Turbo
Revision as of 23:16, 1 May 2018; view current revision
Category: Forced Induction
Forced induction comes in two forms: Supercharging and Turbo-supercharging. This article will focus on the turbocharger. For a comparison with the supercharger, see Forced Induction.
For the turbo compressor itself, see Turbos
For specific turbocharger models, see Turbos
Big Power from a stock A-series engines can be had by adding a turbocharger. A turbo setup on an A12 makes more power and torque than a worked non-turbo A14, for a fraction of the build cost.
See Main Article: $1200 EFI Turbo A12
Turbo setups range from modest to wild.
21789.jpgAlbum 21789
Discussion: POST regarding Turbocharging A12
350.jpgAlbum 350
Stage 1
20% more HP than stock.
A stock A-series engine can take 10 psi. You don't even need an intercoolor, and so you can use draw-through on a stock carburetor. But blow-through is easier.
1000.jpgAlbum 1000
  • Stock engine
  • Loop piping from stock exhaust manifold
    999.jpgAlbum click to view 5881.jpgAlbum click to view 5904.jpgAlbum click to view 5906.jpgAlbum click to view
  • Small Wrecking yard turbo ($100). If sized small enough, no wastgate or blow-off valve is needed
  • Tee into the oil pressure line, feed it into turbo. Tap a return line into the oil pan
  • Piping from turbo to stock carburetor via a top hat
  • Set initial timing at 3 degrees
  • In the distributor, weld the advance slots partially to limit mechanical advance
  • Keep the stock vacuum advance (it will have no effect under boost)
  • Fit larger power valve to carburetor
  • Fit secondary main jet two sizes larger
  • Stock fuel piping with medium pressure fuel pump (above 10 psi)
Limit boost to 5 psi.
Or go to 10 psi for short bursts on cooler days.
Stage 2
10 psi. 40% more HP.
  • stock block and head
  • Fit Intercooler (precludes use of draw-through)
  • Box the carburetor to go higher than 10 psi
  • Rejet primary main two sizes larger. Secondary main 3 sizes larger. Power valve increase.
  • Retard timing to 0 degrees. Connect vacuum advance up directly to manifold. This will help idle and starting out under low throttle, but the vacuum advance will have no effect under boost
  • Use 75.5-degree thermostat
  • High volume/high pressure fuel pump
  • anti-surge tank up front
  • Use custom exhaust manifold to mount the turbo
  • 2" exhaust
  • H165 rear axle
Stage 3
100% more HP than stock. Requires modified engine, but not high-RPM usage.
2 bar (28.2 psi)
1 bar (14.7 psi)
Do all the stage 2 modifications plus:
  • Use new Nissan rod bolts, torque to spec
  • Use ARP head studs
  • Custom pistons for low compression (7:1)
  • A12GX head, ported
  • Copper head gasket
  • Oil Cooler
  • EFI (or professionally modified & tuned box carburetor)
  • custom inlet manifold with large runners
  • 2.5" exhaust
  • Carefully-sized ball bearing turbo
  • 5/16" fuel lines and high volume/high pressure fuel pump
  • Fuel tank modified with baffles, or anti-surge tank up front
  • Custom-recurved distributor with Electronic Ignition
  • Spark retard system
  • Water-injection system
  • 63-Series Transmission for A-series
  • Heavy duty clutch
  • H190 rear axle (or H165 rear axle with heavy-spline axles)
  • traction bars
Proof
6779.jpgAlbum click to view 5016.jpgAlbum click to view 7356.jpgAlbum click to view 9949.jpgAlbum click to view 9977.jpgAlbum click to view 13376.jpgAlbum click to view 13755.jpgAlbum click to view 13779.jpgAlbum click to view 23785.jpgAlbum click to view 24245.jpgAlbum click to view
A15ETT
See main article: A15ETT
Twin-turbo A15 by 1200rallycar
A15 Before: 52.3 kw (70.1 hp)
A15 After: 75.6 kw (101.4 hp)
Sikyne's A12
See: POST A12 Turbo Development thread
160+ rwhp @ 15 lbs boost (standard H89 Head)
240+ rwhp @ 24 lbs boost (big valve ported head)
2nd-hand GT2860R (707160-5) ball bearing turbo
E85 fuel, intercooled
stock and unmodified H89 head
Cam: 236 Degrees at .050 lift
Maximum advance at 16 psi boost: 23 degrees
ARP head studs
stock pistons, crank and rods
standard headgasket
about 120 Lb Ft from 5100 to 6800 RPM @ 15 psi
dyno chart
23949.jpgAlbum 23949
Draw-through or blow-through turbo systems?
