Turbo
From Datsun 1200 Club
Category: Forced Induction
This article is about a general turbo overview. For specific turbocharger models, see Turbos.
Forced induction comes in two forms: Supercharging and Turbo-supercharging. This article will focus on the turbocharger. For a comparison with the supercharger, see Forced Induction.
Big Power from a stock A-series engines can be had by adding a turbocharger. A turbo setup on an A12 makes more power and torque than a worked non-turbo A14, for a fraction of the build cost.
Turbo setups range from modest to wild.
21789.jpgAlbum 21789
350.jpgAlbum 350
Safely Turboing
POST frankthedolphintrainer: its been proven by a few members already that stock bottom ends can handle massive boost. i still run 15.6 psi on my daily and have had no problems
POST about 240hp A-series: rods ARE stock because he raves about there original quality and strength - he mentioned he was expecting it to throw a rod but it hasnt so he likes the standard rods
But don't let the engine ping (detonatation):
POST steveo: in a standard bottom end ... [with] a crappy tuning it leaned out up high and pinged like crazy at that amount of boost ... I had trouble with 'rolling' the ring lands above 15psi
Everything about having an engine survive under boost is the "tuning" (control over the fuel burn)
  • injection - complete fuel control is easier to achieve than with carburetion. Don't ever let it go lean!
  • ignition - complete spark control (limit the advance so there is no detonation/pinging)
  • wastegate - no spikes. An external gate may work better
  • temperatures:
    • Big enough radiator to support the HP made
    • keeping air charge cool (to avoid detonation)
    • keeping combustion temps cool (to avoid detonation) by rich mixture or by water injection or by lowering the compression ratio
    • keeping the turbo bearing cool
  • exactly perfect AFR (air/fuel ratio) for complete even burning. Under full boost this means an unusually rich ratio to keep the charge cool and avoid detonation. Note that stoich ratio (14.7) is not ideal for either power nor fuel economy but is used only to enable catalytic conversion
Stage 1
20% more HP than stock.
A stock A-series engine can take 10 psi. You don't even need an intercoolor, and so you can use draw-through on a stock carburetor. But blow-through is easier.
1000.jpgAlbum 1000
  • Stock engine
  • Loop piping from stock exhaust manifold (J-pipe)
    999.jpgAlbum click to view 5881.jpgAlbum click to view 5904.jpgAlbum click to view 5906.jpgAlbum click to view
  • Small Wrecking yard turbo ($100). If sized small enough, no wastgate or blow-off valve is needed
  • Tee into the oil pressure line, feed it into turbo. Tap a return line into the oil pan
  • Piping from turbo to stock carburetor via a top hat
  • Set initial timing at 3 degrees
  • In the distributor, weld the advance slots partially to limit mechanical advance
  • Keep the stock vacuum advance (it will have no effect under boost)
  • Fit larger power valve to carburetor
  • Fit secondary main jet two sizes larger
  • Stock fuel piping with medium pressure fuel pump (above 10 psi)
Limit boost to 5 psi.
Or go to 10 psi for short bursts on cooler days.
Stage 2
10 psi. 40% more HP.
  • stock block and head
  • Fit Intercooler (precludes use of draw-through)
  • Box the carburetor to go higher than 10 psi
  • Rejet primary main two sizes larger. Secondary main 3 sizes larger. Power valve increase.
  • Retard timing to 0 degrees. Connect vacuum advance up directly to manifold. This will help idle and starting out under low throttle, but the vacuum advance will have no effect under boost
  • Use 75.5-degree thermostat
  • High volume/high pressure fuel pump
  • anti-surge tank up front
  • Use custom exhaust manifold to mount the turbo
  • 2" exhaust
  • H165 rear axle
Stage 3
100% more HP than stock. Requires modified engine, but not high-RPM usage.
