-mounted number plate
B210 L-16 powered SEDAN
3885.jpgAlbum 3885 8167.jpgAlbum 8167
B210 COUPE
6346.jpgAlbum 6346 11709.jpgAlbum 11709
KB210 L-engine-powered COUPE
4950.jpgAlbum 4950 11374.jpgAlbum 11374 11463.jpgAlbum 11463 19007.jpgAlbum click to view 16123.jpgAlbum click to view 13127.jpgAlbum click to view 22314.jpgAlbum 22314 22315.jpgAlbum 22315
VB210 Van (Wagon)
17005.jpgAlbum 17005 vb210_TL.jpg vb210_TL_.jpg IKI_4071-1.jpg IKI_4071-2.jpg VB20_lens-a.jpg VB20_lens-b.jpg VB20_lens-c.jpg
Interior
The B210 DX Steering Wheel was re-used in the 1978-up Datsun 1200 Pickup
Dash
See main article: B210 Gauges
Most B210 models used a "modern" square-gauge dash (GL Sedan pictured):
3953.jpgAlbum 3953 10874.jpgAlbum 10874
High-line round-gauge dash (JDM Coupes. GX Sedan also):
11371.jpg 26896.jpgAlbum 26896
Markets
Australia
Some B210 sedans were Australian-assembled
JDM
In the Japan market, B210 was marketed as Sunny.
B210 - the original design
* from 1973 to late 1975
B211 - the redesign (minor facelift)
* Sedan, Coupe from December 1975
* Van continues as B210, but upgraded in October 1975
New Zealand
120Y
312456047.jpg 312456038.jpg 312456082.jpg 312456059.jpg 312456019.jpg 312456063.jpg 312456074.jpg 312456070.jpg
North America
In North America, the B210 was marketed as the "B-210" (with a hyphen). NOTE: It was not the 210, that is a newer Datsun.
See main article: B210 Year Changes
Also See:
* Emission Controls
* A-series Engine Changes
South Africa
B210 was sold 1977-1980 in South Africa with market names 120Y, 140Y and 160Y.
South America
POST Bolivia 120Y
16054_4f43dfdd142ad.jpgUpload click to view 16054_4f43dfeb69c55.jpgUpload click to view 16054_4f43dff74408b.jpgUpload click to view 16054_4f43e01f9bf9f.jpgUpload click to view 16054_4f43e02a281ed.jpgUpload click to view 16054_4f43e035b05d7.jpgUpload click to view
4-door sedan
13629.jpgAlbum 13629 12877.jpgAlbum 12877 6062.jpgAlbum 6062 18329.jpgAlbum 18329 5138.jpgAlbum 5138
10624.jpgAlbum 10624 2641.jpgAlbum 2641 3143.jpgAlbum 3143
10877.jpgAlbum 10877 10876.jpgAlbum 10876 10875.jpgAlbum 10875 10874.jpgAlbum 10874 10873.jpgAlbum 10873
12885.jpgAlbum 12885 13120.jpgAlbum 13120 14328.jpgAlbum 14328 18057.jpgAlbum 18057 18323.jpgAlbum 18323 19430.jpgAlbum 19430 19459.jpgAlbum 19459 19465.jpgAlbum 19465 19496.jpgAlbum 19496 19497.jpgAlbum 19497 19651.jpgAlbum 19651 19652.jpgAlbum 19652 19653.jpgAlbum 19653 19654.jpgAlbum 19654 19655.jpgAlbum 19655 19679.jpgAlbum 19679 19860.jpgAlbum 19860 20467.jpgAlbum 20467 25246.jpgAlbum click to view 25247.jpgAlbum click to view
Powertrain
Engine
Most B210s outside of North American were fitted with the redesigned A12 engine, hence the 120 in "120Y". North American models were fitted *only* with the high-line engines, namely the A13 for 1974, and the A14 for 1975-1978.
USA GX models use the single-carb engine (A14S). Some JDM GX models used the A12S or A14S single carb engine, and some used twin-carb engines (A12T or A14T).
Transmission
A12 and A13 models were fitted with the 56-Series Transmission, a four speed. A14 models, having extra torque, required a heavier-duty transmission so the the 60-Series Transmission 4-speed was fitted.
A12T Five-speed models (GFK, 1973-1974) used the 56-series 5-speed.
A14 Five-speed models (GFK, 1976-1978) used the large 63-Series Transmission.
Differential
1974-1975 models with A12 and A13 models used the Hitachi H145 differential.
A14 models used the H150 differential, which was rated to cope with the extra torque.
1976-1978 models all used the H150, including A12 models.
Brakes and Suspension
All North American B210s used the large disk brakes from the PB210 series, along with heavy-duty steering linkage from the Datsun 610.
Early A12 models used front drum brakes and lightweight steering linkage. 76-78 A12 models used a lightweight disc brake with heavy duty steering linkage.
Spring rates are nearly identical to Datsun 1200, even though the B210 was 20-25% heavier. This resulted in a noticeably smoother ride.
Special Versions
120Y
The 120Y was not another name for B210, but indicated only the A12-powered version of the B210. In many countries it was the only B210 offered. In some countries the 120Y was offered alongside the 140Y (A14-powered) and 160Y (L16-powered).
North America
North American (Canada/USA) B210s have 610 based front suspension and steering, including wheels and tires. It also has 610 engine crossmember modified for A-series mounts and a 610 style mid-sump oil pan on its A13/A14 engine. These changes are similar to the PB210.
By contrast the 120Y (A12-powered B210) does not have any 610 parts.
L-series Powered
PB210 (L14 engine) and GB210 (L16 engine) were marketed in Japan as "Sunny Excellent" and South Africa as 140Z/160Z.
See main article: PB210
B210 SSS
Datsun-Nissan New Zealand sold a special model, the SSS.
See Main Article: 120Y SSS
Honey Bee
The Datsun B-210 Honey Bee was a special low-cost model offered in the United States. It was the low-spec Standard model with no carpeting, but could be had with a special stripe and Bee decal. Its goal was to sell to a young, first time buyer who could not afford a regular B210. Honey Bee was only offered as a 2-dr sedan.
See main article: B210 Honey Bee
Colors
See B210 Colors
Fuel Economy Champions
B210 was consistently at or near the top of the fuel ecomony leaders.
 See main article: B210 Fuel Economy
Donor Parts
Many 510 and 610 steering, suspension and brake parts fit B210
* For a list of parts that fit the B210, see B210 Parts
* For a list of B110 parts that be taken from B210, see B210 Parts Donor.
Sales Literature
Photo Galleries
ddgonzal's photobucket: B210
Drawings
7111.jpgAlbum click to view 8013.jpgAlbum click to view 8014.jpgAlbum click to view 8015.jpgAlbum click to view
Custom
120Y-badged sedan with 'Sunny' Coupe grille and PB210 GX sedan rear lights
21041.jpgAlbum 21041 21042.jpgAlbum 21042 21043.jpgAlbum 21043
Design Study
5840.jpgAlbum 5840