Section by datto_dave
The carburettor can be mounted in two positions on a turbo-charged engine, and a great deal of controversy exists as to which is better. The carburettor can be mounted such that it feeds air into the turbo then the turbo feeds it to the engine. This is known as a Draw-Through system. Under these conditions the carburettor operates more or less as it would on a naturally asperated engine. Another school of thought says that the carburettor should be mounted between the turbocharger and the intake manifold. This means that the turbocharger draws fresh air and pumps it into the carburettor, which then feeds the fuel/air mixture to the engine. This blow-through setup allows the use of an intercooler, which draw-through does not. In fact there are several advantages to a blow through over a draw through, because the fuel/air does not have to travel through the turbo. The blow through system requires a boost sensitive rising rate fuel pressure regulator in order to increase fuel pressure with boost pressure as the rpms rise.
Blow-through system feeding Boxed carburetor
2249.jpgAlbum 2249
Another snag to the blow-through system is that the carburettor must be enclosed in a pressure box and the fuel supplied to the carburettor must be at a suitable pressure above the boost pressure. This means the fuel pressure has to be regulated in accordance with the boost pressure at all times. My own personal preference to date has been for the draw-through system this is largely substantiated by other people in the industry who are running very high-powered turbocharged cars. Almost all are using draw-through systems. However, the speed equipment industry doesn’t stand still. A new development with blow through systems could change the picture. The specially designed for ‘blow-through turbo applications Dellorto side draught carburettors may well be that development.
Blow-through system feeding carb top-hat
519.jpgAlbum click to view
A third possibility exists: fuel injection. Here, the injection system has to be designed to measure the amount of air going into the turbocharger by whatever means. It then injects the correct quantity of fuel into the engine at whatever point is convenient. The butterflies for throttling the engine may be situated either prior or after the turbocharger, depending on ease of installation layout. If the injectors are situated in such a position that they injected into a high pressure boosted environment, then the injection pressure must be compensated for by whatever pressure the boost level has reached. Fortunately most fuel injection systems have ample fuel pressure to cope with as high as 40-45 psi used in alcohol burners.
Intercooler
An Intercooler is not needed. The first three years of the Porsche 911 Turbo didn't have one (75-77), yet this 3.0 liter turbo outperformed 7.5 liter NA cars. However there are very good reasons to use an intercooler, including:
  • Intercooler is worth the extra cost and complexity, because it significantly reduces the temperature of the compressed air, which increases the boost possible with a given octane fuel
  • An alternative is to use water or alcohol injection. Some OEM applications used water injection (ex. 1962 Oldsmobile Jetfire)
An intercooler can result in far more HP, but requires a blow-through system (boxed carburetor) or EFI port injection. This is because for safety you don't want air-fuel mixture going through the cooler, where it will condense out of the airstream and result in fuel puddles in the cooler!
By keeping the air cool and therefore dense, the same boost will make more HP, because more air is entering the engine. Because it's not overheated, more spark advance can be applied for more HP.
Can you re-purpose a car radiator and use it as an intercooler? Using an aluminum radiator should be better than nothing. Unless someone actually tested this, we are all just guessing as to whether it will work or not. Radiators can flow a lot of water, and air is easier to pump ... so air should flow through w/o significant restriction. Putting this in front of the car should allow some cooling effect, although obviously not as a much as a purpose-designed cooler.
Also see: Intercooler Photo Index
Nissan GTiR factory-style intercooler (top mount) | Traditional in-front-of-radiator intercooler
9749.jpgAlbum 9749 296.jpgAlbum 296 13123.jpgAlbum 13123
Water Injection
An alternative to an intercooler is to use water or alcohol injection. Some OEM applications used water injection, for example the 1962 Oldsmobile Jetfire injected water/alcohol mix.