2 bar (28.2 psi)
1 bar (14.7 psi)
Do all the stage 2 modifications plus:
  • Use new Nissan rod bolts, torque to spec
  • Use ARP head studs
  • Custom pistons for low compression (7:1)
  • A12GX head, ported
  • Copper head gasket
  • Oil Cooler
  • EFI (or professionally modified & tuned box carburetor)
  • custom inlet manifold with large runners
  • 2.5" exhaust
  • Carefully-sized ball bearing turbo
  • 5/16" fuel lines and high volume/high pressure fuel pump
  • Fuel tank modified with baffles, or anti-surge tank up front
  • Custom-recurved distributor with Electronic Ignition
  • Spark retard system
  • Water-injection system
  • 63-Series Transmission for A-series
  • Heavy duty clutch
  • H190 rear axle (or H165 rear axle with heavy-spline axles)
  • traction bars
Proof
6779.jpgAlbum click to view 5016.jpgAlbum click to view 7356.jpgAlbum click to view 9949.jpgAlbum click to view 9977.jpgAlbum click to view 13376.jpgAlbum click to view 13755.jpgAlbum click to view 13779.jpgAlbum click to view 23785.jpgAlbum click to view 24245.jpgAlbum click to view
A15ETT
See main article: A15ETT
Twin-turbo A15 by 1200rallycar
A15 Before: 52.3 kw (70.1 hp)
A15 After: 75.6 kw (101.4 hp)
Sikyne's A12
160+ rwhp @ 15 lbs boost (standard H89 Head)
240+ rwhp @ 24 lbs boost (big valve ported head)
2nd-hand GT2860R (707160-5) ball bearing turbo
E85 fuel, intercooled
stock and unmodified H89 head
Cam: 236 Degrees at .050 lift
Maximum advance at 16 psi boost: 23 degrees
ARP head studs
stock pistons, crank and rods
standard headgasket
about 120 Lb Ft from 5100 to 6800 RPM @ 15 psi
dyno chart
23949.jpgAlbum 23949
Turbo systems
Oh boy, there are a lot of choices when turbo-ing your engine.
See Main Article: Turbo systems
Kits
Factory Turbo Systems
Draw-through or blow-through turbo systems?
Carburetor Setup for Blow Thru and for Draw Thru
Cooling: Radiator, Intercooler and Water Injection
Top Mount or Bottom Mount
Wastegate
Blow-off valve (or recirculation valve)
Spark Curve
Camshaft
Fuel pump
Boost pressure
Exhaust Manifolds and Intake Manifolds
Troubleshooting
Builds
120jas
Top Mount: TD04 draw-through Dellorto
20621_57b98efa50afd.jpgPost 480687
Low Mount:
20621_57bf7d5916445.jpgPost 480821 20621_57bf7d819c20a.jpgPost 480821
B110SSS
B20 A15
A15 with Toyota CT12 turbo
19314.jpgAlbum 19314 19342.jpgAlbum 19342
chris1200t
March 2005
A12 engine
A12 inlet manifold (plenum removed)
Daihatsu 1000cc turbo
* bolted to exhaust manifold heater flange
suck-through 2" SU carburetor from MG
5951.jpgAlbum 5951 5928.jpgAlbum 5928 5889.jpgAlbum 5889 5832.jpgAlbum 5832 7387.jpgAlbum 7387
2nd version: Blowthrough
December 2005
boxed Hitachi carb
IHI rhb5 turbo
Custom manifold
7640.jpgAlbum 7640 7602.jpgAlbum 7602 7601.jpgAlbum 7601
3rd version
November 2006
naturally aspirated dual Mikuni-Solex
10988.jpgAlbum 10988
dato8u
POST power: will do 13s now still with the standard block
EFI A14 out of Hawkes Bay
4481.jpgAlbum 4481 4480.jpgAlbum 4480 4914.jpgAlbum 4914 4479.jpgAlbum 4479
datsmokin
Forum discussion: POST HELP !! A12 turbo
turbo001.jpg turbo002.jpg turbo003.jpg turbo004.jpg turbo005.jpg turbo007.jpg turbo009.jpg
datsonovic
Zenith-Stromberg 1.75 with T04 turbo. See POST 7 years of 30 pounds and all is well
  • A15 in Datsun VB10 running 30psi boost
  • dyno'd at 105 kw @6000 rpm with 17 psi boost
  • running BP Ultimate pump gasoline with water injection
  • 90,000+ KM 30PSI AND ALL IS WELL
tourque of the 1500 isnt lost off boost. after 3000 she starts spooling up and by 3500 shes on boost at 4000 shes on full boost and dosnt run out until well after 7000
11635.jpgAlbum 11635 11631.jpgAlbum 11631 11630.jpgAlbum 11630 19909.jpgAlbum 19909 19890.jpgAlbum 19890 11623.jpgAlbum 11623 11622.jpgAlbum 11622 2519.jpgAlbum 2519 2511.jpgAlbum 2511
Datsun100ATurbo
A15 turbo intercooler
twin Dellorto 40H
homemade adjustable cam timing gear
big valves: 42mm + 33mm
custom modified piston dish
2967.jpgAlbum 2967 2982.jpgAlbum 2982
Empson
28218.jpgSuckthru
fat910
Forum discussion: POST a12 turbo 1200 sedan
Unmodified A12 short block
8 to 10 pound boost
hi flow garrett t2
custom hat and weber carb
custom sump
vl turbo fuel pump with malpassi fuel reg
saab turbo bov
It is easier to build up a 120Y engine instead of a 1200 engine as the alternator is not on the exhaust side
blow through A12
9641_49d47d0def86c.jpgPost 249542
Top-hatted carburetor on A12
9641_49dc92c935148.jpgPost 250245
Weber 32/36 blow-thru with frankthedolphintrainer turbo manifold
13611.jpgAlbum 13611 13642.jpgAlbum 13642 13641.jpgAlbum 13641 13524.jpgAlbum 13524 13266.jpgAlbum 13266 13771.jpgAlbum 13771 13768.jpgAlbum 13768 13817.jpgAlbum 13817
Intercooler
13338.jpgAlbum 13338 13339.jpgAlbum 13339 13340.jpgAlbum 13340
finn
Finn may have the world's quickest A-series engine. It runs a high 11 second quarter mile with Turbo Master Power.