Boost Cooler brand uses a 300 psi pump to inject fluid just before the throttle plate.
Into the air filter is quite effective for a suck through turbo. It not only cools the air fuel mixture but also cools the compressor wheel and that helps the ADI atomise also. But there is a problem with this system, water WILL pit the compressor wheel over time and over time wear out the turbo faster.
7161.jpgAlbum 7161
ADI tank can use a pump to spray liquid into the system (see discussion about eliminating the pump)
7157.jpgAlbum 7157
Wastegate
A Wastegate is used for adjustable control over boost pressure. When the set pressure is exceeded, exhaust is routed around the turbine to go out the tailpipe
  • Not needed if you carefully size the turbo to the application (ensuring that at maximum rpm, design boost is not exceeded). Older OEM applications used this method.
Blow-off valve (or recirculation valve)
A Blow-off valve is used to preventin the turbo from surging, for example during gear shift or whenever throttle is closed. Porsche uses these, so obviously they work.
  • Blow-off intake boost to atmosphere. Boost is lost. Simple, inexpensive
  • Blow-off to compressor inlet (recirculate back through turbo inlet). Used to enhance throttle response: Boost is kept in circuit for immediate availability when throttle is opened again
A Blow-off valve is OPTIONAL. Many turbo setups work fine without a blowoff valve.
Carburetor Setup
  • EFI is best allowing better control of mixture, but carbs can work fine
  • Draw through was used by many OEM setups. It is reliable, and the simplest option. The downside is you can't use an intercooler, as the fuel will condense in the cooler.
  • Need richer jets to keep air charge cool and prevent detonation
Blow Thru
Blow through works well. The main reason to use this over a draw-through is so an intercooler can be used.
See main article: Boxed carburetor
Boxed carb allows a more or less stock carb to be used, the outside pressure balancing the inside pressure
Top Hat style
Draw Thru
Suck-through setups are simpler and more fool-proof than blow-through.
SU-type carburetor
22407.jpgAlbum 22407 22408.jpgAlbum 22408
Turbo kit with Stromberg carburetor (Datsun L-series engine)
22916.jpgAlbum 22916 22919.jpgAlbum 22919 22921.jpgAlbum 22921 22922.jpgAlbum 22922
Spark Curve
The more compression, the less advance the engine can handle. But a high-compression engine can still use some advance, and even a forced-induction engine needs some advance to make the most power at varying RPMs. The key is LIMITING the advance to a safe level.
Consequences of too much spark advance: cracked pistons, broken ring lands
What about locking the distributor? Yes, if you lock the advance mechanism, yes, it can help prevent detonation, but also it won't make the best power. Locked distributor will only work great at high-RPM, high-boost condition -- which is where racers spend most of their time, so it works well for racing. For a street engine, you will have a more flexible, more powerful engine at all RPMs by NOT locking the distributor, but by limiting the advance.
CONSTANT-LOAD RACING METHOD
  • Lock the distributor advance. Set full timing to an appropriate level, say 30 degrees for a high-compression engine or for maximum advance at 16 psi boost: 23 degrees.
LOW-DOLLAR STREET POWER METHOD
  • In the distributor, weld the advance slots partially to limit mechanical advance (see Limiting Mechanical Advance)
  • Keep the stock vacuum advance (it will have no effect under heavy throttle or boost)
  • Connect vacuum advance up directly to manifold. This will help idle and starting out under low throttle, but the vacuum advance will have no effect under heavier throttle
  • Set initial timing to lower than normal, say 3 degrees or 0 degrees (instead of the normal 5-7)
  • Downside: On a forced-induction engine, the advance won't be right for varying boost levels. You'll have to set the advance for full boost scenario, giving up HP and fuel economy for lower throttle conditions such as highway cruising
BEST METHOD: fully programmable ignition
  • use a crank trigger with a fully programmable ignition system. MegaSquirt and other ECUs can provide initial timing, limited full timing, timing under boost and even retard under boost and compensate for high temperatures.
  • use a standalone advance controller like the Block Box or an MSD Programmable, which allows for limited mechanical advance along with variable retard under boost, off-boost, and partial-boost conditions. With such a controller, the distributor is locked, and the box takes over the exact timing curve.
Camshaft
The stock A12 cam works well with a turbo.