See Main Article: Finn A14
josh_c
Suck-through SU, the classic setup
23088.jpgAlbum 23088 23087.jpgAlbum 23087 23086.jpgAlbum 23086 23085.jpgAlbum 23085 23084.jpgAlbum 23084 23082.jpgAlbum 23082 23089.jpgAlbum 23089
kegs
5527.jpgAlbum 5527
Turbocharged A15
Twin Dellorto DHLA 45 carburetors on Redline manifold
Custom airbox hat
Garret A/R 48 turbo
Intercooler from 200SX
2.5 inch dump pipe
Liverpool Exhaust
5526.jpgAlbum 5526
5462.jpgAlbum 5462 5463.jpgAlbum 5463 5587.jpgAlbum 5587 6661.jpgAlbum 6661 6863.jpgAlbum 6863
more photos
oan78
A12 Sedan with Weber and Hitachi turbo
10474.jpgAlbum 10474
A12 wagon with 175 Stromberg and Mazda 20B turbo
10476.jpgAlbum 10476 7279.jpgAlbum 7279 7278.jpgAlbum 7278
rezlo
See also: rezlo
ZA turbo A15, and when racing class rules changed, changed over to A14
17526.jpgAlbum 17526
rice
For maximum boost, use a large turbo. Lag is heavy, but still operable.
* Drawthrough
* 45 Weber DCOE carburetor
* T4 turbo @ 10 psi
* Compression ratio: 8.2:1
9809.jpgAlbum 9809 9808.jpgAlbum 9808
topgear
9947.jpgAlbum 9947 8137.jpgAlbum 8137
A12 turbo made 100kw rwhp on 12-13 lbs boost
See Main Article: Topgear A12 Turbo
  • stock block except for new rings
  • A14 head
  • suck-through SU carburetor
  • no intercooler
sikyne
See Main Article: $1200 EFI Turbo A12
slam1024
slam1024 added a turbo
* 1973 Datsun 1200 2-door sedan
* Custom manifold with runners from Tercel
* stock SU blow-through setup from 1.3 liter MG Metro Turbo
17911.jpgAlbum 17911
25851.gifAlbum 25851 20314.jpgAlbum 20314
21918.jpgAlbum 21918 21917.jpgAlbum 21917 20282.jpgAlbum 20282 20281.jpgAlbum 20281 17913.jpgAlbum 17913 17913.jpgAlbum 1791317912.jpgAlbum 17912 17911.jpgAlbum 17911 17095.jpgAlbum 17095 16966.jpgAlbum 16966 16965.jpgAlbum 16965
steveo 1
Using stock exhaust manifold with suck-through. Cut oval port manifold with hose to connect it to the pipe work that goes to the commpressor side of the turbo and the turbo sits on the sunny manifold. it look better in real life!
2647.jpgAlbum 2647
ThomasSymes
POST Ex-MYORGZM sale
$8,000 from Jake's Performance in Canberra
originally built for Simon Woolford ex-Canberra Raiders
A15 engine built
Garrett turbo
Weber downdraft modified for blow-through use
intercooler
Upgraded Radiator
fuel system surge tank etc
exhaust system
All pipe work inc
Boost controller
runs 7 or 11 psi up to 14psi
130rwkw with papers
Photos
See
Turbo Manifold Photos
Turbo Photos 1
Turbo Photos 2
Intercooler Photo Index
22407.jpg 22408.jpg 22668.jpg 22916.jpg 22919.jpg 22921.jpg 22922.jpg 23013.jpg 23014.jpg 23015.jpg 23940.jpg 23941.jpg 24111.jpg 24244.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Turbo"
This page has been accessed 132,293 times. This page was last modified 04:08, 17 November 2021. Content is available under Datsun 1200 Club.