If you wish to run lower revs than the standard A12 6,000 RPM shift point, a milder cam can be installed. If you want more power, a higher RPM cam can be fitted.
Your local cam grinder can advise on the best cam for your usage patterns.
Turbo Camshaft specs
921.jpgAlbum 921
Fuel pump
  • Draw-through
    • Stock fuel pump is good for draw-through setup. It's not enough for a blow-through setup, as 2.5 boost would overpower the fuel pressure
  • Blow-through
    • Using a low-pressure (15 psi) electric pump oughta be good for a 10-12 psi boost.
    • Needle and seat has trouble holding more than 10 psi fuel pressure. Better to use a secondary 15-psi pump to cut in only when needed.
    • Best setup is to use a rising-rate regulator with a high-psi pump. Excess fuel is returned to the tank.
Malpassi rising-rate regulator
14014.jpgAlbum 14014 527.jpgAlbum 527
Turbochargers
See main article: Turbos
  • T3 is pretty big for an A12. Needs high rpm, head work, etc
  • Mid-80s Nissan Pulsar turbo (E15 engine) has integral wastegate
  • go_the_datto actually tried Daihatsu diesel 1.0 turbo on A12. Good response in lower rpm ranges. Two make better twin-turbo application for A12
Here is some helpful info on everything from how a turbo works to choosing the right turbo for your engine based on compressor maps Turbo Tech
3007.jpgAlbum click to view 3393.jpgAlbum click to view 8643.jpgAlbum click to view 8644.jpgAlbum click to view
Flange
Flanges are different to suit each turbo style. For example T3 pattern requires a T3 flange some of the common types are T25/28 ,T03,T04, then there is open and split pulse.
Diesel vs. Petrol Turbos
Barpk: The main difference between a petrol and diesel turbo is its seals. Diesel turbos don't have positive seal turbo seals, which means that if put it in a suck-through system they can leak oil under extreme vacuum, which happens when throttle is closed. This is not a problem in a blow-through system.
Boost pressure
  • 6-7 psi is what a lot of OEM applications use.
  • 10 psi should be possible with a stock A12/A14
  • 14.7 lbs gives theoretically double the airflow so max. power would be about 2x stock, but this isn't actually the result. The reason is that the stock induction and exhaust system won't flow this much air under pressure. However, the low rpm torque could approach 2x (at about 2250 rpm) if a small turbo is used. So a 130hp turbo engine will have much more performance than a 130hp NA engine
  • 1986 Honda 1.5 liter ran boost of 4.0 bar - that's 300 bhp ... per cylinder ... with special fuel
Induction and Exhaust
Obviously, for more airflow, a higher flowing carb, intake, heads (ports and valves) and exhaust system is beneficial. The turbo will increase power on a stock engine, but increasing the airflow capability of the engine will bring your turbo engine to its full potential
Exhaust Manifolds
The stock manifold may be used with a J-pipe for mounting a turbo. But a custom manifold that allows direct mounting is more efficient (allows more power).
See Main Article: Turbo_exhaust_manifolds
Intake Manifolds
The stock inlet manifold may be used. But obviously a larger one makes for more HP.
See main article: Turbo Inlet Manifolds
20267.jpg 301.JPG 654.jpg 7952_5156836ba4deb.jpgUpload click to view
Kit
The well-traveled turbo setup
8558.jpgAlbum 8558 8195.jpgAlbum 8195 7611.jpgAlbum 7611 27019.jpgAlbum 27019 27020.jpgAlbum 27020 27021.jpgAlbum 27021 27022.jpgAlbum 27022
Factory Turbo Systems
Might you spend less money and get more horsepower and reliability by swapping in a factory turbo motor?
Nissan Turbos
Z18T. See Z-series Engine Swap
43.jpgAlbum 43
CA18DET. See CA-Series Engine Swaps
91.jpgAlbum 91
SR20DET. See SR engine swap
111.jpgAlbum 111
Mazda Wankel Engine – Turbo
Mazda 13BT. See Mazda rotary engine swap
93.jpgAlbum 93
Mazda piston Engine – Turbo
Turbo Mazda piston-engine
818.jpgAlbum 818
Builds
B20 A15
A15 with Toyota CT12 turbo
19314.jpgAlbum 19314 19342.jpgAlbum 19342
josh_c
Suck-through SU, the classic setup
23088.jpgAlbum 23088 23087.jpgAlbum 23087 23086.jpgAlbum 23086 23085.jpgAlbum 23085 23084.jpgAlbum 23084 23082.jpgAlbum 23082 23089.jpgAlbum 23089
slam1024
slam1024 added a turbo
* 1973 Datsun 1200 2-door sedan
* Custom manifold with runners from Tercel
* stock SU blow-through setup from 1.3 liter MG Metro Turbo
17911.jpgAlbum 17911
25851.gifAlbum 25851 20314.jpgAlbum 20314
21918.jpgAlbum 21918 21917.jpgAlbum 21917 20282.jpgAlbum 20282 20281.jpgAlbum 20281 17913.jpgAlbum 17913 17913.jpgAlbum 1791317912.jpgAlbum 17912 17911.jpgAlbum 17911 17095.jpgAlbum 17095 16966.jpgAlbum 16966 16965.jpgAlbum 16965
kegs
5527.jpgAlbum 5527
Turbocharged A15
Twin Dellorto DHLA 45 carburetors on Redline manifold
Custom airbox hat
Garret A/R 48 turbo
Intercooler from 200SX
2.5 inch dump pipe
Liverpool Exhaust
5526.jpgAlbum 5526
5462.jpgAlbum 5462 5463.jpgAlbum 5463 5587.jpgAlbum 5587 6661.jpgAlbum 6661 6863.jpgAlbum 6863
more photos
fat910
See a12 turbo 1200 sedan
Unmodified A12 short block
8 to 10 pound boost
hi flow garrett t2
custom hat and weber carb
custom sump
vl turbo fuel pump with malpassi fuel reg
saab turbo bov
It is easier to build up a 120Y engine instead of a 1200 engine as the alternator is not on the exhaust side
blow through A12
9641_49d47d0def86c.jpgPost 249542
Top-hatted carburetor on A12
9641_49dc92c935148.jpgPost 250245
frankthedolphintrainer
Weber 32/36 blow-thru with frankthedolphintrainer turbo manifold
13611.jpgAlbum 13611 13642.jpgAlbum 13642 13641.jpgAlbum 13641 13524.jpgAlbum 13524 13266.jpgAlbum 13266 13771.jpgAlbum 13771 13768.jpgAlbum 13768 13817.jpgAlbum 13817
Intercooler
13338.jpgAlbum 13338 13339.jpgAlbum 13339 13340.jpgAlbum 13340
Empson
A series suck through turbo setup by James Empson (twitch@bigpond.com) 2008/05/01 Datsun B10 coupe
The turbo is an IHI - RB6, originally off a mitsubishi Galant 2 litre. the exhuast manifold is off an A15, with a flange welded onto it. The inlet manifold is suited to an Oval port head, the SU is a 1.5 inch.
datsonovic
Zenith-Stromberg 1.75 with T04 turbo
11635.jpgAlbum 11635 11631.jpgAlbum 11631 11630.jpgAlbum 11630 19909.jpgAlbum 19909 19890.jpgAlbum 19890 11623.jpgAlbum 11623 11622.jpgAlbum 11622 2519.jpgAlbum 2519 2511.jpgAlbum 2511
oan78
A12 Sedan with Weber and Hitachi turbo
10474.jpgAlbum 10474
A12 wagon with 175 Stromberg and Mazda 20B turbo
10476.jpgAlbum 10476 7279.jpgAlbum 7279 7278.jpgAlbum 7278
rice
For maximum boost, use a large turbo. Lag is heavy, but still operable.
* Drawthrough
* 45 Weber DCOE carburetor
* T4 turbo @ 10 psi
* Compression ratio: 8.2:1
9809.jpgAlbum 9809 9808.jpgAlbum 9808
Photos
See
Turbo Manifold Photos
Turbo Photos 1
Turbo Photos 2
22407.jpg 22408.jpg 22668.jpg 22916.jpg 22919.jpg 22921.jpg 22922.jpg 23013.jpg 23014.jpg 23015.jpg 23940.jpg 23941.jpg 24111.jpg 24244.jpg
